Print at Sep 19, 2026, 3:38:44 PM
Posted by Puybaret at Nov 8, 2011, 4:03:53 PM
Re: Add a new texture feature
That could be a nice plug-in. smile
The difficulty depends on your programming skills, but you could reuse many classes of Sweet Home 3D to help you achieve it faster. To avoid having too much to master, I would:
- learn how to program a new plug-in,
- program a dialog box that would let the user choose the image on each side of the cube,
- generate a cube at OBJ + MTL formats (generate one with Sweet Home 3D or better with an other 3D program and you'll understand quickly what it requires),
- gather the OBJ, MTL and textures files in a zip file,
- create a modifiable CatalogPieceOfFurniture instance, and add it to the catalog (and/or add it to home after that if you want it to appear in the plan), reproducing the behavior of the finish method in ImportedFurnitureWizardController class.
