Total posts in this thread: 197
Posts: 197   Pages: 20   [ Previous Page | 2 3 4 5 6 7 8 9 10 11 | Next Page ]
Previous Thread This topic has been viewed 1241128 times and has 196 replies Next Thread
Re: Sweet Home 3D 6.0
Tonight, the Beta 6 fixes two old problems reported by Ceciliabr and Okh:
- it fixes how objects very close and very far are displayed in Sweet Home 3D.
- it also fixes how sky texture are displayed in the 3D view, in such a way it now shows the same image in SunFlow rendering engine, as (logically) requested here. Compared to previous versions, this fix will display sky textures a little differently in the 3D view, and I hope you won't mind this change.
Okh and ndorigatti, I hope you'll be able to test .obj modifications to handle openings. Don't hesitate to request some help.
[Sep 5, 2018, 11:32:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
I have tested it.
I have tested it.
5.7 sky box algorithm is wrong.
6.0B6's sky box algorithm is correct.
But 5.7 can support 16K sky box Texture.(17430X4322 pixel)
6.0B6 can only support 8K sky box Texture.
8K's sky box is not clear enough.Need to support 16K
https://overpic.net/viewer.php?file=x2c6aem43yv1zifyu2p.png
https://overpic.net/viewer.php?file=xy4ad7ef4exdygqzm85wn.png
https://overpic.net/viewer.php?file=xee7jyye2ba21y635.png
6.0B6 Do not support 16K sky box Texture.
https://overpic.net/viewer.php?file=xytp4ekdkit6kyenk4pd.png
Partial panorama
[Edit 1 times, last edit by Puybaret at Sep 6, 2018, 11:00:56 PM]
[Sep 6, 2018, 9:17:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
Scan panorama Like this
[img]https://img.overpic.net/thumbs/8/s/i/x8sind7gr8pvf7edzshq9_s.png[/img]
This picture is 220 degrees.
Set the arc wall to 220 degrees.
Set the texture to the appropriate size
However,in Sweet Home 3D. the radian of the wall should not exceed 270 degrees. I hope the author can change to 360 degrees.
[Sep 6, 2018, 10:06:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your tests.
I wouldn't worry about the large image you couldn't render. It's probably because you launched SweetHome3D.6.0.beta.jnlp with javaws.exe 32 bit. If you run it with javaws.exe 64 bit, it won't fail.
[Sep 6, 2018, 11:07:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Today, the Beta 7 brings various features requested by users:
- Resizing the selected piece of furniture can be forced along only its width or depth when Ctrl shortcut (alt under macOS) is pressed
- The list of video formats were updated with 2.40:1 ratio formats, and HD resolutions
- The column widths are now saved and restored at home opening
- I added the menu items Plan > Make level the only viewable one and Plan > Make all levels viewable
- As soon as a home has some levels, all menu items related to levels are now available in a separated contextual menu displayed on level tabs.
- I added the X offset and Y offset spinners to the texture modification dialog box. These attributes let you set how the selected texture should be shifted along its width and height. The values are expressed in percentage of the width or the height of the texture.
When this dialog box is displayed to choose the sky texture, only the X offset spinner is displayed to let you shift the sky image.
Hope you'll like these new features and how I programmed them. Don't hesitate to request some adjustments if needed. I'll study them closely...
[Sep 10, 2018, 9:40:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
..dialog box is displayed to choose the sky texture, only the X offset spinner is displayed to let you shift the sky image...
That makes today's wisth redundant smile and I suppose request 879 too. This really is a great improvement. As are many of the other new features, but now development is faster than it is possible to test...
But the sky offset really works beautifully. Better than I hoped for this morning.
Thanks and congratulations. And no glitches in my somewhat random testing.
[Sep 10, 2018, 11:36:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great you like it smile
I know that you proposed an angle for the sky texture offset, but using a percentage seems more versatile in other cases, and isn’t too difficult to convert from degrees : 180° = 50%, 90° = 25%, 45° = 12.5%,...
[Sep 11, 2018, 1:16:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ndorigatti
Italia
What about adding this as hint/popover of the slider?
A lot of information are among the forum but very difficult to find or imagine in the app. And this is really important, not everyone is following the forum unfortunately
[Sep 11, 2018, 10:33:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The Beta 8 just contains a quick fix I forgot in the texture choice dialog box.
[Sep 11, 2018, 10:33:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
applause Re: Sweet Home 3D 6.0
1.Sky texture Do not support 16K
2.Sky texture may get stuck after multiple settings.It is recommended to add a preview graph to the texture of 4K 8K 16K, otherwise it will affect the speed very much.
3. I suggest that an 'Apply' button should be added to the XY offset set window.So that users can see changes immediately.
4.It is recommended to add the function of changing texture color(Hue) and texture transparency. Very convenient.
5.I suggest changing the image preview size of the texture settings window from 128X128 to 256X256 or 512X512.
128 is too small to see the difference
[Sep 11, 2018, 11:02:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
