Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Staircase not visible in upper level » » » » Post: Re: Staircase not visible in upper level |
Print at Sep 20, 2026, 5:29:21 PM |
| Posted by Puybaret at Mar 20, 2012, 8:08:28 PM |
Re: Staircase not visible in upper level I cannot see this staircase on the floorplan of the upper level. Not sure I completely understand what you mean. If your staircase isn't higher enough, it won't be seen at the upper level and if you didn't check the Staircase option at the third step of the furniture import wizard, no hole in the floor will be computed.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 5:29:21 PM |
