confused imported glass not transparent
This topic has been viewed 6716 times and has 9 replies
Thread status: Active
Still a problem with your graphic card? [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Post Reply New Topic
User avatar
pencilart
Post by pencilart »
I have recently upgraded Art Of Illusion, which I use to make my models and I used to make glass and export it as an obj and the glass would be transparent (after having assigned a transparent texture to it). Using this new version of AOI (2.9) when I export a glass (tried it with a material and without a material) and import it into the latest version of SweetHome3D (3.4) the glass appears either gray or black, no transparency at all.
I don't know if the problem is with A.O.I. or SweetHome3D. How can I tell? And how do I fix this?
sclee
Country: Taipei, Taiwan
Contact:
Re: imported glass not transparent
Post by sclee »
Modifying the furniture, you try to use color, instead of using the textures.
It needs to increase transparency in the next version of the floor, Transparency of separate wall and floor.
User avatar
pencilart
Post by pencilart »
After playing around with this all day, I found that I had to go back to using this (the old way) by opening the .obj in a text editor:
Code: Select all
g sweethome3d_window_pane
usemtl flltgrey
User avatar
pencilart
Post by pencilart »
ok, never mind.
User avatar
Country: Paris, France
Contact:
Post by Puybaret »
If OBJ models created with a previous version of AOI are still correctly imported, it means that AOI changed something (it looks like a possible regression since version 2.9 brought changes on textures and materials). You can change it the way you did, but you can also change the value following "d" in the MTL file, 0 being fully transparent and 1 fully opaque.
If you're sure it's a bug, it would be nice to report it to AOI developer.
User avatar
pencilart
Post by pencilart »
There seems to be no simple "d" in the .mtl file.
This is the info that AOI puts into it:
Code: Select all
#Produced by Art of Illusion 2.9, Mon Dec 26 16:19:27 EST 2011
newmtl Glass
Kd 0.0928 0.0928 0.0928
Ks 0.144 0.144 0.144
Ka 0 0 0
illum 2
Ns 127
I tried making the "Kd" line as 0.0 0.0 0.0 but that did not work. I also tried it as 0 0 0 but that too did not work. The vase imported into SH3D was still black.
So, I went with:
Code: Select all
g sweethome3d_window_pane_vase
usemtl glasstransparent
in the .obj file.
Be expecting this vase ( http://www.storm-artists.net/view/117760 ) in the models contributions shortly. :D
User avatar
Contact:
Post by Puybaret »
You could add the "d" line yourself. For example:
Code: Select all
d 0.5
Your vase is really nice. Thanks for your contribution. [:)]
User avatar
pencilart
Post by pencilart »
So, the
Code: Select all
d 0.5
could be placed between
Code: Select all
newmtl Glass
and
Code: Select all
Or should it be placed at the bottom of
Code: Select all
Ns 127
User avatar
Contact:
Post by Puybaret »
You can place the d line anywhere between a newmtl line and the next newmtl line if there are more than one material defined in the MTL file.
User avatar
pencilart
Post by pencilart »
that worked! The glass is rather dark though. So now I have 3 versions: A light one, (usemtl glasstransparent) a medium shaded one, (usemtlglass) and now this one (using the method you just taught me).
