Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: I Need Your Help "About Service Hatches" » » » » Post: Re: I Need Your Help "About Service Hatches" |
Print at Oct 5, 2026, 8:53:07 PM |
| Posted by hansmex at Dec 31, 2011, 5:54:25 PM |
Re: I Need Your Help "About Service Hatches" Vako, What you need is a combination of a door frame and a service hatch, but than invisible. This model isn't provided, but you can make it yourself with a bit of effort. 1 - Combine 3 very thin boxes into a door frame (2 vertical, one horizontal at the top) 2 - Export to OBJ format 3 - Using a text editor, add "d 0" (see this thread) to make it invisible 4 - Now import it as furniture, and make sure you check the check box "door/window" If you insert this model, it will function as a door frame, but because there's no floor part, the floors of two rooms will connect seamlessly. Maybe (very maybe) I will make the model after the weekend. Now it's time for bubbles, lots of bubbles. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Oct 5, 2026, 8:53:07 PM |
