Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: when the program is reset » » » » Post: Re: when the program is reset |
Print at Sep 20, 2026, 2:36:22 AM |
| Posted by Puybaret at Jan 8, 2019, 3:12:49 PM |
Re: when the program is reset Sorry, you shouldn't hope to recover data you lost 3 months ago. Did you check that the content of the folder C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D changes when you import some furniture? If it's the case, it means that Sweet Home 3D works correctly and the program doesn't remove any of the imported furniture unless you delete them from the catalog. Anyway, if you want to backup the imported furniture, you could also create some furniture libraries with the plug-in ExportToSH3F. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 2:36:22 AM |
