Sloped Walls question
This topic has been viewed 4229 times and has 6 replies
Thread status: Active
Post Reply New Topic
StylusPilot
Post by StylusPilot »
I see the newer versions contain the ability for sloped walls.
I have a House which is on a sloped block of land.
roughly 27 degree slope
How can I start a wall at point A
have it go 10m and have it end at point B on a 27 degree slope?
I have been unable to find a guide so far.
any assistance appreciated.
User avatar
Country: Netherlands
Re: Sloped Walls question
Post by hansmex »
Maybe you could try the Math Forum ?
User avatar
Country: Paris, France
Contact:
Post by Puybaret »
B must be tan(27°) x 10 = 5.1 m higher than A.
User avatar
macfrog
Country: Germany
Post by macfrog »
Friends,
i believe he's looking for a solution to create a downwards sloping wall, with a leveled upper end and the floor on top....
macfrog
StylusPilot
Thanks for that, very productive.
now onto my question, where is the option in the GUI for these settings for a wall?
Friends,
macfrog
Yes, thank you your version makes more sense.
User avatar
Post by hansmex »
If you use the above formula to calculate the slope, you can then use (in this order)
- CopyAsNewFurniture (to eliminate the floor) (see plug-ins PDF),
- Export to OBJ format (to export the wall segment as a model) and
- Import furniture.
Make sure that during importation you rotate the wall segment 180 degrees, so that the sloping side ends up at the bottom.
User avatar
Contact:
Post by Puybaret »
For one horizontal or vertical wall, no need to install CopyAsNewFurniture plugin.
Who is online
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 3 guests
