Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Drawing issues » » » » Post: Re: Drawing issues |
Print at Oct 1, 2026, 11:40:02 PM |
| Posted by okh at Jan 25, 2016, 8:42:04 AM |
Re: Drawing issues 1. When I started to draw the top level, how do I add one below? Double-click the tab on the new level and insert the correct elevations/floor thickness and ceiling height (for each level).2. How can I create a roof? If you look ah the FAQ and in the forum you will find hints, e.g. thread 6372 has some links to start you off. 3. How can I creat a wall which starts at the sealing(if you have a room which a part of it is sloped)? If you modify a wall, it is a question of setting start and end heights. Often you will first need to split the wall first. ok |
Current timezone is GMT Oct 1, 2026, 11:40:02 PM |
