Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: create room with exact size impossible » » » » Post: Re: create room with exact size impossible |
Print at Aug 21, 2026, 3:59:45 PM |
| Posted by hansmex at Apr 11, 2017, 10:02:36 AM |
Re: create room with exact size impossible Possibility 1 To draw EXACT lengths, use this feature: - select the Walls button - click for first point of wall - hit Enter - a small window pops up where you can enter the exact length of the wall, angle and thickness - make walls 1 mm longer than needed and set wall thickness to 1 mm Your walls will have your exact dimensions. Possibility 2 If you have the AdvancedEdit plug-in installed, you could also draw a room, then EditPoints to set the exact room dimensions. - select the Room button - draw a room that has the approximate size and shape you need - edit the room points using Plan --> Edit Points - select the Walls button - double click on the room: walls will be drawn around your room Good luck with this "kids program". Maybe you should study the user guide and help files before drawing conclusions? Hans My motto in life: If you don't know how to use a program: blame the program, not yourself! ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Aug 21, 2026, 3:59:45 PM |
