Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can't see 1st floor from living room » » » » Post: Re: Can't see 1st floor from living room |
Print at Sep 20, 2026, 1:43:27 PM |
| Posted by Puybaret at Oct 26, 2012, 10:23:41 AM |
Re: Can't see 1st floor from living room If you want to create a mezzanine, you have to play with the visibility of the floor and the ceiling of the floors. To work faster, use copy-paste from a level to an other to copy the floor/ceiling of the room that matches the mezzanine, and use the Select object menu item available in contextual menu of the plan. Look closely to this example I submitted to a similar question in the French forum. The mysterious line is the ceiling of the room at last level. It behaves badly because of the smaller wall you used at that place (see help about rooms for explanations about how the elevation of the points of ceilings are computed). If you create a "ceiling room" that covers the same surface of your home as the "floor room" at first level, this should disappear. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 1:43:27 PM |
