Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to set the different elevations at each corner of the ground level? » » » » Post: Re: How to set the different elevations at each corner of the ground level? |
Print at Sep 10, 2026, 8:06:43 AM |
| Posted by okh at Jan 28, 2016, 8:06:43 PM |
Re: How to set the different elevations at each corner of the ground level? You probably need a workaround, if you look around the forum, you will find many threads discussing this, e.g. 4817 , 3335 , 6060 , 4450 - and then quite a few... Depending on what you want, triangles or other geometry may help. ok. |
Current timezone is GMT Sep 10, 2026, 8:06:43 AM |
