Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: massive color-difference » » » » Post: Re: massive color-difference |
Print at Sep 21, 2026, 2:20:17 AM |
| Posted by hal9000 at Oct 21, 2018, 6:04:44 PM |
Re: massive color-difference I noticed that the table and chairs, which are textured, are more similar between the two render modes. More as a test or possible workaround (if it works) than a definitive solution, could you make a little bitmap containing only the plain color that you want to use and then use it as a texture for the material? I wonder if it will be processed the same way... ![]() ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Sep 21, 2026, 2:20:17 AM |
