{"name":"Sweet Home 3D","description":"News and tips about Sweet Home 3D","url":"https:\/\/www.sweethome3d.com","home":"https:\/\/www.sweethome3d.com\/zh-hant\/","gmt_offset":"0","timezone_string":"","page_for_posts":387,"page_on_front":1152,"show_on_front":"page","namespaces":["oembed\/1.0","wpml\/v1","flexible-table-block\/v1","rankmath\/v1","rankmath\/v1\/setupWizard","rankmath\/v1\/an","wp-super-cache\/v1","wpml\/st\/v1","wpml\/tm\/v1","wpml\/ate\/v1","wp-smush\/v1","hub-connector\/v1","rankmath\/v1\/ai-visibility","rankmath\/v1\/ca","rankmath\/v1\/in","rankmath\/v1\/status","rankmath\/v1\/link-genius","google-site-kit\/v1","wpmudev_pcs\/v1","wpmudev_blc\/v1","regenerate-thumbnails\/v1","otgs\/installer\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/www.sweethome3d.com\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"\u7528\u65bc\u64f7\u53d6 oEmbed \u8cc7\u6599\u7684\u8cc7\u6e90\u7db2\u5740\u3002","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"\u7528\u65bc\u64f7\u53d6 oEmbed \u8cc7\u6599\u7684\u8cc7\u6e90\u7db2\u5740\u3002","type":"string","format":"uri","required":true},"format":{"description":"\u8981\u4f7f\u7528\u7684 oEmbed \u683c\u5f0f\u3002","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"\u5167\u5d4c\u6846\u67b6\u6700\u5927\u5bec\u5ea6 (\u55ae\u4f4d\u70ba px)\u3002","type":"integer","default":600,"required":false},"maxheight":{"description":"\u5167\u5d4c\u6846\u67b6\u6700\u5927\u9ad8\u5ea6 (\u55ae\u4f4d\u70ba px)\u3002","type":"integer","required":false},"discover":{"description":"\u662f\u5426\u57f7\u884c\u672a\u6279\u51c6\u7684\u63d0\u4f9b\u8005\u7684 oEmbed \u63a2\u7d22\u8981\u6c42\u3002","type":"boolean","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/oembed\/1.0\/proxy"}]}},"\/wpml\/v1":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1"}]}},"\/wpml\/v1\/custom-xml-config":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/custom-xml-config"}]}},"\/wpml\/v1\/custom-xml-config\/validate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/custom-xml-config\/validate"}]}},"\/flexible-table-block\/v1":{"namespace":"flexible-table-block\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"flexible-table-block\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/flexible-table-block\/v1"}]}},"\/flexible-table-block\/v1\/options":{"namespace":"flexible-table-block\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/flexible-table-block\/v1\/options"}]}},"\/rankmath\/v1":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1"}]}},"\/rankmath\/v1\/saveModule":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"module":{"type":"string","description":"\u6a21\u7d44\u4ee3\u7a31","required":true},"state":{"type":"string","description":"\u6a21\u7d44\u72c0\u614b\uff08\u958b\u555f\u6216\u95dc\u9589\uff09","enum":["on","off"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/saveModule"}]}},"\/rankmath\/v1\/toolsAction":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"action":{"type":"string","description":"\u8981\u57f7\u884c\u7684\u52d5\u4f5c","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/toolsAction"}]}},"\/rankmath\/v1\/updateMode":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"mode":{"type":"string","description":"\u8981\u8a2d\u5b9a\u7684\u6a21\u5f0f","enum":["easy","advanced","custom"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/updateMode"}]}},"\/rankmath\/v1\/dashboardWidget":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/dashboardWidget"}]}},"\/rankmath\/v1\/updateSeoScore":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"postScores":{"type":"object","description":"\u6587\u7ae0\u5206\u6578","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/updateSeoScore"}]}},"\/rankmath\/v1\/updateSettings":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/updateSettings"}]}},"\/rankmath\/v1\/searchPage":{"namespace":"rankmath\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/searchPage"}]}},"\/rankmath\/v1\/disconnectSite":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"token":{"type":"string","description":"\u7db2\u7ad9\u6b0a\u6756","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/disconnectSite"}]}},"\/rankmath\/v1\/getFeaturedImageId":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"postId":{"type":"integer","description":"\u6587\u7ae0 ID","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/getFeaturedImageId"}]}},"\/rankmath\/v1\/updateRedirection":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectID":{"type":"integer","description":"\u7269\u4ef6\u552f\u4e00 ID","required":true},"objectType":{"type":"string","default":"post","description":"\u7269\u4ef6\u985e\u578b\uff0c\u4f8b\u5982\u6587\u7ae0\u3001\u8a5e\u5f59\u3001\u4f7f\u7528\u8005","required":true},"hasRedirect":{"type":"boolean","description":"\u7269\u4ef6\u662f\u5426\u6709\u91cd\u65b0\u5c0e\u5411","required":true},"redirectionID":{"type":"string","description":"\u91cd\u65b0\u5c0e\u5411 ID","required":false},"redirectionUrl":{"type":"string","description":"\u91cd\u65b0\u5c0e\u5411\u7db2\u5740","required":false},"redirectionType":{"type":"string","default":"301","description":"\u91cd\u65b0\u5c0e\u5411\u985e\u578b","enum":["301","302","307","410","451"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/updateRedirection"}]}},"\/rankmath\/v1\/updateMeta":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectType":{"type":"string","description":"\u7269\u4ef6\u985e\u578b\uff0c\u4f8b\u5982\u6587\u7ae0\u3001\u8a5e\u5f59\u3001\u4f7f\u7528\u8005","required":true},"objectID":{"type":"integer","description":"\u7269\u4ef6\u552f\u4e00 ID","required":true},"meta":{"description":"\u8981\u65b0\u589e\u6216\u66f4\u65b0\u8cc7\u6599\u7684\u4e2d\u7e7c\u8cc7\u6599\u3002","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/updateMeta"}]}},"\/rankmath\/v1\/updateSchemas":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectType":{"type":"string","description":"\u7269\u4ef6\u985e\u578b\uff0c\u4f8b\u5982\u6587\u7ae0\u3001\u8a5e\u5f59\u3001\u4f7f\u7528\u8005","required":true},"objectID":{"type":"integer","description":"\u7269\u4ef6\u552f\u4e00 ID","required":true},"schemas":{"description":"\u7528\u65bc\u65b0\u589e\u6216\u66f4\u65b0\u8cc7\u6599\u7684 Schema\u3002","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/updateSchemas"}]}},"\/rankmath\/v1\/updateMetaBulk":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"rows":{"description":"\u9078\u53d6\u8981\u66f4\u65b0\u8cc7\u6599\u7684\u6587\u7ae0\u3002","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/updateMetaBulk"}]}},"\/rankmath\/v1\/setupWizard":{"namespace":"rankmath\/v1\/setupWizard","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/setupWizard","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/setupWizard"}]}},"\/rankmath\/v1\/setupWizard\/getStepData":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step":{"type":"string","description":"\u76ee\u524d\u6b65\u9a5f","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/setupWizard\/getStepData"}]}},"\/rankmath\/v1\/setupWizard\/updateStepData":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step":{"type":"string","description":"\u76ee\u524d\u6b65\u9a5f","required":true},"value":{"type":"object","description":"\u76ee\u524d\u6b65\u9a5f\u8cc7\u6599","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/setupWizard\/updateStepData"}]}},"\/rankmath\/v1\/setupWizard\/updateTrackingOptin":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"enable_tracking":{"type":"string","description":"\u555f\u7528\u8ffd\u8e64","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/setupWizard\/updateTrackingOptin"}]}},"\/rankmath\/v1\/saveTemplate":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postId":{"type":"integer","description":"Post ID.","required":false},"schema":{"type":"object","description":"Schema data.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/saveTemplate"}]}},"\/rankmath\/v1\/getVideoData":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectID":{"type":"integer","description":"Object unique id","required":true},"url":{"description":"Video URL.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/getVideoData"}]}},"\/rankmath\/v1\/an":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/an","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an"}]}},"\/rankmath\/v1\/an\/getKeywordPages":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"query":{"description":"Query to search.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/getKeywordPages"}]}},"\/rankmath\/v1\/an\/postsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/postsOverview"}]}},"\/rankmath\/v1\/an\/getTrackedKeywords":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/getTrackedKeywords"}]}},"\/rankmath\/v1\/an\/getTrackedKeywordsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Keyword to search.","type":"string","default":"","required":false},"orderby":{"default":"default","enum":["default","keyword"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/getTrackedKeywordsRows"}]}},"\/rankmath\/v1\/an\/getTrackedKeywordSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/getTrackedKeywordSummary"}]}},"\/rankmath\/v1\/an\/trackedKeywordsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/trackedKeywordsOverview"}]}},"\/rankmath\/v1\/an\/addTrackKeyword":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"keyword":{"description":"Keyword to add.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/addTrackKeyword"}]}},"\/rankmath\/v1\/an\/autoAddFocusKeywords":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"data":{"description":"Data to add.","type":"object","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/autoAddFocusKeywords"}]}},"\/rankmath\/v1\/an\/removeTrackKeyword":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc","ASC","DESC"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/removeTrackKeyword"}]}},"\/rankmath\/v1\/an\/deleteTrackedKeywords":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/deleteTrackedKeywords"}]}},"\/rankmath\/v1\/an\/getDesktopPagespeed":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"id":{"description":"Record id.","type":"integer","default":0,"required":false},"objectID":{"description":"Post id.","type":"integer","default":0,"required":false},"force":{"description":"Force update pagespeed.","type":"boolean","default":false,"required":false},"isAdminBar":{"description":"Is admin bar.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/getDesktopPagespeed"}]}},"\/rankmath\/v1\/an\/getMobilePagespeed":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"id":{"description":"Record id.","type":"integer","default":0,"required":false},"objectID":{"description":"Post id.","type":"integer","default":0,"required":false},"force":{"description":"Force update pagespeed.","type":"boolean","default":false,"required":false},"isAdminBar":{"description":"Is admin bar.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/getMobilePagespeed"}]}},"\/rankmath\/v1\/an\/getPageSEOScore":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"id":{"description":"Record id.","type":"integer","default":0,"required":false},"objectID":{"description":"Post id.","type":"integer","default":0,"required":false},"force":{"description":"Force update pagespeed.","type":"boolean","default":false,"required":false},"isAdminBar":{"description":"Is admin bar.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/getPageSEOScore"}]}},"\/rankmath\/v1\/an\/postsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/postsRows"}]}},"\/rankmath\/v1\/an\/inspectionStats":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/inspectionStats"}]}},"\/rankmath\/v1\/pingSettings":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"apiKey":{"description":"API Key.","type":"string","required":true},"username":{"description":"Username.","type":"string","required":true},"plan":{"description":"Plan.","type":"string","required":true},"keywords":{"description":"Keywords.","type":"string","required":true},"settings":{"description":"Settings.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/pingSettings"}]}},"\/rankmath\/v1\/searchIntent":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"The keyword used to determine the intent.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/searchIntent"}]}},"\/rankmath\/v1\/importCSV":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/importCSV"}]}},"\/rankmath\/v1\/cancelCsvImport":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/cancelCsvImport"}]}},"\/wp-super-cache\/v1":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-super-cache\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-super-cache\/v1"}]}},"\/wp-super-cache\/v1\/settings":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-super-cache\/v1\/settings"}]}},"\/wp-super-cache\/v1\/status":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-super-cache\/v1\/status"}]}},"\/wp-super-cache\/v1\/stats":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-super-cache\/v1\/stats"}]}},"\/wp-super-cache\/v1\/cache":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-super-cache\/v1\/cache"}]}},"\/wp-super-cache\/v1\/preload":{"namespace":"wp-super-cache\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-super-cache\/v1\/preload"}]}},"\/wp-super-cache\/v1\/cache\/test":{"namespace":"wp-super-cache\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-super-cache\/v1\/cache\/test"}]}},"\/wp-super-cache\/v1\/plugins":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-super-cache\/v1\/plugins"}]}},"\/wpml\/st\/v1":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/st\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/st\/v1"}]}},"\/wpml\/st\/v1\/strings\/settings":{"namespace":"wpml\/st\/v1","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"autoregisterType":{"type":"integer","default":0,"required":false},"shouldRegisterBackendStrings":{"type":"integer","default":0,"required":false},"setNoticeThatCachePluginCanBlockAutoregisterAsDismissed":{"type":"integer","default":0,"required":false},"setDetectStringsInJS":{"type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/st\/v1\/strings\/settings"}]}},"\/wpml\/st\/v1\/strings\/itemscount":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/st\/v1\/strings\/itemscount"}]}},"\/wpml\/st\/v1\/strings":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/st\/v1\/strings"}]}},"\/wpml\/st\/v1\/strings\/filters":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/st\/v1\/strings\/filters"}]}},"\/wpml\/st\/v1\/string-packages":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/st\/v1\/string-packages"}]}},"\/wpml\/st\/v1\/strings\/processstringsqueue":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/st\/v1\/strings\/processstringsqueue"}]}},"\/wpml\/tm\/v1":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/tm\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/store":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_job_id":{"type":"string","required":true},"ate_job_data":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/store"}]}},"\/wpml\/tm\/v1\/xliff\/fetch\/(?P<jobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/ams\/register_manager":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ams\/register_manager"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/translators":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/translators"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/managers":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/managers"}]}},"\/wpml\/tm\/v1\/ams\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ams\/status"}]}},"\/wpml\/tm\/v1\/ams\/console":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ams\/console"}]}},"\/wpml\/tm\/v1\/ams\/engines":{"namespace":"wpml\/tm\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ams\/engines"}]}},"\/wpml\/tm\/v1\/ate\/jobs":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ate\/jobs"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/jobs":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"local_job_ids":{"type":"string","required":false},"scope":{"type":"string","required":false},"id":{"type":"integer","required":false},"title":{"type":"string","required":false},"source_language":{"type":"string","required":false},"target_language":{"type":"string","required":false},"status":{"type":"string","required":false},"needs_update":{"type":"string","required":false},"limit":{"type":"integer","required":false},"offset":{"type":"integer","required":false},"sorting":{"required":false},"translated_by":{"type":"string","required":false},"sent_from":{"type":"string","required":false},"sent_to":{"type":"string","required":false},"deadline_from":{"type":"string","required":false},"deadline_to":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/jobs"}]}},"\/wpml\/tm\/v1\/jobs\/assign":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"jobId":{"required":true},"type":{"required":false},"translatorId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/jobs\/assign"}]}},"\/wpml\/tm\/v1\/jobs\/cancel":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/jobs\/cancel"}]}},"\/wpml\/tm\/v1\/tp\/xliff\/download\/(?P<job_id>\\d+)\/(?P<job_type>\\w+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"job_id":{"required":true},"job_type":{"required":true},"json":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/tp\/apply-translations":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/tp\/apply-translations"}]}},"\/wpml\/tm\/v1\/tp\/batches\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batchId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/tp\/batches\/sync"}]}},"\/wpml\/tm\/v1\/tp\/batches\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/tp\/batches\/status"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"lockKey":{"type":"string","required":false},"ateToken":{"type":"string","required":false},"page":{"type":"int","required":false},"numberOfPages":{"type":"int","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/sync"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/download":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/download"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/retry":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/retry"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/receive\/(?P<wpmlJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpmlJobId":{"type":"int","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)\/fix":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/ate\/v1":{"namespace":"wpml\/ate\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/ate\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/ate\/v1"}]}},"\/wpml\/ate\/v1\/ate\/proxy":{"namespace":"wpml\/ate\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/ate\/v1\/ate\/proxy"}]}},"\/wpml\/st\/v1\/import_mo_strings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"type":"array","required":false},"themes":{"type":"array","required":false},"other":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/st\/v1\/import_mo_strings"}]}},"\/wpml\/st\/v1\/pre_generate_mo_files":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/st\/v1\/pre_generate_mo_files"}]}},"\/wpml\/st\/v1\/settings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"group":{"required":true},"key":{"required":true},"data":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/st\/v1\/settings"}]}},"\/wpml\/v1\/updates":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/updates"}]}},"\/wpml\/v1\/troubleshooting\/posthog":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/troubleshooting\/posthog"}]}},"\/wpml\/v1\/troubleshooting\/enable-alias-domain":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/troubleshooting\/enable-alias-domain"}]}},"\/wpml\/v1\/troubleshooting\/reset-alias-domain":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/troubleshooting\/reset-alias-domain"}]}},"\/wpml\/v1\/item-sections\/populated":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/item-sections\/populated"}]}},"\/wpml\/v1\/posts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/posts"}]}},"\/wpml\/v1\/posts\/count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/posts\/count"}]}},"\/wpml\/v1\/send-to-translation\/validate-translation-options":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/send-to-translation\/validate-translation-options"}]}},"\/wpml\/v1\/send-to-translation\/default-batch-name":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/send-to-translation\/default-batch-name"}]}},"\/wpml\/v1\/send-to-translation\/validate-batch-name":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/send-to-translation\/validate-batch-name"}]}},"\/wpml\/v1\/set-review-translation-option":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/set-review-translation-option"}]}},"\/wpml\/v1\/posts\/hierarchical":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/posts\/hierarchical"}]}},"\/wpml\/v1\/posts\/taxonomies":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/posts\/taxonomies"}]}},"\/wpml\/v1\/posts\/terms":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/posts\/terms"}]}},"\/wpml\/v1\/translate-everything\/enable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/translate-everything\/enable"}]}},"\/wpml\/v1\/translate-everything\/disable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/translate-everything\/disable"}]}},"\/wpml\/v1\/cancelallautomaticjobs":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/cancelallautomaticjobs"}]}},"\/wpml\/v1\/getuntranslatedtypescount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/getuntranslatedtypescount"}]}},"\/wpml\/v1\/save-translator-note":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/save-translator-note"}]}},"\/wpml\/v1\/credits":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/credits"}]}},"\/wpml\/v1\/translation-proxy\/commit-batch":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/translation-proxy\/commit-batch"}]}},"\/wpml\/v1\/tranlsation-proxy\/getlastpickedup":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/tranlsation-proxy\/getlastpickedup"}]}},"\/wpml\/v1\/translation-proxy\/getRemoteJobsCount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/translation-proxy\/getRemoteJobsCount"}]}},"\/wpml\/v1\/gettranslationstatus":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/gettranslationstatus"}]}},"\/wpml\/v1\/getlocaltranslatorbyid":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/getlocaltranslatorbyid"}]}},"\/wpml\/v1\/reloadremotetranslationservice":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/reloadremotetranslationservice"}]}},"\/wpml\/v1\/gettranslationeditortype":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/gettranslationeditortype"}]}},"\/wpml\/v1\/translate-existing-content":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/translate-existing-content"}]}},"\/wpml\/v1\/get-needs-update-count-created-in-cte":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/get-needs-update-count-created-in-cte"}]}},"\/wpml\/v1\/get-engines":{"namespace":"wpml\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/get-engines"}]}},"\/wpml\/v1\/website-contexts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/website-contexts"}]}},"\/wpml\/v1\/has-posts-using-native-editor":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/has-posts-using-native-editor"}]}},"\/wpml\/v1\/get-credits-per-word":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/get-credits-per-word"}]}},"\/wpml\/v1\/get-words-to-translate-for-items":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/get-words-to-translate-for-items"}]}},"\/wpml\/v1\/get-words-to-translate-for-types":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/get-words-to-translate-for-types"}]}},"\/wpml\/v1\/save-automatic-translation-settings":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/save-automatic-translation-settings"}]}},"\/wpml\/v1\/getlocaltranslators":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/getlocaltranslators"}]}},"\/wpml\/v1\/account-balances":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/account-balances"}]}},"\/wpml\/v1\/glossary-count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/glossary-count"}]}},"\/wpml\/v1\/enable-ate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/enable-ate"}]}},"\/wpml\/v1\/get-dismissed-notices":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/get-dismissed-notices"}]}},"\/wpml\/v1\/minimum-requirements":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/minimum-requirements"}]}},"\/wpml\/v1\/rest\/status":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/rest\/status"}]}},"\/wpml\/v1\/dismiss-notice":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/dismiss-notice"}]}},"\/wpml\/v1\/dismiss-notice-per-user":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/dismiss-notice-per-user"}]}},"\/wpml\/v1\/cancel-jobs":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/cancel-jobs"}]}},"\/wpml\/v1\/unsolvable-jobs":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/unsolvable-jobs"}]}},"\/wpml\/v1\/resend-unsolvable-jobs":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/resend-unsolvable-jobs"}]}},"\/wpml\/v1\/wpml\/posthog\/capture-event":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/wpml\/posthog\/capture-event"}]}},"\/wpml\/v1\/capture\/event":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/capture\/event"}]}},"\/wpml\/v1\/wpml-proxy\/status":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/wpml-proxy\/status"}]}},"\/wpml\/v1\/wpml-content-stats":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/wpml-content-stats"}]}},"\/wpml\/v1\/wpml-ph-make-external-request":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpml\/v1\/wpml-ph-make-external-request"}]}},"\/wp-smush\/v1":{"namespace":"wp-smush\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-smush\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-smush\/v1"}]}},"\/wp-smush\/v1\/preset_configs":{"namespace":"wp-smush\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-smush\/v1\/preset_configs"}]}},"\/hub-connector\/v1":{"namespace":"hub-connector\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"hub-connector\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/hub-connector\/v1"}]}},"\/hub-connector\/v1\/sync":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"force":{"description":"Should do a force sync.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/hub-connector\/v1\/sync"}]}},"\/hub-connector\/v1\/logout":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/hub-connector\/v1\/logout"}]}},"\/rankmath\/v1\/ai-visibility":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/ai-visibility","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ai-visibility"}]}},"\/rankmath\/v1\/ai-visibility\/overview":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"refresh":{"description":"\u5f37\u5236\u5f9e AI Visibility API \u91cd\u65b0\u6574\u7406\u3002","type":"boolean","default":false,"required":false},"search":{"description":"\u4f9d\u540d\u7a31\u6216\u7db2\u5740\u7be9\u9078\u54c1\u724c\u3002","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ai-visibility\/overview"}]}},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u54c1\u724c UUID\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u54c1\u724c UUID\u3002","type":"string","required":true},"name":{"type":"string","required":false},"url":{"type":"string","required":false},"description":{"type":"string","required":false},"locale":{"type":"string","required":false},"language":{"type":"string","enum":["","US English","UK English","Arabic","Bulgarian","Chinese","Czech","Danish","Dutch","Estonian","Finnish","French","German","Greek","Hebrew","Hungarian","Indonesian","Italian","Japanese","Korean","Latvian","Lithuanian","Norwegian","Polish","Portuguese","Romanian","Russian","Slovak","Slovenian","Spanish","Swedish","Turkish"],"required":false},"status":{"type":"string","enum":["active","inactive"],"required":false},"interval":{"type":"string","enum":["daily","weekly","monthly"],"required":false},"platforms":{"description":"\u6b64\u54c1\u724c\u8981\u8ffd\u8e64\u7684 AI \u5e73\u53f0\u3002\u652f\u63f4\u7684\u503c\uff1a\"chatgpt\", \"gemini\"\u3002\u6bcf\u500b\u54c1\u724c\u8ffd\u8e64\u591a\u500b\u5e73\u53f0\u9700\u8981 Expert \u65b9\u6848\u3002","type":"array","minItems":1,"items":{"type":"string","enum":["chatgpt","gemini"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"name":{"description":"\u54c1\u724c\u540d\u7a31\u3002","type":"string","required":true},"url":{"description":"\u54c1\u724c\u7db2\u7ad9\u7db2\u5740\u6216\u7db2\u57df\u3002","type":"string","required":true},"description":{"description":"\u54c1\u724c\u6216\u7522\u54c1\u7684\u7c21\u77ed\u8aaa\u660e\u3002","type":"string","required":true},"locale":{"description":"ISO 3166-1 alpha-2 \u570b\u5bb6\/\u5730\u5340\u4ee3\u78bc (\u4f8b\u5982 &quot;US&quot;\u3001&quot;HU&quot;)\u3002","type":"string","required":false},"language":{"description":"\u70ba\u6b64\u54c1\u724c\u5206\u6790\uff0f\u7522\u751f\u5167\u5bb9\u6642\u4f7f\u7528\u7684\u8f38\u51fa\u8a9e\u8a00\u3002\u7368\u7acb\u65bc `locale`\uff08\u76ee\u6a19\u570b\u5bb6\/\u5730\u5340\uff09\u3002\u5fc5\u586b\uff1b\u5efa\u7acb\u5f8c\u7121\u6cd5\u8b8a\u66f4\u3002","type":"string","enum":["US English","UK English","Arabic","Bulgarian","Chinese","Czech","Danish","Dutch","Estonian","Finnish","French","German","Greek","Hebrew","Hungarian","Indonesian","Italian","Japanese","Korean","Latvian","Lithuanian","Norwegian","Polish","Portuguese","Romanian","Russian","Slovak","Slovenian","Spanish","Swedish","Turkish"],"required":true},"interval":{"description":"\u5206\u6790\u91cd\u65b0\u6574\u7406\u983b\u7387\u3002\u82e5\u7701\u7565 \u2192 \u5f8c\u7aef\u5c07\u5957\u7528\u5e33\u865f\u65b9\u6848\u7684\u9810\u8a2d\u503c\u3002","type":"string","enum":["daily","weekly","monthly"],"required":false},"platforms":{"description":"\u6b64\u54c1\u724c\u8981\u8ffd\u8e64\u7684 AI \u5e73\u53f0\u3002\u652f\u63f4\u7684\u503c\uff1a\"chatgpt\", \"gemini\"\u3002\u6bcf\u500b\u54c1\u724c\u8ffd\u8e64\u591a\u500b\u5e73\u53f0\u9700\u8981 Expert \u65b9\u6848\u3002","type":"array","minItems":1,"items":{"type":"string","enum":["chatgpt","gemini"]},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ai-visibility\/brands"}]}},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/insights":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u54c1\u724c UUID\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/queries":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u54c1\u724c UUID\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/queries\/(?P<qid>[a-zA-Z0-9\\-]+)":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u54c1\u724c UUID\u3002","type":"string","required":true},"qid":{"description":"\u67e5\u8a62 UUID\u3002","type":"string","required":true},"enabled":{"description":"\u67e5\u8a62\u662f\u5426\u5df2\u555f\u7528\u9032\u884c\u5206\u6790\u3002","type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/generate-queries":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u54c1\u724c UUID\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/trial\/activate":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ai-visibility\/trial\/activate"}]}},"\/rankmath\/v1\/ai-visibility\/checkout-url":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ai-visibility\/checkout-url"}]}},"\/rankmath\/v1\/ca":{"namespace":"rankmath\/v1\/ca","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/ca","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca"}]}},"\/rankmath\/v1\/ca\/researchKeyword":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"\u8981\u7814\u7a76\u7684\u95dc\u9375\u5b57\u3002","type":"string","required":true},"country":{"description":"\u8981\u7814\u7a76\u95dc\u9375\u5b57\u7684\u570b\u5bb6\/\u5730\u5340\u3002","type":"string","required":true},"objectID":{"description":"\u767c\u8d77\u95dc\u9375\u5b57\u7814\u7a76\u8acb\u6c42\u7684\u6587\u7ae0 ID\u3002","type":"integer","required":true},"force_update":{"description":"\u82e5\u70ba true\uff0c\u5c07\u5f37\u5236\u91cd\u65b0\u767c\u9001\u7814\u7a76\u8acb\u6c42\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/researchKeyword"}]}},"\/rankmath\/v1\/ca\/getCredits":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/getCredits"}]}},"\/rankmath\/v1\/ca\/createPost":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"content":{"description":"\u65b0\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"string","required":true},"title":{"description":"\u65b0\u6587\u7ae0\u6a19\u984c\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/createPost"}]}},"\/rankmath\/v1\/ca\/saveOutput":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"outputs":{"description":"\u8981\u5132\u5b58\u7684 AI \u7522\u51fa\u8207\u65e2\u6709\u8f38\u51fa\u7684\u9663\u5217\u3002","type":"array","required":false},"endpoint":{"description":"\u7522\u751f\u8f38\u51fa\u5167\u5bb9\u7684 API \u7aef\u9ede\u3002","type":"string","required":false},"isChat":{"description":"\u6307\u51fa\u8a72\u8acb\u6c42\u662f\u5426\u91dd\u5c0d Chat \u7aef\u9ede\u3002","type":"boolean","required":false},"attributes":{"description":"\u7528\u65bc\u7522\u751f AI \u8f38\u51fa\u7684\u53c3\u6578\u3002","type":"object","required":false},"credits":{"description":"API \u50b3\u56de\u7684\u9ede\u6578\u4f7f\u7528\u8a73\u7d30\u8cc7\u6599\u3002","type":"object","required":false},"usage":{"description":"API \u50b3\u56de\u7684\u5404\u5de5\u5177\u4f7f\u7528\u8cc7\u6599\u3002","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/saveOutput"}]}},"\/rankmath\/v1\/ca\/deleteOutput":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"isChat":{"description":"\u6307\u51fa\u522a\u9664\u8f38\u51fa\u5167\u5bb9\u7684\u8acb\u6c42\u662f\u5426\u91dd\u5c0d Chat \u7aef\u9ede\u3002","type":"boolean","required":false},"index":{"description":"\u8981\u522a\u9664\u7684\u8f38\u51fa\u7d22\u5f15\uff0c\u50c5\u9069\u7528\u65bc Chat \u7aef\u9ede\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/deleteOutput"}]}},"\/rankmath\/v1\/ca\/updateRecentPrompt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompt":{"description":"\u8981\u5728\u6700\u8fd1\u63d0\u793a\u4e2d\u66f4\u65b0\u7684\u9078\u53d6\u63d0\u793a\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/updateRecentPrompt"}]}},"\/rankmath\/v1\/ca\/updatePrompt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompt":{"description":"\u8981\u5132\u5b58\u81f3\u8cc7\u6599\u5eab\u7684\u63d0\u793a\u8cc7\u6599\u3002","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/updatePrompt"}]}},"\/rankmath\/v1\/ca\/savePrompts":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompts":{"description":"\u5f9e API \u6536\u5230\u4e26\u8981\u5132\u5b58\u5230\u8cc7\u6599\u5eab\u7684\u63d0\u793a\u6e05\u55ae\u3002","type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/savePrompts"}]}},"\/rankmath\/v1\/ca\/pingContentAI":{"namespace":"rankmath\/v1\/ca","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"plan":{"description":"\u8981\u66f4\u65b0\u81f3\u8cc7\u6599\u5eab\u7684 Rank Math AI \u65b9\u6848\u3002","type":"string","required":true},"refreshDate":{"description":"\u8981\u66f4\u65b0\u81f3\u8cc7\u6599\u5eab\u7684 Content AI \u91cd\u8a2d\u65e5\u671f","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/pingContentAI"}]}},"\/rankmath\/v1\/ca\/generateAlt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"attachmentIds":{"description":"\u8981\u7522\u751f\u66ff\u4ee3\u6587\u5b57\u7684\u9644\u4ef6 ID \u6e05\u55ae\u3002","type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/generateAlt"}]}},"\/rankmath\/v1\/ca\/updateCredits":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"credits":{"description":"API \u50b3\u56de\u7684\u9ede\u6578\u4f7f\u7528\u8a73\u7d30\u8cc7\u6599\u3002","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/ca\/updateCredits"}]}},"\/rankmath\/v1\/an\/dashboard":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/dashboard"}]}},"\/rankmath\/v1\/an\/keywordsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/keywordsOverview"}]}},"\/rankmath\/v1\/an\/postsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/postsSummary"}]}},"\/rankmath\/v1\/an\/postsRowsByObjects":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"\u9801\u78bc\u3002","type":"integer","required":false},"per_page":{"description":"\u6bcf\u9801\u7d50\u679c\u6578\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/postsRowsByObjects"}]}},"\/rankmath\/v1\/an\/post\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u6587\u7ae0 ID\u3002","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/an\/keywordsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/keywordsSummary"}]}},"\/rankmath\/v1\/an\/analyticsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"postType":{"description":"\u6587\u7ae0\u985e\u578b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/analyticsSummary"}]}},"\/rankmath\/v1\/an\/keywordsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"\u9801\u78bc\u3002","type":"integer","required":false},"perPage":{"description":"\u6bcf\u9801\u7d50\u679c\u6578\u3002","type":"integer","required":false},"orderBy":{"description":"\u6392\u5e8f\u4f9d\u64da\u3002","type":"string","required":false},"order":{"description":"\u6392\u5e8f\u3002","type":"string","required":false},"search":{"description":"\u641c\u5c0b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/keywordsRows"}]}},"\/rankmath\/v1\/an\/userPreferences":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"preferences":{"description":"\u4f7f\u7528\u8005\u504f\u597d\u8a2d\u5b9a\u3002","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/userPreferences"}]}},"\/rankmath\/v1\/an\/inspectionResults":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"\u9801\u78bc\u3002","type":"integer","required":false},"perPage":{"description":"\u6bcf\u9801\u7d50\u679c\u6578\u3002","type":"integer","required":false},"orderBy":{"description":"\u6392\u5e8f\u4f9d\u64da\u3002","type":"string","required":false},"order":{"description":"\u6392\u5e8f\u3002","type":"string","required":false},"search":{"description":"\u641c\u5c0b\u3002","type":"string","required":false},"filter":{"description":"\u7be9\u9078\u3002","type":"string","required":false},"filterType":{"description":"\u7be9\u9078\u985e\u578b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/inspectionResults"}]}},"\/rankmath\/v1\/an\/removeFrontendStats":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"toggleBar":{"description":"\u5207\u63db\u5217\u3002","type":"boolean","required":false},"hide":{"description":"\u96b1\u85cf\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/an\/removeFrontendStats"}]}},"\/rankmath\/v1\/in":{"namespace":"rankmath\/v1\/in","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/in","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/in"}]}},"\/rankmath\/v1\/in\/submitUrls":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"urls":{"description":"\u8981\u63d0\u4ea4\u5230 Instant Indexing API \u7684\u7db2\u5740\u6e05\u55ae\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/in\/submitUrls"}]}},"\/rankmath\/v1\/in\/getLog":{"namespace":"rankmath\/v1\/in","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filter":{"description":"\u4f9d\u985e\u578b\u7be9\u9078\u8a18\u9304\u3002","type":"string","enum":["all","manual","auto"],"default":"all","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/in\/getLog"}]}},"\/rankmath\/v1\/in\/clearLog":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filter":{"description":"\u4f9d\u985e\u578b\u6e05\u9664\u8a18\u9304\u3002","type":"string","enum":["all","manual","auto"],"default":"all","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/in\/clearLog"}]}},"\/rankmath\/v1\/in\/resetKey":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/in\/resetKey"}]}},"\/rankmath\/v1\/links\/posts":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"\u9801\u78bc\u3002","type":"integer","default":1,"required":false},"per_page":{"description":"\u6bcf\u9801\u9805\u76ee\u6578\u3002","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"\u5728\u6587\u7ae0\u6a19\u984c\u4e2d\u641c\u5c0b\u3002","type":"string","default":"","required":false},"post_type":{"description":"\u4f9d\u6587\u7ae0\u985e\u578b\u7be9\u9078\u3002\u652f\u63f4\u591a\u500b\u503c\u3002","type":"array","items":{"type":"string"},"default":[],"required":false},"is_orphan":{"description":"\u4f9d\u5b64\u5152\u72c0\u614b\u7be9\u9078 (\u5b64\u5152\u3001\u5df2\u9023\u7d50)\u3002","type":"string","default":"","required":false},"seo_score_range":{"description":"\u4f9d SEO \u5206\u6578\u7bc4\u570d\u7be9\u9078 (\u6975\u4f73\u3001\u826f\u597d\u3001\u4e0d\u826f\u3001\u7121\u5206\u6578)\u3002","type":"string","default":"","required":false},"post_id":{"description":"\u4f9d\u6587\u7ae0 ID \u7be9\u9078\u3002","type":"integer","default":0,"required":false},"orderby":{"description":"\u4f9d\u6b04\u4f4d\u6392\u5e8f\u3002","type":"string","default":"post_title","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5411 (ASC\u3001DESC)\u3002","type":"string","default":"ASC","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/links\/posts"}]}},"\/rankmath\/v1\/links\/posts-stats":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/links\/posts-stats"}]}},"\/rankmath\/v1\/links\/links":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"\u9801\u78bc\u3002","type":"integer","default":1,"required":false},"per_page":{"description":"\u6bcf\u9801\u9805\u76ee\u6578\u3002","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"\u5728\u7db2\u5740\u4e2d\u641c\u5c0b\u3002","type":"string","default":"","required":false},"source_id":{"description":"\u4f9d\u4f86\u6e90\u6587\u7ae0 ID \u7be9\u9078\u3002","type":"integer","default":0,"required":false},"target_post_id":{"description":"\u4f9d\u76ee\u6a19\u6587\u7ae0 ID \u7be9\u9078\u3002","type":"integer","default":0,"required":false},"is_internal":{"description":"\u4f9d\u9023\u7d50\u985e\u578b\u7be9\u9078 (1 = \u5167\u90e8\uff0c0 = \u5916\u90e8)\u3002","type":"string","default":"","required":false},"orderby":{"description":"\u4f9d\u6b04\u4f4d\u6392\u5e8f\u3002","type":"string","default":"id","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5411 (ASC\u3001DESC)\u3002","type":"string","default":"DESC","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/links\/links"}]}},"\/rankmath\/v1\/links\/links-stats":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/links\/links-stats"}]}},"\/rankmath\/v1\/status":{"namespace":"rankmath\/v1\/status","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/status","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/status"}]}},"\/rankmath\/v1\/status\/getViewData":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/status\/getViewData"}]}},"\/rankmath\/v1\/status\/updateViewData":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/status\/updateViewData"}]}},"\/rankmath\/v1\/status\/importSettings":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/status\/importSettings"}]}},"\/rankmath\/v1\/status\/exportSettings":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/status\/exportSettings"}]}},"\/rankmath\/v1\/status\/runBackup":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/status\/runBackup"}]}},"\/rankmath\/v1\/link-genius":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/link-genius","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius"}]}},"\/rankmath\/v1\/link-genius\/links":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"source_id":{"description":"Filter by source post ID.","type":"integer","default":0,"required":false},"target_post_id":{"description":"Filter by target post ID.","type":"integer","default":0,"required":false},"is_internal":{"description":"Filter by link type.","type":"string","default":"","required":false},"is_nofollow":{"description":"Filter by nofollow status.","type":"string","default":"","required":false},"anchor_type":{"description":"Filter by anchor type (HPLNK, CNCL, HLANG, IMAGE).","type":"string","default":"","required":false},"target_blank":{"description":"Filter by target blank status.","type":"string","default":"","required":false},"search":{"description":"Search in anchor text or URL.","type":"string","default":"","required":false},"orderby":{"description":"Order by field.","type":"string","default":"created_at","required":false},"order":{"description":"Order direction.","type":"string","default":"DESC","required":false},"status_code":{"description":"Filter by HTTP status code (e.g., 404). Supports multiple values.","type":"array","items":{"type":"string"},"default":[],"required":false},"status_category":{"description":"Filter by status category (2xx, 3xx, 4xx, 5xx, timeout, error).","type":"string","default":"","required":false},"is_broken":{"description":"Filter broken links (4xx, 5xx, timeout, error).","type":"boolean","default":false,"required":false},"is_success":{"description":"Filter successful links (2xx).","type":"boolean","default":false,"required":false},"is_redirect":{"description":"Filter redirect links (3xx).","type":"string","default":"","required":false},"robots_blocked":{"description":"Filter links blocked by robots.txt.","type":"string","default":"","required":false},"unchecked":{"description":"Filter unchecked links (no status data).","type":"string","default":"","required":false},"is_marked_safe":{"description":"Filter links marked as safe.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/links"}]}},"\/rankmath\/v1\/link-genius\/links\/(?P<id>\\d+)\/details":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Link ID.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/delete":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_ids":{"description":"Link IDs to delete.","type":"array","required":false},"filters":{"description":"Filter criteria for selecting links to delete.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/delete"}]}},"\/rankmath\/v1\/link-genius\/undo-delete":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID to restore.","type":"integer","required":true},"original_content":{"description":"Original post content to restore.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/undo-delete"}]}},"\/rankmath\/v1\/link-genius\/remove-nofollow":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_id":{"description":"Link ID to remove nofollow from.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/remove-nofollow"}]}},"\/rankmath\/v1\/link-genius\/update":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_id":{"description":"Link ID to update.","type":"integer","required":true},"new_url":{"description":"New URL for the link.","type":"string","required":true},"new_anchor":{"description":"New anchor text for the link.","type":"string","required":true},"is_nofollow":{"description":"Whether the link should have nofollow attribute.","type":"integer","default":0,"required":false},"target_blank":{"description":"Whether the link should open in a new tab.","type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/update"}]}},"\/rankmath\/v1\/link-genius\/bulk-actions\/restore":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batch_id":{"description":"Batch ID to restore from snapshots.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/bulk-actions\/restore"}]}},"\/rankmath\/v1\/link-genius\/link-suggestions":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID.","type":"integer","required":true},"text":{"description":"Selected text used for suggestions.","type":"string","required":false},"current":{"description":"Current editor state summary.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/link-suggestions"}]}},"\/rankmath\/v1\/link-genius\/link-opportunities":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID.","type":"integer","required":true},"current":{"description":"Current editor state summary.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/link-opportunities"}]}},"\/rankmath\/v1\/link-genius\/related-posts":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID.","type":"integer","required":true},"current":{"description":"Current editor state summary.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/related-posts"}]}},"\/rankmath\/v1\/link-genius\/audit\/stats":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/audit\/stats"}]}},"\/rankmath\/v1\/link-genius\/audit\/start":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filters":{"description":"Filters to apply (is_internal, unchecked_only, etc.).","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/audit\/start"}]}},"\/rankmath\/v1\/link-genius\/audit\/recheck":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_ids":{"description":"Array of link IDs to recheck.","type":"array","required":false},"filters":{"description":"Filter criteria for selecting links to recheck.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/audit\/recheck"}]}},"\/rankmath\/v1\/link-genius\/audit\/mark-safe":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_ids":{"description":"Link IDs to mark as safe.","type":"array","required":false},"reason":{"description":"Reason for marking as safe.","type":"string","required":false},"filters":{"description":"Filter criteria for selecting links to mark as safe.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/audit\/mark-safe"}]}},"\/rankmath\/v1\/link-genius\/export":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"description":"Export type (links or posts).","type":"string","required":true},"format":{"description":"Export format (csv, json, excel).","type":"string","required":true},"filters":{"description":"Filters to apply to the export.","type":"object","required":false},"columns":{"description":"Column definitions.","type":"array","required":true},"total":{"description":"Total number of records to export.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/export"}]}},"\/rankmath\/v1\/link-genius\/posts":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"Search in post title.","type":"string","default":"","required":false},"post_type":{"description":"Filter by post type. Supports multiple values.","type":"array","items":{"type":"string"},"default":[],"required":false},"is_orphan":{"description":"Filter by orphan status.","type":"string","default":"","required":false},"seo_score_range":{"description":"Filter by SEO score range.","type":"string","default":"","required":false},"orderby":{"description":"Order by field.","type":"string","default":"post_title","required":false},"order":{"description":"Order direction.","type":"string","default":"ASC","required":false},"min_incoming_links":{"description":"Minimum incoming links count filter.","type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/posts"}]}},"\/rankmath\/v1\/link-genius\/posts-stats":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/posts-stats"}]}},"\/rankmath\/v1\/link-genius\/stats":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/stats"}]}},"\/rankmath\/v1\/link-genius\/regenerate":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/regenerate"}]}},"\/rankmath\/v1\/link-genius\/operations\/progress":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"operation":{"description":"Operation type.","type":"string","enum":["regenerate","audit","bulk_delete","bulk_mark_safe","bulk_restore","bulk_update_preview","bulk_update_apply","keyword_map_preview","keyword_map_apply","export"],"required":true},"id":{"description":"Optional operation ID (for keyword maps).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/operations\/progress"}]}},"\/rankmath\/v1\/link-genius\/operations\/cancel":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"operation":{"description":"Operation type to cancel.","type":"string","enum":["regenerate","audit","bulk_delete","bulk_mark_safe","bulk_restore","bulk_update_preview","bulk_update_apply","keyword_map_preview","keyword_map_apply","export"],"required":true},"id":{"description":"Optional operation ID (for keyword maps).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/operations\/cancel"}]}},"\/rankmath\/v1\/link-genius\/operations\/clear":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"operation":{"description":"Operation type to clear.","type":"string","enum":["regenerate","audit","bulk_delete","bulk_mark_safe","bulk_restore","bulk_update_preview","bulk_update_apply","keyword_map_preview","keyword_map_apply","export"],"required":true},"id":{"description":"Optional operation ID (for keyword maps).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/operations\/clear"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/preview":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filters":{"description":"Search filters for finding links.","type":"object","required":true},"update_config":{"description":"Update configuration.","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/preview"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/preview\/results":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/preview\/results"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/history":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/history"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/history\/(?P<batch_id>[a-zA-Z0-9_]+)":{"namespace":"rankmath\/v1\/link-genius","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"batch_id":{"description":"Batch ID to delete.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/bulk-update\/apply":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filters":{"description":"Search filters for finding links.","type":"object","required":true},"update_config":{"description":"Update configuration.","type":"object","required":true},"selected_link_ids":{"description":"Optional array of specific link IDs to update.","type":"array","items":{"type":"integer"},"required":false},"is_rollback":{"description":"Whether this is a rollback operation (prevents history creation).","type":"boolean","default":false,"required":false},"rollback_batch_id":{"description":"Batch ID being rolled back (for status update).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/apply"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/rollback":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batch_id":{"description":"Batch ID to rollback.","type":"string","required":true},"selected_post_ids":{"description":"Optional array of specific post IDs to rollback.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/rollback"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/changes\/(?P<batch_id>[a-zA-Z0-9_]+)":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"batch_id":{"description":"Batch ID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/preview":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/preview\/results":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"keyword_map_id":{"description":"Keyword map ID.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/preview\/results"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/history":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/history"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps":{"namespace":"rankmath\/v1\/link-genius","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"orderby":{"description":"Column to order by.","type":"string","default":"created_at","enum":["id","name","created_at","updated_at","last_executed_at","execution_count"],"required":false},"order":{"description":"Order direction.","type":"string","default":"DESC","enum":["ASC","DESC"],"required":false},"enabled":{"description":"Filter by enabled status.","type":"boolean","required":false},"search":{"description":"Search term.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Keyword map name.","type":"string","required":true},"description":{"description":"Keyword map description.","type":"string","required":false},"target_url":{"description":"Target URL.","type":"string","required":true},"is_enabled":{"description":"Whether the keyword map is enabled.","type":"boolean","default":true,"required":false},"max_links_per_post":{"description":"Maximum links per post.","type":"integer","default":3,"minimum":1,"required":false},"auto_link_on_publish":{"description":"Enable auto-linking on publish.","type":"boolean","default":false,"required":false},"case_sensitive":{"description":"Enable case-sensitive keyword matching.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/link-genius","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Keyword map name.","type":"string","required":false},"description":{"description":"Keyword map description.","type":"string","required":false},"target_url":{"description":"Target URL.","type":"string","required":false},"is_enabled":{"description":"Whether the keyword map is enabled.","type":"boolean","default":true,"required":false},"max_links_per_post":{"description":"Maximum links per post.","type":"integer","default":3,"minimum":1,"required":false},"auto_link_on_publish":{"description":"Enable auto-linking on publish.","type":"boolean","default":false,"required":false},"case_sensitive":{"description":"Enable case-sensitive keyword matching.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-toggle":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"description":"Array of keyword map IDs.","type":"array","items":{"type":"integer"},"required":true},"enabled":{"description":"New enabled status.","type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-toggle"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-delete":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"description":"Array of keyword map IDs.","type":"array","items":{"type":"integer"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-delete"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/execute":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/variations":{"namespace":"rankmath\/v1\/link-genius","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"variation":{"description":"Variation text.","type":"string","required":true},"source":{"description":"Variation source.","type":"string","default":"manual","enum":["manual","ai"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/variations\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/link-genius","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/generate-variations":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/generate-variations":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"Keyword to generate variations for.","type":"string","required":true},"context":{"description":"Optional context to help generate better variations.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/generate-variations"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/accept-variations":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"variations":{"description":"Array of variations to accept.","type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"google-site-kit\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1"}]}},"\/google-site-kit\/v1\/core\/site\/data\/setup-tag":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/setup-tag"}]}},"\/google-site-kit\/v1\/core\/site\/data\/connection":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/connection"}]}},"\/google-site-kit\/v1\/core\/user\/data\/authentication":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/authentication"}]}},"\/google-site-kit\/v1\/core\/user\/data\/disconnect":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/disconnect"}]}},"\/google-site-kit\/v1\/core\/user\/data\/get-token":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/get-token"}]}},"\/google-site-kit\/v1\/core\/user\/data\/user-input-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"questions":{"purpose":{"type":"array","items":{"type":"string"}},"postFrequency":{"type":"array","items":{"type":"string"}},"goals":{"type":"array","items":{"type":"string"}},"includeConversionEvents":{"type":"array","items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/user-input-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/audience-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"configuredAudiences":{"type":"array","items":{"type":"string"}},"isAudienceSegmentationWidgetHidden":{"type":"boolean"},"didSetAudiences":{"type":"boolean"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/audience-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"newEventsCalloutDismissedAt":{"type":"integer"},"lostEventsCalloutDismissedAt":{"type":"integer"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/list":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/list"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/activation":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/activation"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/info"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/check-access":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/check-access"}]}},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"data":{"type":"object","description":"Settings to set.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/data-available":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/(?P<datapoint>[a-z\\-]+)":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"datapoint":{"type":"string","description":"Module data point to address.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"datapoint":{"type":"string","description":"Module data point to address.","default":null,"required":false},"data":{"type":"object","description":"Data to set.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/core\/modules\/data\/recover-modules":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/recover-modules"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-items":{"namespace":"google-site-kit\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"data":{"type":"object","description":"","default":null,"minProperties":1,"additionalProperties":false,"properties":{"slugs":{"type":"array","required":true,"items":{"type":"string"}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-item":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-item"}]}},"\/google-site-kit\/v1\/core\/user\/data\/expirable-items":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/expirable-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","description":"","default":null,"items":{"type":"object","additionalProperties":false,"properties":{"slug":{"type":"string","required":true},"expiration":{"type":"integer","required":true}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers"}]}},"\/google-site-kit\/v1\/core\/user\/data\/permissions":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/permissions"}]}},"\/google-site-kit\/v1\/core\/user\/data\/nonces":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/nonces"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-trigger":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"triggerID":{"type":"string","required":true},"ttl":{"type":"integer","minimum":0}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-trigger"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-event":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"session":{"type":"object","required":true,"properties":{"session_id":{"type":"string","required":true},"session_token":{"type":"string","required":true}}},"event":{"type":"object","required":true,"properties":{"survey_shown":{"type":"object"},"survey_closed":{"type":"object"},"question_answered":{"type":"object"},"completion_shown":{"type":"object"},"follow_up_link_clicked":{"type":"object"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-event"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset-persistent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset-persistent"}]}},"\/google-site-kit\/v1\/core\/site\/data\/developer-plugin":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/developer-plugin"}]}},"\/google-site-kit\/v1\/core\/user\/data\/tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":true}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/tracking"}]}},"\/google-site-kit\/v1\/core\/search\/data\/entity-search":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"query":{"type":"string","description":"Text content to search for.","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/search\/data\/entity-search"}]}},"\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":false}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings"}]}},"\/google-site-kit\/v1\/core\/site\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/notifications"}]}},"\/google-site-kit\/v1\/core\/site\/data\/mark-notification":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/mark-notification"}]}},"\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test"}]}},"\/google-site-kit\/v1\/core\/site\/data\/health-checks":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/health-checks"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour"}]}},"\/google-site-kit\/v1\/core\/user\/data\/key-metrics":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"isWidgetHidden":{"type":"boolean","required":true},"widgetSlugs":{"type":"array","required":false,"maxItems":8,"items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/key-metrics"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-mode":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean"},"regions":{"type":"array","items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-mode"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-info"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate"}]}},"\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status"}]}},"\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking"}]}},"\/wpmudev_pcs\/v1":{"namespace":"wpmudev_pcs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpmudev_pcs\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpmudev_pcs\/v1"}]}},"\/wpmudev_pcs\/v1\/plugincrosssell\/install_plugin":{"namespace":"wpmudev_pcs\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpmudev_pcs\/v1\/plugincrosssell\/install_plugin"}]}},"\/wpmudev_pcs\/v1\/plugincrosssell\/activate_plugin":{"namespace":"wpmudev_pcs\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpmudev_pcs\/v1\/plugincrosssell\/activate_plugin"}]}},"\/wpmudev_blc\/v1":{"namespace":"wpmudev_blc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpmudev_blc\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpmudev_blc\/v1"}]}},"\/wpmudev_blc\/v1\/avatars":{"namespace":"wpmudev_blc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpmudev_blc\/v1\/avatars"}]}},"\/wpmudev_blc\/v1\/scan":{"namespace":"wpmudev_blc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpmudev_blc\/v1\/scan"}]}},"\/wpmudev_blc\/v1\/settings":{"namespace":"wpmudev_blc\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wpmudev_blc\/v1\/settings"}]}},"\/regenerate-thumbnails\/v1":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"regenerate-thumbnails\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/regenerate-thumbnails\/v1"}]}},"\/regenerate-thumbnails\/v1\/regenerate\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"only_regenerate_missing_thumbnails":{"description":"\u78ba\u8a8d\u662f\u5426\u50c5\u7522\u751f\u7f3a\u5c11\u76ee\u524d\u5df2\u8a3b\u518a\u5c3a\u5bf8\u7684\u7e2e\u5716\u3002\u555f\u7528\u9019\u9805\u8a2d\u5b9a\u6703\u6709\u8f03\u9ad8\u7684\u57f7\u884c\u6548\u80fd\u3002","type":"boolean","default":true,"required":false},"delete_unregistered_thumbnail_files":{"description":"\u78ba\u8a8d\u662f\u5426\u522a\u9664\u4efb\u4f55\u820a\u7248\u3001\u76ee\u524d\u70ba\u70ba\u8a3b\u518a\u5c3a\u5bf8\u7684\u7e2e\u5716\u6a94\u6848\u3002","type":"boolean","default":false,"required":false},"update_usages_in_posts":{"description":"\u78ba\u8a8d\u662f\u5426\u66f4\u65b0\u4f7f\u7528\u9019\u500b\u9644\u4ef6\u7684\u6587\u7ae0\u4e2d\u7684\u5716\u7247\u6a19\u7c64\u3002","type":"boolean","default":true,"required":false},"update_usages_in_posts_post_type":{"description":"\u8a2d\u5b9a\u8981\u9032\u884c\u66f4\u65b0\u7684\u5167\u5bb9\u985e\u578b\u3002\u9810\u8a2d\u503c\u70ba\u5168\u90e8\u7684\u516c\u958b\u5167\u5bb9\u985e\u578b\u3002","type":"array","default":[],"required":false},"update_usages_in_posts_post_ids":{"description":"\u66f4\u65b0\u6307\u5b9a\u6587\u7ae0 ID \u7684\u6587\u7ae0\uff0c\u800c\u4e0d\u662f\u66f4\u65b0\u4f7f\u7528\u9019\u500b\u9644\u4ef6\u7684\u6587\u7ae0\u3002","type":"array","default":[],"required":false},"update_usages_in_posts_posts_per_loop":{"description":"\u8a2d\u5b9a\u6bcf\u500b\u8ff4\u5708\u53ef\u8655\u7406\u7684\u6587\u7ae0\u6578\u91cf\u3002\u9019\u9805\u8a2d\u5b9a\u662f\u70ba\u4e86\u63a7\u5236\u7db2\u7ad9\u4e3b\u6a5f\u8a18\u61b6\u9ad4\u4f7f\u7528\u91cf\uff0c\u6709\u53ef\u80fd\u4e0d\u9700\u8981\u8abf\u6574\u3002","type":"integer","default":10,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/regenerate-thumbnails\/v1\/attachmentinfo\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/regenerate-thumbnails\/v1\/featuredimages":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/regenerate-thumbnails\/v1\/featuredimages"}]}},"\/otgs\/installer\/v1":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"otgs\/installer\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/otgs\/installer\/v1"}]}},"\/otgs\/installer\/v1\/push\/fetch-subscription":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/otgs\/installer\/v1\/push\/fetch-subscription"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u81f3\u6307\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u6d3e\u81f3\u6307\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u89e3\u8b6f\u641c\u5c0b\u8f38\u5165\u7684\u65b9\u5f0f\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u6587\u7ae0\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u8981\u641c\u5c0b\u7684\u6b04\u4f4d\u540d\u7a31\u9663\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u4e00\u6216\u591a\u500b\u72c0\u614b\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u57fa\u65bc\u591a\u500b\u5206\u985e\u6cd5\u9593\u7684\u95dc\u4fc2\u3002","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5728 [categories] \u5206\u985e\u6cd5\u4e2d\u4f7f\u7528\u6307\u6d3e\u6307\u5b9a\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u9805\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u6e05\u55ae","description":"\u5c07\u5206\u985e\u6cd5\u8a5e\u5f59\u8207\u5217\u51fa\u7684 ID \u9032\u884c\u6bd4\u5c0d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u5206\u985e\u6cd5\u67e5\u8a62","description":"\u57f7\u884c\u9032\u968e\u5206\u985e\u6cd5\u8a5e\u5f59\u67e5\u8a62\u3002","type":"object","properties":{"terms":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"\u662f\u5426\u5728\u9650\u5236\u7d50\u679c\u96c6\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u4e2d\u5305\u542b\u5b50\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"boolean","default":false},"operator":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u9805\u76ee\u662f\u5426\u5fc5\u9808\u6307\u6d3e\u7d66\u5168\u90e8\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u9664\u4e86\u5728 [categories] \u5206\u985e\u6cd5\u4e2d\u4f7f\u7528\u6307\u6d3e\u6307\u5b9a\u5206\u985e\u6cd5\u8a5e\u5f59\u4e4b\u5916\u7684\u9805\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u6e05\u55ae","description":"\u5c07\u5206\u985e\u6cd5\u8a5e\u5f59\u8207\u5217\u51fa\u7684 ID \u9032\u884c\u6bd4\u5c0d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u5206\u985e\u6cd5\u67e5\u8a62","description":"\u57f7\u884c\u9032\u968e\u5206\u985e\u6cd5\u8a5e\u5f59\u67e5\u8a62\u3002","type":"object","properties":{"terms":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"\u662f\u5426\u5728\u9650\u5236\u7d50\u679c\u96c6\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u4e2d\u5305\u542b\u5b50\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5728 [tags] \u5206\u985e\u6cd5\u4e2d\u4f7f\u7528\u6307\u6d3e\u6307\u5b9a\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u9805\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u6e05\u55ae","description":"\u5c07\u5206\u985e\u6cd5\u8a5e\u5f59\u8207\u5217\u51fa\u7684 ID \u9032\u884c\u6bd4\u5c0d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u5206\u985e\u6cd5\u67e5\u8a62","description":"\u57f7\u884c\u9032\u968e\u5206\u985e\u6cd5\u8a5e\u5f59\u67e5\u8a62\u3002","type":"object","properties":{"terms":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u9805\u76ee\u662f\u5426\u5fc5\u9808\u6307\u6d3e\u7d66\u5168\u90e8\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u9664\u4e86\u5728 [tags] \u5206\u985e\u6cd5\u4e2d\u4f7f\u7528\u6307\u6d3e\u6307\u5b9a\u5206\u985e\u6cd5\u8a5e\u5f59\u4e4b\u5916\u7684\u9805\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u6e05\u55ae","description":"\u5c07\u5206\u985e\u6cd5\u8a5e\u5f59\u8207\u5217\u51fa\u7684 ID \u9032\u884c\u6bd4\u5c0d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u5206\u985e\u6cd5\u67e5\u8a62","description":"\u57f7\u884c\u9032\u968e\u5206\u985e\u6cd5\u8a5e\u5f59\u67e5\u8a62\u3002","type":"object","properties":{"terms":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u7f6e\u9802\u9805\u76ee\u3002","type":"boolean","required":false},"ignore_sticky":{"description":"\u662f\u5426\u5ffd\u7565\u7f6e\u9802\u6587\u7ae0\u3002","type":"boolean","default":true,"required":false},"format":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u4e00\u6216\u591a\u500b\u6307\u5b9a\u683c\u5f0f\u7684\u9805\u76ee\u3002","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u7684\u4f5c\u8005 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u6458\u8981\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7cbe\u9078\u5a92\u9ad4 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u662f\u5426\u555f\u7528\u6587\u7ae0\u7684\u7559\u8a00\u529f\u80fd\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u662f\u5426\u80fd\u901a\u77e5\u6587\u7ae0\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6587\u7ae0\u7684\u683c\u5f0f\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u662f\u5426\u61c9\u5c07\u6587\u7ae0\u7f6e\u9802\u3002","type":"boolean","required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"categories":{"description":"\u5df2\u6307\u6d3e\u81f3\u5c6c\u65bc\u3008category\u3009\u5206\u985e\u6cd5\u7684\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u5df2\u6307\u6d3e\u81f3\u5c6c\u65bc\u3008post_tag\u3009\u5206\u985e\u6cd5\u7684\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u8986\u5beb\u9810\u8a2d\u5167\u5bb9\u6458\u8981\u9577\u5ea6\u3002","type":"integer","required":false},"password":{"description":"\u6587\u7ae0\u53d7\u5230\u5bc6\u78bc\u4fdd\u8b77\u6642\u7684\u6587\u7ae0\u5bc6\u78bc\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u7684\u4f5c\u8005 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u6458\u8981\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7cbe\u9078\u5a92\u9ad4 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u662f\u5426\u555f\u7528\u6587\u7ae0\u7684\u7559\u8a00\u529f\u80fd\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u662f\u5426\u80fd\u901a\u77e5\u6587\u7ae0\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6587\u7ae0\u7684\u683c\u5f0f\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u662f\u5426\u61c9\u5c07\u6587\u7ae0\u7f6e\u9802\u3002","type":"boolean","required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"categories":{"description":"\u5df2\u6307\u6d3e\u81f3\u5c6c\u65bc\u3008category\u3009\u5206\u985e\u6cd5\u7684\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u5df2\u6307\u6d3e\u81f3\u5c6c\u65bc\u3008post_tag\u3009\u5206\u985e\u6cd5\u7684\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u7269\u4ef6\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc [\u5167\u5bb9\u4fee\u8a02] \u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u7684\u4f5c\u8005 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u6458\u8981\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7cbe\u9078\u5a92\u9ad4 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u662f\u5426\u555f\u7528\u6587\u7ae0\u7684\u7559\u8a00\u529f\u80fd\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u662f\u5426\u80fd\u901a\u77e5\u6587\u7ae0\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6587\u7ae0\u7684\u683c\u5f0f\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u662f\u5426\u61c9\u5c07\u6587\u7ae0\u7f6e\u9802\u3002","type":"boolean","required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"categories":{"description":"\u5df2\u6307\u6d3e\u81f3\u5c6c\u65bc\u3008category\u3009\u5206\u985e\u6cd5\u7684\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u5df2\u6307\u6d3e\u81f3\u5c6c\u65bc\u3008post_tag\u3009\u5206\u985e\u6cd5\u7684\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u81f3\u6307\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u6d3e\u81f3\u6307\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u6307\u5b9a menu_order \u503c\u7684\u6587\u7ae0\u3002","type":"integer","required":false},"search_semantics":{"description":"\u89e3\u8b6f\u641c\u5c0b\u8f38\u5165\u7684\u65b9\u5f0f\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u6587\u7ae0\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u6307\u5b9a\u4e0a\u5c64\u9805\u76ee ID \u7684\u9805\u76ee\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u9664\u4e86\u542b\u6709\u6307\u5b9a\u4e0a\u5c64\u9805\u76ee ID \u4e4b\u5916\u7684\u5168\u90e8\u9805\u76ee\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u8981\u641c\u5c0b\u7684\u6b04\u4f4d\u540d\u7a31\u9663\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u4e00\u6216\u591a\u500b\u72c0\u614b\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"parent":{"description":"\u4e0a\u5c64\u6587\u7ae0\u7684 ID\u3002","type":"integer","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u7684\u4f5c\u8005 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u6458\u8981\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7cbe\u9078\u5a92\u9ad4 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u662f\u5426\u555f\u7528\u6587\u7ae0\u7684\u7559\u8a00\u529f\u80fd\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u662f\u5426\u80fd\u901a\u77e5\u6587\u7ae0\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u6587\u7ae0\u8207\u5176\u4ed6\u6587\u7ae0\u7684\u76f8\u5c0d\u9806\u5e8f\u3002","type":"integer","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u8986\u5beb\u9810\u8a2d\u5167\u5bb9\u6458\u8981\u9577\u5ea6\u3002","type":"integer","required":false},"password":{"description":"\u6587\u7ae0\u53d7\u5230\u5bc6\u78bc\u4fdd\u8b77\u6642\u7684\u6587\u7ae0\u5bc6\u78bc\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"parent":{"description":"\u4e0a\u5c64\u6587\u7ae0\u7684 ID\u3002","type":"integer","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u7684\u4f5c\u8005 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u6458\u8981\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7cbe\u9078\u5a92\u9ad4 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u662f\u5426\u555f\u7528\u6587\u7ae0\u7684\u7559\u8a00\u529f\u80fd\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u662f\u5426\u80fd\u901a\u77e5\u6587\u7ae0\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u6587\u7ae0\u8207\u5176\u4ed6\u6587\u7ae0\u7684\u76f8\u5c0d\u9806\u5e8f\u3002","type":"integer","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u7269\u4ef6\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc [\u5167\u5bb9\u4fee\u8a02] \u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u4e0a\u5c64\u6587\u7ae0\u7684 ID\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u7684\u4f5c\u8005 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u6458\u8981\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7cbe\u9078\u5a92\u9ad4 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u662f\u5426\u555f\u7528\u6587\u7ae0\u7684\u7559\u8a00\u529f\u80fd\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u662f\u5426\u80fd\u901a\u77e5\u6587\u7ae0\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u6587\u7ae0\u8207\u5176\u4ed6\u6587\u7ae0\u7684\u76f8\u5c0d\u9806\u5e8f\u3002","type":"integer","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u81f3\u6307\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u6d3e\u81f3\u6307\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u89e3\u8b6f\u641c\u5c0b\u8f38\u5165\u7684\u65b9\u5f0f\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u6587\u7ae0\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u6307\u5b9a\u4e0a\u5c64\u9805\u76ee ID \u7684\u9805\u76ee\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u9664\u4e86\u542b\u6709\u6307\u5b9a\u4e0a\u5c64\u9805\u76ee ID \u4e4b\u5916\u7684\u5168\u90e8\u9805\u76ee\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u8981\u641c\u5c0b\u7684\u6b04\u4f4d\u540d\u7a31\u9663\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u4e00\u6216\u591a\u500b\u72c0\u614b\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u7279\u5b9a\u5a92\u9ad4\u985e\u578b\u6216\u5a92\u9ad4\u985e\u578b\u7684\u9644\u4ef6\u3002","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u7279\u5b9a MIME \u985e\u578b\u6216 MIME \u985e\u578b\u7684\u9644\u4ef6\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u7684\u4f5c\u8005 ID\u3002","type":"integer","required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7cbe\u9078\u5a92\u9ad4 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u662f\u5426\u555f\u7528\u6587\u7ae0\u7684\u7559\u8a00\u529f\u80fd\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u662f\u5426\u80fd\u901a\u77e5\u6587\u7ae0\u3002","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"smush":{"description":"Smush data.","type":"string","required":false},"alt_text":{"description":"\u9644\u4ef6\u7121\u6cd5\u986f\u793a\u6642\u6240\u986f\u793a\u7684\u66ff\u4ee3\u6587\u5b57\u3002","type":"string","required":false},"caption":{"description":"\u9644\u4ef6\u8aaa\u660e\u6587\u5b57\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u9644\u4ef6\u8aaa\u660e\u6587\u5b57\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u8aaa\u660e\u6587\u5b57\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u9644\u4ef6\u5167\u5bb9\u8aaa\u660e\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u9644\u4ef6\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"\u8207\u9644\u4ef6\u95dc\u806f\u7684\u6587\u7ae0\u7684\u6587\u7ae0 ID\u3002","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"\u662f\u5426\u7522\u751f\u5716\u7247\u7684\u5176\u4ed6\u5c3a\u5bf8\u3002","required":false},"convert_format":{"type":"boolean","default":true,"description":"\u662f\u5426\u8f49\u63db\u5716\u7247\u683c\u5f0f\u3002","required":false},"url":{"type":"string","format":"uri","description":"\u8981\u5f9e\u5916\u90e8\u532f\u5165\u5a92\u9ad4\u5eab\u7684\u5716\u7247\u7db2\u5740\uff0c\u4ee5\u53d6\u4ee3\u4e0a\u50b3\u6a94\u6848\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u7684\u4f5c\u8005 ID\u3002","type":"integer","required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7cbe\u9078\u5a92\u9ad4 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u662f\u5426\u555f\u7528\u6587\u7ae0\u7684\u7559\u8a00\u529f\u80fd\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u662f\u5426\u80fd\u901a\u77e5\u6587\u7ae0\u3002","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"smush":{"description":"Smush data.","type":"string","required":false},"alt_text":{"description":"\u9644\u4ef6\u7121\u6cd5\u986f\u793a\u6642\u6240\u986f\u793a\u7684\u66ff\u4ee3\u6587\u5b57\u3002","type":"string","required":false},"caption":{"description":"\u9644\u4ef6\u8aaa\u660e\u6587\u5b57\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u9644\u4ef6\u8aaa\u660e\u6587\u5b57\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u8aaa\u660e\u6587\u5b57\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u9644\u4ef6\u5167\u5bb9\u8aaa\u660e\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u9644\u4ef6\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"\u8207\u9644\u4ef6\u95dc\u806f\u7684\u6587\u7ae0\u7684\u6587\u7ae0 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u9644\u4ef6\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"\u5df2\u7de8\u8f2f\u904e\u7684\u5716\u7247\u6a94\u6848\u7db2\u5740\u3002","type":"string","format":"uri","required":true},"modifiers":{"description":"\u5716\u7247\u7de8\u8f2f\u9663\u5217\u3002","type":"array","minItems":1,"items":{"description":"\u5716\u7247\u7de8\u8f2f\u3002","type":"object","required":["type","args"],"oneOf":[{"title":"\u7ffb\u8f49","properties":{"type":{"description":"\u7ffb\u8f49\u985e\u578b\u3002","type":"string","enum":["flip"]},"args":{"description":"\u7ffb\u8f49\u5f15\u6578\u3002","type":"object","required":["flip"],"properties":{"flip":{"description":"\u7ffb\u8f49\u65b9\u5411\u3002","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"\u662f\u5426\u9032\u884c\u6c34\u5e73\u7ffb\u8f49\u3002","type":"boolean"},"vertical":{"description":"\u662f\u5426\u9032\u884c\u5782\u76f4\u7ffb\u8f49\u3002","type":"boolean"}}}}}}},{"title":"\u65cb\u8f49","properties":{"type":{"description":"\u65cb\u8f49\u985e\u578b\u3002","type":"string","enum":["rotate"]},"args":{"description":"\u65cb\u8f49\u5f15\u6578\u3002","type":"object","required":["angle"],"properties":{"angle":{"description":"\u4ee5\u5ea6\u70ba\u55ae\u4f4d\uff0c\u9806\u6642\u91dd\u65b9\u5411\u65cb\u8f49\u7684\u8a2d\u5b9a\u503c\u3002","type":"number"}}}}},{"title":"\u88c1\u526a","properties":{"type":{"description":"\u88c1\u526a\u985e\u578b\u3002","type":"string","enum":["crop"]},"args":{"description":"\u88c1\u526a\u5f15\u6578\u3002","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"\u5f9e\u5de6\u5074\u958b\u59cb\u88c1\u526a\u7684\u6c34\u5e73\u4f4d\u7f6e (\u4ee5\u4f54\u7528\u5716\u7247\u5bec\u5ea6\u7684\u767e\u5206\u6bd4\u8a08\u7b97)\u3002","type":"number"},"top":{"description":"\u5f9e\u9802\u7aef\u958b\u59cb\u88c1\u526a\u7684\u5782\u76f4\u4f4d\u7f6e (\u4ee5\u4f54\u7528\u5716\u7247\u9ad8\u5ea6\u7684\u767e\u5206\u6bd4\u8a08\u7b97)\u3002","type":"number"},"width":{"description":"\u7528\u65bc\u88c1\u526a\u5716\u7247\u7684\u5bec\u5ea6 (\u4ee5\u4f54\u7528\u5716\u7247\u5bec\u5ea6\u7684\u767e\u5206\u6bd4\u8a08\u7b97)\u3002","type":"number"},"height":{"description":"\u7528\u65bc\u88c1\u526a\u5716\u7247\u7684\u9ad8\u5ea6 (\u4ee5\u4f54\u7528\u5716\u7247\u9ad8\u5ea6\u7684\u767e\u5206\u6bd4\u8a08\u7b97)\u3002","type":"number"}}}}}]},"required":false},"rotation":{"description":"\u4ee5\u5ea6\u70ba\u55ae\u4f4d\uff0c\u7528\u65bc\u9806\u6642\u91dd\u65b9\u5411\u65cb\u8f49\u5716\u7247\u3002\u5df2\u6dd8\u6c70\u4e0d\u7528\uff0c\u8acb\u6539\u7528 modifiers\u3002","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"\u7528\u65bc\u88c1\u526a\u5716\u7247\u7684 X \u8ef8\u8d77\u59cb\u4f4d\u7f6e (\u4ee5\u4f54\u7528\u5716\u7247\u7684\u767e\u5206\u6bd4\u8a08\u7b97)\u3002\u5df2\u6dd8\u6c70\u4e0d\u7528\uff0c\u8acb\u6539\u7528 modifiers\u3002","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"\u7528\u65bc\u88c1\u526a\u5716\u7247\u7684 Y \u8ef8\u8d77\u59cb\u4f4d\u7f6e (\u4ee5\u4f54\u7528\u5716\u7247\u7684\u767e\u5206\u6bd4\u8a08\u7b97)\u3002\u5df2\u6dd8\u6c70\u4e0d\u7528\uff0c\u8acb\u6539\u7528 modifiers\u3002","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"\u7528\u65bc\u88c1\u526a\u5716\u7247\u7684\u5bec\u5ea6 (\u4ee5\u4f54\u7528\u5716\u7247\u7684\u767e\u5206\u6bd4\u8a08\u7b97)\u3002\u5df2\u6dd8\u6c70\u4e0d\u7528\uff0c\u8acb\u6539\u7528 modifiers\u3002","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"\u7528\u65bc\u88c1\u526a\u5716\u7247\u7684\u9ad8\u5ea6 (\u4ee5\u4f54\u7528\u5716\u7247\u7684\u767e\u5206\u6bd4\u8a08\u7b97)\u3002\u5df2\u6dd8\u6c70\u4e0d\u7528\uff0c\u8acb\u6539\u7528 modifiers\u3002","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"\u9644\u4ef6\u8aaa\u660e\u6587\u5b57\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u9644\u4ef6\u8aaa\u660e\u6587\u5b57\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u8aaa\u660e\u6587\u5b57\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u9644\u4ef6\u5167\u5bb9\u8aaa\u660e\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u9644\u4ef6\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"\u8207\u9644\u4ef6\u95dc\u806f\u7684\u6587\u7ae0\u7684\u6587\u7ae0 ID\u3002","type":"integer","required":false},"alt_text":{"description":"\u9644\u4ef6\u7121\u6cd5\u986f\u793a\u6642\u6240\u986f\u793a\u7684\u66ff\u4ee3\u6587\u5b57\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/sideload":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u9644\u4ef6\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"image_size":{"description":"\u5716\u7247\u5c3a\u5bf8\u3002\u53ef\u4ee5\u662f\u55ae\u4e00\u5c3a\u5bf8\u540d\u7a31\u6216\u5c3a\u5bf8\u540d\u7a31\u9663\u5217\uff0c\u8b93\u540c\u4e00\u500b\u6a94\u6848\u4ee5\u591a\u500b\u5c3a\u5bf8\u8a3b\u518a\u3002","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"convert_format":{"type":"boolean","default":true,"description":"\u662f\u5426\u8f49\u63db\u5716\u7247\u683c\u5f0f\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/finalize":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u9644\u4ef6\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"sub_sizes":{"description":"\u5f9e\u5074\u8f09\u56de\u61c9\u4e2d\u6536\u96c6\u7684\u5b50\u5c3a\u5bf8\u4e2d\u7e7c\u8cc7\u6599\u9663\u5217\u3002","type":"array","default":[],"maxItems":100,"items":{"type":"object","properties":{"image_size":{"description":"\u5c3a\u5bf8\u540d\u7a31\uff1b\u82e5\u540c\u4e00\u500b\u6a94\u6848\u4ee5\u591a\u500b\u9577\u5bec\u76f8\u540c\u7684\u5c3a\u5bf8\u8a3b\u518a\uff0c\u5247\u70ba\u5c3a\u5bf8\u540d\u7a31\u9663\u5217\u3002","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"width":{"type":"integer","minimum":1},"height":{"type":"integer","minimum":1},"file":{"type":"string","minLength":1},"mime_type":{"type":"string","pattern":"^image\/.*"},"filesize":{"type":"integer","minimum":1},"original_image":{"type":"string","minLength":1}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u89e3\u8b6f\u641c\u5c0b\u8f38\u5165\u7684\u65b9\u5f0f\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u7269\u4ef6\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"\u8981\u641c\u5c0b\u7684\u6b04\u4f4d\u540d\u7a31\u9663\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u4e00\u6216\u591a\u500b\u72c0\u614b\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u57fa\u65bc\u591a\u500b\u5206\u985e\u6cd5\u9593\u7684\u95dc\u4fc2\u3002","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5728 [menus] \u5206\u985e\u6cd5\u4e2d\u4f7f\u7528\u6307\u6d3e\u6307\u5b9a\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u9805\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u6e05\u55ae","description":"\u5c07\u5206\u985e\u6cd5\u8a5e\u5f59\u8207\u5217\u51fa\u7684 ID \u9032\u884c\u6bd4\u5c0d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u5206\u985e\u6cd5\u67e5\u8a62","description":"\u57f7\u884c\u9032\u968e\u5206\u985e\u6cd5\u8a5e\u5f59\u67e5\u8a62\u3002","type":"object","properties":{"terms":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u9805\u76ee\u662f\u5426\u5fc5\u9808\u6307\u6d3e\u7d66\u5168\u90e8\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u9664\u4e86\u5728 [menus] \u5206\u985e\u6cd5\u4e2d\u4f7f\u7528\u6307\u6d3e\u6307\u5b9a\u5206\u985e\u6cd5\u8a5e\u5f59\u4e4b\u5916\u7684\u9805\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u6e05\u55ae","description":"\u5c07\u5206\u985e\u6cd5\u8a5e\u5f59\u8207\u5217\u51fa\u7684 ID \u9032\u884c\u6bd4\u5c0d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u5206\u985e\u6cd5\u67e5\u8a62","description":"\u57f7\u884c\u9032\u968e\u5206\u985e\u6cd5\u8a5e\u5f59\u67e5\u8a62\u3002","type":"object","properties":{"terms":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u6307\u5b9a menu_order \u503c\u7684\u6587\u7ae0\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"\u7269\u4ef6\u7684\u6a19\u984c\u3002","type":["string","object"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7269\u4ef6\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u7269\u4ef6\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"\u7269\u4ef6\u521d\u59cb\u8868\u793a\u7cfb\u5217\uff0c\u4f8b\u5982 post_type \u6216 taxonomy\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"\u7269\u4ef6\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"\u7269\u4ef6\u7684\u4e0a\u5c64\u9805\u76ee ID\u3002","type":"integer","minimum":0,"required":false},"attr_title":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u9023\u7d50\u5143\u7d20 title \u5c6c\u6027\u6587\u5b57\u3002","type":"string","required":false},"classes":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u9023\u7d50\u5143\u7d20\u985e\u5225\u540d\u7a31\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","required":false},"menu_order":{"default":1,"description":"nav_menu_item \u7684\u8cc7\u6599\u5eab ID\u3002\u5982\u679c\u6709 nav_menu_item\uff0c\u4fbf\u6703\u662f\u9019\u500b\u9805\u76ee\u7684\u4e0a\u5c64\u9078\u55ae\uff0c0 \u4ee3\u8868\u6c92\u6709\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u7269\u4ef6\u521d\u59cb\u8868\u793a\u985e\u578b\uff0c\u4f8b\u5982 category\u3001post \u6216 attachment\u3002","type":"string","required":false},"object_id":{"default":0,"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u4ee3\u8868\u7684\u539f\u59cb\u7269\u4ef6\u7684\u8cc7\u6599\u5eab ID\uff0c\u4f8b\u5982\u6587\u7ae0 ID \u53ca\u5206\u985e\u7684 term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u9023\u7d50\u5143\u7d20\u76ee\u6a19\u5c6c\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u6240\u6307\u5411\u7684\u7db2\u5740\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u5728\u9019\u500b\u9078\u55ae\u9805\u76ee\u9023\u7d50\u8868\u793a\u7684 XFN \u4eba\u969b\u95dc\u4fc2\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u5df2\u6307\u6d3e\u81f3\u3008nav_menu\u3009\u5206\u985e\u6cd5\u7269\u4ef6\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"integer","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"title":{"description":"\u7269\u4ef6\u7684\u6a19\u984c\u3002","type":["string","object"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7269\u4ef6\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u7269\u4ef6\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"\u7269\u4ef6\u521d\u59cb\u8868\u793a\u7cfb\u5217\uff0c\u4f8b\u5982 post_type \u6216 taxonomy\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"\u7269\u4ef6\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"\u7269\u4ef6\u7684\u4e0a\u5c64\u9805\u76ee ID\u3002","type":"integer","minimum":0,"required":false},"attr_title":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u9023\u7d50\u5143\u7d20 title \u5c6c\u6027\u6587\u5b57\u3002","type":"string","required":false},"classes":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u9023\u7d50\u5143\u7d20\u985e\u5225\u540d\u7a31\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","required":false},"menu_order":{"description":"nav_menu_item \u7684\u8cc7\u6599\u5eab ID\u3002\u5982\u679c\u6709 nav_menu_item\uff0c\u4fbf\u6703\u662f\u9019\u500b\u9805\u76ee\u7684\u4e0a\u5c64\u9078\u55ae\uff0c0 \u4ee3\u8868\u6c92\u6709\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u7269\u4ef6\u521d\u59cb\u8868\u793a\u985e\u578b\uff0c\u4f8b\u5982 category\u3001post \u6216 attachment\u3002","type":"string","required":false},"object_id":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u4ee3\u8868\u7684\u539f\u59cb\u7269\u4ef6\u7684\u8cc7\u6599\u5eab ID\uff0c\u4f8b\u5982\u6587\u7ae0 ID \u53ca\u5206\u985e\u7684 term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u9023\u7d50\u5143\u7d20\u76ee\u6a19\u5c6c\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u6240\u6307\u5411\u7684\u7db2\u5740\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u5728\u9019\u500b\u9078\u55ae\u9805\u76ee\u9023\u7d50\u8868\u793a\u7684 XFN \u4eba\u969b\u95dc\u4fc2\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u5df2\u6307\u6d3e\u81f3\u3008nav_menu\u3009\u5206\u985e\u6cd5\u7269\u4ef6\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"integer","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u7269\u4ef6\u7684\u4e0a\u5c64\u9805\u76ee ID\u3002","type":"integer","minimum":0,"required":false},"title":{"description":"\u7269\u4ef6\u7684\u6a19\u984c\u3002","type":["string","object"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7269\u4ef6\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u7269\u4ef6\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"\u7269\u4ef6\u521d\u59cb\u8868\u793a\u7cfb\u5217\uff0c\u4f8b\u5982 post_type \u6216 taxonomy\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"\u7269\u4ef6\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u9023\u7d50\u5143\u7d20 title \u5c6c\u6027\u6587\u5b57\u3002","type":"string","required":false},"classes":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u9023\u7d50\u5143\u7d20\u985e\u5225\u540d\u7a31\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","required":false},"menu_order":{"description":"nav_menu_item \u7684\u8cc7\u6599\u5eab ID\u3002\u5982\u679c\u6709 nav_menu_item\uff0c\u4fbf\u6703\u662f\u9019\u500b\u9805\u76ee\u7684\u4e0a\u5c64\u9078\u55ae\uff0c0 \u4ee3\u8868\u6c92\u6709\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u7269\u4ef6\u521d\u59cb\u8868\u793a\u985e\u578b\uff0c\u4f8b\u5982 category\u3001post \u6216 attachment\u3002","type":"string","required":false},"object_id":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u4ee3\u8868\u7684\u539f\u59cb\u7269\u4ef6\u7684\u8cc7\u6599\u5eab ID\uff0c\u4f8b\u5982\u6587\u7ae0 ID \u53ca\u5206\u985e\u7684 term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u7684\u9023\u7d50\u5143\u7d20\u76ee\u6a19\u5c6c\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u9019\u500b\u9078\u55ae\u9805\u76ee\u6240\u6307\u5411\u7684\u7db2\u5740\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u5728\u9019\u500b\u9078\u55ae\u9805\u76ee\u9023\u7d50\u8868\u793a\u7684 XFN \u4eba\u969b\u95dc\u4fc2\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u5df2\u6307\u6d3e\u81f3\u3008nav_menu\u3009\u5206\u985e\u6cd5\u7269\u4ef6\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"integer","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u89e3\u8b6f\u641c\u5c0b\u8f38\u5165\u7684\u65b9\u5f0f\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u6587\u7ae0\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u8981\u641c\u5c0b\u7684\u6b04\u4f4d\u540d\u7a31\u9663\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u4e00\u6216\u591a\u500b\u72c0\u614b\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u57fa\u65bc\u591a\u500b\u5206\u985e\u6cd5\u9593\u7684\u95dc\u4fc2\u3002","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5728 [wp_pattern_category] \u5206\u985e\u6cd5\u4e2d\u4f7f\u7528\u6307\u6d3e\u6307\u5b9a\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u9805\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u6e05\u55ae","description":"\u5c07\u5206\u985e\u6cd5\u8a5e\u5f59\u8207\u5217\u51fa\u7684 ID \u9032\u884c\u6bd4\u5c0d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u5206\u985e\u6cd5\u67e5\u8a62","description":"\u57f7\u884c\u9032\u968e\u5206\u985e\u6cd5\u8a5e\u5f59\u67e5\u8a62\u3002","type":"object","properties":{"terms":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u9805\u76ee\u662f\u5426\u5fc5\u9808\u6307\u6d3e\u7d66\u5168\u90e8\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u9664\u4e86\u5728 [wp_pattern_category] \u5206\u985e\u6cd5\u4e2d\u4f7f\u7528\u6307\u6d3e\u6307\u5b9a\u5206\u985e\u6cd5\u8a5e\u5f59\u4e4b\u5916\u7684\u9805\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u6e05\u55ae","description":"\u5c07\u5206\u985e\u6cd5\u8a5e\u5f59\u8207\u5217\u51fa\u7684 ID \u9032\u884c\u6bd4\u5c0d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID \u5206\u985e\u6cd5\u67e5\u8a62","description":"\u57f7\u884c\u9032\u968e\u5206\u985e\u6cd5\u8a5e\u5f59\u67e5\u8a62\u3002","type":"object","properties":{"terms":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u6458\u8981\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u5df2\u6307\u6d3e\u81f3\u5c6c\u65bc\u3008wp_pattern_category\u3009\u5206\u985e\u6cd5\u7684\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u8986\u5beb\u9810\u8a2d\u5167\u5bb9\u6458\u8981\u9577\u5ea6\u3002","type":"integer","required":false},"password":{"description":"\u6587\u7ae0\u53d7\u5230\u5bc6\u78bc\u4fdd\u8b77\u6642\u7684\u6587\u7ae0\u5bc6\u78bc\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u6458\u8981\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u5df2\u6307\u6d3e\u81f3\u5c6c\u65bc\u3008wp_pattern_category\u3009\u5206\u985e\u6cd5\u7684\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u7269\u4ef6\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc [\u5167\u5bb9\u4fee\u8a02] \u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u6458\u8981\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u6458\u8981\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u5df2\u6307\u6d3e\u81f3\u5c6c\u65bc\u3008wp_pattern_category\u3009\u5206\u985e\u6cd5\u7684\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u7269\u4ef6\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc [\u5167\u5bb9\u4fee\u8a02] \u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"slug":{"description":"\u8b58\u5225\u7bc4\u672c\u7684\u552f\u4e00\u4ee3\u7a31\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u7bc4\u672c\u7684\u4f48\u666f\u4e3b\u984c\u8b58\u5225\u78bc\u3002","type":"string","required":false},"type":{"description":"\u7bc4\u672c\u7684\u985e\u578b\u3002","type":"string","required":false},"content":{"description":"\u7bc4\u672c\u5167\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u5167\u5bb9\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u7bc4\u672c\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u7bc4\u672c\u6a19\u984c\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u7bc4\u672c\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u7bc4\u672c\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","required":false},"status":{"description":"\u7bc4\u672c\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u7bc4\u672c\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"id":{"description":"\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"\u9650\u5236\u70ba\u6307\u5b9a\u6587\u7ae0 ID\u3002","type":"integer","required":false},"area":{"description":"\u9650\u5236\u70ba\u6307\u5b9a\u7bc4\u672c\u7d44\u4ef6\u5340\u57df\u3002","type":"string","required":false},"post_type":{"description":"\u53d6\u5f97\u7bc4\u672c\u4f7f\u7528\u7684\u5167\u5bb9\u985e\u578b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"\u8b58\u5225\u7bc4\u672c\u7684\u552f\u4e00\u4ee3\u7a31\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"\u7bc4\u672c\u7684\u4f48\u666f\u4e3b\u984c\u8b58\u5225\u78bc\u3002","type":"string","required":false},"type":{"description":"\u7bc4\u672c\u7684\u985e\u578b\u3002","type":"string","required":false},"content":{"default":"","description":"\u7bc4\u672c\u5167\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u5167\u5bb9\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u7bc4\u672c\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"\u7bc4\u672c\u6a19\u984c\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u7bc4\u672c\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"\u7bc4\u672c\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","required":false},"status":{"default":"publish","description":"\u7bc4\u672c\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u7bc4\u672c\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u53d6\u5f97\u5099\u7528\u7bc4\u672c\u4ee3\u7a31","type":"string","required":true},"is_custom":{"description":"\u6307\u5b9a\u7bc4\u672c\u70ba\u81ea\u8a02\u7bc4\u672c\u6216\u7bc4\u672c\u968e\u5c64\u7684\u4e00\u90e8\u4efd","type":"boolean","required":false},"template_prefix":{"description":"\u5df2\u5efa\u7acb\u7bc4\u672c\u7684\u7bc4\u672c\u524d\u7f6e\u8a5e\u3002\u9019\u500b\u524d\u7f6e\u8a5e\u6703\u7528\u65bc\u64f7\u53d6\u4e3b\u8981\u7bc4\u672c\u985e\u578b\uff0c\u4f8b\u5982\u5728 taxonomy-books \u4e2d\u64f7\u53d6\u51fa taxonomy","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"slug":{"description":"\u8b58\u5225\u7bc4\u672c\u7684\u552f\u4e00\u4ee3\u7a31\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u7bc4\u672c\u7684\u4f48\u666f\u4e3b\u984c\u8b58\u5225\u78bc\u3002","type":"string","required":false},"type":{"description":"\u7bc4\u672c\u7684\u985e\u578b\u3002","type":"string","required":false},"content":{"description":"\u7bc4\u672c\u5167\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u5167\u5bb9\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u7bc4\u672c\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u7bc4\u672c\u6a19\u984c\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u7bc4\u672c\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u7bc4\u672c\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","required":false},"status":{"description":"\u7bc4\u672c\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u7bc4\u672c\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u7269\u4ef6\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc [\u5167\u5bb9\u4fee\u8a02] \u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"slug":{"description":"\u8b58\u5225\u7bc4\u672c\u7684\u552f\u4e00\u4ee3\u7a31\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u7bc4\u672c\u7684\u4f48\u666f\u4e3b\u984c\u8b58\u5225\u78bc\u3002","type":"string","required":false},"type":{"description":"\u7bc4\u672c\u7684\u985e\u578b\u3002","type":"string","required":false},"content":{"description":"\u7bc4\u672c\u5167\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u5167\u5bb9\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u7bc4\u672c\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u7bc4\u672c\u6a19\u984c\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u7bc4\u672c\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u7bc4\u672c\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","required":false},"status":{"description":"\u7bc4\u672c\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u7bc4\u672c\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"area":{"description":"\u9700\u8981\u4f7f\u7528\u7bc4\u672c\u7d44\u4ef6\u7684\u4f4d\u7f6e (\u4f8b\u5982\u9801\u9996\u3001\u9801\u5c3e\u7b49)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"id":{"description":"\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"\u9650\u5236\u70ba\u6307\u5b9a\u6587\u7ae0 ID\u3002","type":"integer","required":false},"area":{"description":"\u9650\u5236\u70ba\u6307\u5b9a\u7bc4\u672c\u7d44\u4ef6\u5340\u57df\u3002","type":"string","required":false},"post_type":{"description":"\u53d6\u5f97\u7bc4\u672c\u4f7f\u7528\u7684\u5167\u5bb9\u985e\u578b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"\u8b58\u5225\u7bc4\u672c\u7684\u552f\u4e00\u4ee3\u7a31\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"\u7bc4\u672c\u7684\u4f48\u666f\u4e3b\u984c\u8b58\u5225\u78bc\u3002","type":"string","required":false},"type":{"description":"\u7bc4\u672c\u7684\u985e\u578b\u3002","type":"string","required":false},"content":{"default":"","description":"\u7bc4\u672c\u5167\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u5167\u5bb9\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u7bc4\u672c\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"\u7bc4\u672c\u6a19\u984c\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u7bc4\u672c\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"\u7bc4\u672c\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","required":false},"status":{"default":"publish","description":"\u7bc4\u672c\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u7bc4\u672c\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"area":{"description":"\u9700\u8981\u4f7f\u7528\u7bc4\u672c\u7d44\u4ef6\u7684\u4f4d\u7f6e (\u4f8b\u5982\u9801\u9996\u3001\u9801\u5c3e\u7b49)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u53d6\u5f97\u5099\u7528\u7bc4\u672c\u4ee3\u7a31","type":"string","required":true},"is_custom":{"description":"\u6307\u5b9a\u7bc4\u672c\u70ba\u81ea\u8a02\u7bc4\u672c\u6216\u7bc4\u672c\u968e\u5c64\u7684\u4e00\u90e8\u4efd","type":"boolean","required":false},"template_prefix":{"description":"\u5df2\u5efa\u7acb\u7bc4\u672c\u7684\u7bc4\u672c\u524d\u7f6e\u8a5e\u3002\u9019\u500b\u524d\u7f6e\u8a5e\u6703\u7528\u65bc\u64f7\u53d6\u4e3b\u8981\u7bc4\u672c\u985e\u578b\uff0c\u4f8b\u5982\u5728 taxonomy-books \u4e2d\u64f7\u53d6\u51fa taxonomy","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"slug":{"description":"\u8b58\u5225\u7bc4\u672c\u7684\u552f\u4e00\u4ee3\u7a31\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u7bc4\u672c\u7684\u4f48\u666f\u4e3b\u984c\u8b58\u5225\u78bc\u3002","type":"string","required":false},"type":{"description":"\u7bc4\u672c\u7684\u985e\u578b\u3002","type":"string","required":false},"content":{"description":"\u7bc4\u672c\u5167\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u5167\u5bb9\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u7bc4\u672c\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u7bc4\u672c\u6a19\u984c\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7bc4\u672c\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u7bc4\u672c\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u7bc4\u672c\u5167\u5bb9\u8aaa\u660e\u3002","type":"string","required":false},"status":{"description":"\u7bc4\u672c\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u7bc4\u672c\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"area":{"description":"\u9700\u8981\u4f7f\u7528\u7bc4\u672c\u7d44\u4ef6\u7684\u4f4d\u7f6e (\u4f8b\u5982\u9801\u9996\u3001\u9801\u5c3e\u7b49)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u7bc4\u672c ID\u3002","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u5168\u57df\u6a23\u5f0f\u5167\u5bb9\u4fee\u8a02\u7684\u4e0a\u5c64\u9805\u76ee ID\u3002","type":"integer","required":false},"id":{"description":"\u5168\u57df\u6a23\u5f0f\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"\u4f48\u666f\u4e3b\u984c\u8b58\u5225\u78bc","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"\u4f48\u666f\u4e3b\u984c\u8b58\u5225\u78bc","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"\u5168\u57df\u6a23\u5f0f\u7d44\u614b ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"\u5168\u57df\u6a23\u5f0f\u3002","type":["object"],"required":false},"settings":{"description":"\u5168\u57df\u8a2d\u5b9a\u3002","type":["object"],"required":false},"title":{"description":"\u5168\u57df\u6a23\u5f0f\u8b8a\u5316\u7684\u6a19\u984c\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u5168\u57df\u6a23\u5f0f\u8b8a\u5316\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u89e3\u8b6f\u641c\u5c0b\u8f38\u5165\u7684\u65b9\u5f0f\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u6587\u7ae0\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u8981\u641c\u5c0b\u7684\u6b04\u4f4d\u540d\u7a31\u9663\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u4e00\u6216\u591a\u500b\u72c0\u614b\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u6587\u7ae0\u53d7\u5230\u5bc6\u78bc\u4fdd\u8b77\u6642\u7684\u6587\u7ae0\u5bc6\u78bc\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u7269\u4ef6\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4e0a\u5c64\u5167\u5bb9\u4fee\u8a02\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u5167\u5bb9\u4fee\u8a02\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc [\u5167\u5bb9\u4fee\u8a02] \u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u89e3\u8b6f\u641c\u5c0b\u8f38\u5165\u7684\u65b9\u5f0f\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u6587\u7ae0\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"\u7528\u65bc\u6392\u7248\u6a23\u5f0f\u8a2d\u5b9a\u7684 theme.json \u7d50\u69cb\u5b9a\u7fa9\u7248\u672c\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"theme.json \u683c\u5f0f\u7684 font-family \u5ba3\u544a\uff0c\u7de8\u78bc\u65b9\u5f0f\u70ba\u5b57\u4e32\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"theme_json_version":{"description":"\u7528\u65bc\u6392\u7248\u6a23\u5f0f\u8a2d\u5b9a\u7684 theme.json \u7d50\u69cb\u5b9a\u7fa9\u7248\u672c\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"theme.json \u683c\u5f0f\u7684 font-family \u5ba3\u544a\uff0c\u7de8\u78bc\u65b9\u5f0f\u70ba\u5b57\u4e32\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"\u5b57\u578b\u5b9a\u7fa9\u7684\u4e0a\u5c64\u5b57\u578b\u7cfb\u5217 ID\u3002","type":"integer","required":true},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u89e3\u8b6f\u641c\u5c0b\u8f38\u5165\u7684\u65b9\u5f0f\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u6587\u7ae0\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"id","enum":["id","include"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"\u5b57\u578b\u5b9a\u7fa9\u7684\u4e0a\u5c64\u5b57\u578b\u7cfb\u5217 ID\u3002","type":"integer","required":true},"theme_json_version":{"description":"\u7528\u65bc\u6392\u7248\u6a23\u5f0f\u8a2d\u5b9a\u7684 theme.json \u7d50\u69cb\u5b9a\u7fa9\u7248\u672c\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"theme.json \u683c\u5f0f\u7684 font-face \u5ba3\u544a\uff0c\u7de8\u78bc\u65b9\u5f0f\u70ba\u5b57\u4e32\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"\u5b57\u578b\u5b9a\u7fa9\u7684\u4e0a\u5c64\u5b57\u578b\u7cfb\u5217 ID\u3002","type":"integer","required":true},"id":{"description":"\u5b57\u578b\u5b9a\u7fa9\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":true},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"\u5b57\u578b\u5b9a\u7fa9\u7684\u4e0a\u5c64\u5b57\u578b\u7cfb\u5217 ID\u3002","type":"integer","required":true},"id":{"description":"\u5b57\u578b\u5b9a\u7fa9\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rm_content_editor":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u89e3\u8b6f\u641c\u5c0b\u8f38\u5165\u7684\u65b9\u5f0f\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u6587\u7ae0\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u8981\u641c\u5c0b\u7684\u6b04\u4f4d\u540d\u7a31\u9663\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u4e00\u6216\u591a\u500b\u72c0\u614b\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/rm_content_editor"}]}},"\/wp\/v2\/rm_content_editor\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u6587\u7ae0\u53d7\u5230\u5bc6\u78bc\u4fdd\u8b77\u6642\u7684\u6587\u7ae0\u5bc6\u78bc\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rm_content_editor\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"content":{"description":"\u6587\u7ae0\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6587\u7ae0\u4f7f\u7528\u7684\u5167\u5bb9\u5340\u584a\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5167\u5bb9\u662f\u5426\u53d7\u5bc6\u78bc\u4fdd\u8b77\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rm_content_editor\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4e0a\u5c64\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u5132\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rank_math_schema":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u767c\u4f48\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u4fee\u6539\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u89e3\u8b6f\u641c\u5c0b\u8f38\u5165\u7684\u65b9\u5f0f\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u6587\u7ae0\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u8981\u641c\u5c0b\u7684\u6b04\u4f4d\u540d\u7a31\u9663\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u4e00\u6216\u591a\u500b\u72c0\u614b\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/rank_math_schema"}]}},"\/wp\/v2\/rank_math_schema\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u6587\u7ae0\u53d7\u5230\u5bc6\u78bc\u4fdd\u8b77\u6642\u7684\u6587\u7ae0\u5bc6\u78bc\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u6587\u7ae0\u7684\u767c\u4f48\u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72c0\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u4e00\u7d44\u7528\u4f86\u4fdd\u8b77\u5167\u5bb9\u53ca\u5167\u5bb9\u6458\u8981\u5b58\u53d6\u7684\u5bc6\u78bc\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6a19\u984c\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u6587\u7ae0\u6a19\u984c\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u6a19\u984c\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u65bc\u986f\u793a\u6587\u7ae0\u7684\u4f48\u666f\u4e3b\u984c\u6a94\u6848\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\u7684\u5167\u5bb9\u985e\u578b\u8b58\u5225\u78bc\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\u7684\u72c0\u614b\u8b58\u5225\u78bc\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u8207\u6307\u5b9a\u5167\u5bb9\u985e\u578b\u95dc\u806f\u7684\u5206\u985e\u6cd5\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\u7684\u5206\u985e\u6cd5\u8b58\u5225\u78bc\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u5206\u985e\u6cd5\u8a5e\u5f59\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u96b1\u85cf\u5c1a\u672a\u6307\u6d3e\u81f3\u4efb\u4f55\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"boolean","default":false,"required":false},"parent":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u81f3\u6307\u5b9a\u4e0a\u5c64\u9805\u76ee\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"integer","required":false},"post":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u81f3\u6307\u5b9a\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u5167\u5bb9\u8aaa\u660e (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"name":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u6a19\u984c (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":true},"slug":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"parent":{"description":"\u4e0a\u5c64\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"integer","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"description":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u5167\u5bb9\u8aaa\u660e (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"name":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u6a19\u984c (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"slug":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"parent":{"description":"\u4e0a\u5c64\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"integer","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc\u5206\u985e\u6cd5\u8a5e\u5f59\u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u5206\u985e\u6cd5\u8a5e\u5f59\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u96b1\u85cf\u5c1a\u672a\u6307\u6d3e\u81f3\u4efb\u4f55\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u81f3\u6307\u5b9a\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u5167\u5bb9\u8aaa\u660e (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"name":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u6a19\u984c (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":true},"slug":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"description":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u5167\u5bb9\u8aaa\u660e (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"name":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u6a19\u984c (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"slug":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc\u5206\u985e\u6cd5\u8a5e\u5f59\u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u5206\u985e\u6cd5\u8a5e\u5f59\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u96b1\u85cf\u5c1a\u672a\u6307\u6d3e\u81f3\u4efb\u4f55\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u81f3\u6307\u5b9a\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u5167\u5bb9\u8aaa\u660e (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"name":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u6a19\u984c (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":true},"slug":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":[],"required":false},"locations":{"description":"\u6307\u6d3e\u7d66\u9078\u55ae\u7684\u4f4d\u7f6e\u3002","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"\u662f\u5426\u81ea\u52d5\u5c07\u6700\u4e0a\u5c64\u9801\u9762\u65b0\u589e\u81f3\u9019\u500b\u9078\u55ae\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"description":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u5167\u5bb9\u8aaa\u660e (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"name":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u6a19\u984c (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"slug":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":[],"required":false},"locations":{"description":"\u6307\u6d3e\u7d66\u9078\u55ae\u7684\u4f4d\u7f6e\u3002","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"\u662f\u5426\u81ea\u52d5\u5c07\u6700\u4e0a\u5c64\u9801\u9762\u65b0\u589e\u81f3\u9019\u500b\u9078\u55ae\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc\u5206\u985e\u6cd5\u8a5e\u5f59\u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u5206\u985e\u6cd5\u8a5e\u5f59\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u96b1\u85cf\u5c1a\u672a\u6307\u6d3e\u81f3\u4efb\u4f55\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u81f3\u6307\u5b9a\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u5167\u5bb9\u8aaa\u660e (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"name":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u6a19\u984c (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":true},"slug":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"description":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u5167\u5bb9\u8aaa\u660e (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"name":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u6a19\u984c (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"slug":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc\u5206\u985e\u6cd5\u8a5e\u5f59\u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rank_math_redirection_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u5206\u985e\u6cd5\u8a5e\u5f59\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u96b1\u85cf\u5c1a\u672a\u6307\u6d3e\u81f3\u4efb\u4f55\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"boolean","default":false,"required":false},"parent":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u81f3\u6307\u5b9a\u4e0a\u5c64\u9805\u76ee\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"integer","required":false},"post":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u81f3\u6307\u5b9a\u6587\u7ae0\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u5206\u985e\u6cd5\u8a5e\u5f59\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u5167\u5bb9\u8aaa\u660e (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"name":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u6a19\u984c (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":true},"slug":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"parent":{"description":"\u4e0a\u5c64\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"integer","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/rank_math_redirection_category"}]}},"\/wp\/v2\/rank_math_redirection_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"description":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u5167\u5bb9\u8aaa\u660e (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"name":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u6a19\u984c (\u53ef\u4f7f\u7528 HTML \u7a0b\u5f0f\u78bc)\u3002","type":"string","required":false},"slug":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u8b58\u5225\u78bc\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\uff0c\u5728\u5176\u6240\u5c6c\u7684\u578b\u5225\u4e2d\u5fc5\u9808\u662f\u552f\u4e00\u7684\u9805\u76ee\u3002","type":"string","required":false},"parent":{"description":"\u4e0a\u5c64\u5206\u985e\u6cd5\u8a5e\u5f59 ID\u3002","type":"integer","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5206\u985e\u6cd5\u8a5e\u5f59\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc\u5206\u985e\u6cd5\u8a5e\u5f59\u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"default":"asc","description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"\u4f9d\u4f7f\u7528\u8005\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u542b\u6709\u4e00\u6216\u591a\u500b\u6307\u5b9a\u4ee3\u7a31\u7684\u4f7f\u7528\u8005\u3002","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u7b26\u5408\u81f3\u5c11\u4e00\u7a2e\u6307\u5b9a\u4f7f\u7528\u8005\u89d2\u8272\u7684\u4f7f\u7528\u8005\u3002\u63a5\u53d7 CSV \u6e05\u55ae\u6216\u55ae\u4e00\u4f7f\u7528\u8005\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u7b26\u5408\u81f3\u5c11\u4e00\u7a2e\u6307\u5b9a\u6b0a\u9650\u7684\u4f7f\u7528\u8005\u3002\u63a5\u53d7 CSV \u6e05\u55ae\u6216\u55ae\u4e00\u6b0a\u9650\u3002","type":"array","items":{"type":"string"},"required":false},"who":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5224\u5b9a\u70ba\u4f5c\u8005\u7684\u4f7f\u7528\u8005\u3002","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u66fe\u767c\u4f48\u904e\u6587\u7ae0\u7684\u4f7f\u7528\u8005\u3002","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","rm_content_editor":"rm_content_editor","rank_math_schema":"rank_math_schema"}},"required":false},"search_columns":{"default":[],"description":"\u8981\u641c\u5c0b\u7684\u6b04\u4f4d\u540d\u7a31\u9663\u5217\u3002","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"\u4f7f\u7528\u8005\u7684\u767b\u5165\u540d\u7a31\u3002","type":"string","required":true},"name":{"description":"\u4f7f\u7528\u8005\u7684\u986f\u793a\u540d\u7a31\u3002","type":"string","required":false},"first_name":{"description":"\u4f7f\u7528\u8005\u7684\u540d\u5b57\u3002","type":"string","required":false},"last_name":{"description":"\u4f7f\u7528\u8005\u7684\u59d3\u6c0f\u3002","type":"string","required":false},"email":{"description":"\u4f7f\u7528\u8005\u7684\u96fb\u5b50\u90f5\u4ef6\u5730\u5740\u3002","type":"string","format":"email","required":true},"url":{"description":"\u4f7f\u7528\u8005\u7684\u7db2\u5740\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u4f7f\u7528\u8005\u7684\u500b\u4eba\u8cc7\u6599\u3002","type":"string","required":false},"locale":{"description":"\u4f7f\u7528\u8005\u7684\u5730\u5340\u8a9e\u8a00\u504f\u597d\u3002","type":"string","enum":["","en_US","bg_BG","cs_CZ","de_DE","el","es_ES","fr_FR","hu_HU","it_IT","ja","nl_NL","pl_PL","pt_BR","pt_PT","ru_RU","sk_SK","sl_SI","sv_SE","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"\u4f7f\u7528\u8005\u7684\u66b1\u7a31\u3002","type":"string","required":false},"slug":{"description":"\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\u7684\u4f7f\u7528\u8005\u8b58\u5225\u78bc\u3002","type":"string","required":false},"roles":{"description":"\u6307\u6d3e\u7d66\u4f7f\u7528\u8005\u7684\u4f7f\u7528\u8005\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u4f7f\u7528\u8005\u7684\u5bc6\u78bc (\u6c38\u4e0d\u5305\u542b) \u3002","type":"string","required":true},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u65e5\u671f\u53ca\u6642\u9593\u7684\u504f\u597d\u8a2d\u5b9a\u5df2\u66f4\u65b0\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u4f7f\u7528\u8005\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u4f7f\u7528\u8005\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"username":{"description":"\u4f7f\u7528\u8005\u7684\u767b\u5165\u540d\u7a31\u3002","type":"string","required":false},"name":{"description":"\u4f7f\u7528\u8005\u7684\u986f\u793a\u540d\u7a31\u3002","type":"string","required":false},"first_name":{"description":"\u4f7f\u7528\u8005\u7684\u540d\u5b57\u3002","type":"string","required":false},"last_name":{"description":"\u4f7f\u7528\u8005\u7684\u59d3\u6c0f\u3002","type":"string","required":false},"email":{"description":"\u4f7f\u7528\u8005\u7684\u96fb\u5b50\u90f5\u4ef6\u5730\u5740\u3002","type":"string","format":"email","required":false},"url":{"description":"\u4f7f\u7528\u8005\u7684\u7db2\u5740\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u4f7f\u7528\u8005\u7684\u500b\u4eba\u8cc7\u6599\u3002","type":"string","required":false},"locale":{"description":"\u4f7f\u7528\u8005\u7684\u5730\u5340\u8a9e\u8a00\u504f\u597d\u3002","type":"string","enum":["","en_US","bg_BG","cs_CZ","de_DE","el","es_ES","fr_FR","hu_HU","it_IT","ja","nl_NL","pl_PL","pt_BR","pt_PT","ru_RU","sk_SK","sl_SI","sv_SE","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"\u4f7f\u7528\u8005\u7684\u66b1\u7a31\u3002","type":"string","required":false},"slug":{"description":"\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\u7684\u4f7f\u7528\u8005\u8b58\u5225\u78bc\u3002","type":"string","required":false},"roles":{"description":"\u6307\u6d3e\u7d66\u4f7f\u7528\u8005\u7684\u4f7f\u7528\u8005\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u4f7f\u7528\u8005\u7684\u5bc6\u78bc (\u6c38\u4e0d\u5305\u542b) \u3002","type":"string","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u65e5\u671f\u53ca\u6642\u9593\u7684\u504f\u597d\u8a2d\u5b9a\u5df2\u66f4\u65b0\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u4f7f\u7528\u8005\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u7531\u65bc [\u4f7f\u7528\u8005] \u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"reassign":{"type":"integer","description":"\u5c07\u906d\u5230\u522a\u9664\u7684\u4f7f\u7528\u8005\u7684\u6587\u7ae0\u9032\u884c\u91cd\u65b0\u6307\u6d3e\uff0c\u4e26\u5c07\u9019\u4e9b\u6587\u7ae0\u9023\u7d50\u81f3\u6307\u5b9a\u7684\u4f7f\u7528\u8005 ID\u3002","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"\u4f7f\u7528\u8005\u7684\u767b\u5165\u540d\u7a31\u3002","type":"string","required":false},"name":{"description":"\u4f7f\u7528\u8005\u7684\u986f\u793a\u540d\u7a31\u3002","type":"string","required":false},"first_name":{"description":"\u4f7f\u7528\u8005\u7684\u540d\u5b57\u3002","type":"string","required":false},"last_name":{"description":"\u4f7f\u7528\u8005\u7684\u59d3\u6c0f\u3002","type":"string","required":false},"email":{"description":"\u4f7f\u7528\u8005\u7684\u96fb\u5b50\u90f5\u4ef6\u5730\u5740\u3002","type":"string","format":"email","required":false},"url":{"description":"\u4f7f\u7528\u8005\u7684\u7db2\u5740\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u4f7f\u7528\u8005\u7684\u500b\u4eba\u8cc7\u6599\u3002","type":"string","required":false},"locale":{"description":"\u4f7f\u7528\u8005\u7684\u5730\u5340\u8a9e\u8a00\u504f\u597d\u3002","type":"string","enum":["","en_US","bg_BG","cs_CZ","de_DE","el","es_ES","fr_FR","hu_HU","it_IT","ja","nl_NL","pl_PL","pt_BR","pt_PT","ru_RU","sk_SK","sl_SI","sv_SE","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"\u4f7f\u7528\u8005\u7684\u66b1\u7a31\u3002","type":"string","required":false},"slug":{"description":"\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\u7684\u4f7f\u7528\u8005\u8b58\u5225\u78bc\u3002","type":"string","required":false},"roles":{"description":"\u6307\u6d3e\u7d66\u4f7f\u7528\u8005\u7684\u4f7f\u7528\u8005\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u4f7f\u7528\u8005\u7684\u5bc6\u78bc (\u6c38\u4e0d\u5305\u542b) \u3002","type":"string","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u65e5\u671f\u53ca\u6642\u9593\u7684\u504f\u597d\u8a2d\u5b9a\u5df2\u66f4\u65b0\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"\u7531\u65bc [\u4f7f\u7528\u8005] \u4e0d\u652f\u63f4 [\u56de\u6536\u6876] \u529f\u80fd\uff0c\u56e0\u6b64\u5fc5\u9808\u8a2d\u5b9a\u70ba true\u3002","required":false},"reassign":{"type":"integer","description":"\u5c07\u906d\u5230\u522a\u9664\u7684\u4f7f\u7528\u8005\u7684\u6587\u7ae0\u9032\u884c\u91cd\u65b0\u6307\u6d3e\uff0c\u4e26\u5c07\u9019\u4e9b\u6587\u7ae0\u9023\u7d50\u81f3\u6307\u5b9a\u7684\u4f7f\u7528\u8005 ID\u3002","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"\u7531\u61c9\u7528\u7a0b\u5f0f\u63d0\u4f9b\u3001\u7528\u65bc\u9032\u884c\u552f\u4e00\u8b58\u5225\u7684 UUID\u3002\u5efa\u8b70\u4f7f\u7528\u542b\u6709\u7db2\u5740\u6216 DNS \u547d\u540d\u7a7a\u9593\u7684 UUID v5\u3002","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"\u61c9\u7528\u7a0b\u5f0f\u5bc6\u78bc\u7684\u540d\u7a31\u3002","type":"string","minLength":1,"pattern":".*\\S.*","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"\u7531\u61c9\u7528\u7a0b\u5f0f\u63d0\u4f9b\u3001\u7528\u65bc\u9032\u884c\u552f\u4e00\u8b58\u5225\u7684 UUID\u3002\u5efa\u8b70\u4f7f\u7528\u542b\u6709\u7db2\u5740\u6216 DNS \u547d\u540d\u7a7a\u9593\u7684 UUID v5\u3002","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"\u61c9\u7528\u7a0b\u5f0f\u5bc6\u78bc\u7684\u540d\u7a31\u3002","type":"string","minLength":1,"pattern":".*\\S.*","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"after":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u5f8c\u767c\u4f48\u7684\u7559\u8a00\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u6d3e\u70ba\u6307\u5b9a\u4f7f\u7528\u8005 ID \u7684\u7559\u8a00\u3002\u9019\u9805\u64cd\u4f5c\u9700\u8981\u6388\u6b0a\u3002","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u6d3e\u70ba\u6307\u5b9a\u4f7f\u7528\u8005 ID \u7684\u7559\u8a00\u3002\u9019\u9805\u64cd\u4f5c\u9700\u8981\u6388\u6b0a\u3002","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u4f86\u81ea\u6307\u5b9a\u4f5c\u8005\u96fb\u5b50\u90f5\u4ef6\u5730\u5740\u3002\u9019\u9805\u64cd\u4f5c\u9700\u8981\u6388\u6b0a\u3002","format":"email","type":"string","required":false},"before":{"description":"\u5c07\u56de\u61c9\u9650\u5b9a\u70ba\u5728\u7b26\u5408 ISO8601 \u683c\u5f0f\u898f\u7bc4\u7684\u65e5\u671f\u6642\u9593\u524d\u767c\u4f48\u7684\u7559\u8a00\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u7559\u8a00\u5c6c\u6027\u4f86\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a\u4e0a\u5c64\u9805\u76ee ID \u7684\u7559\u8a00\u3002","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a\u4e0a\u5c64\u9805\u76ee ID\u3002","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u6d3e\u81f3\u6307\u5b9a\u6587\u7ae0 ID \u7684\u7559\u8a00\u3002","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u6d3e\u70ba\u6307\u5b9a\u72c0\u614b\u7684\u7559\u8a00\u3002\u9019\u9805\u64cd\u4f5c\u9700\u8981\u6388\u6b0a\u3002","type":"string","required":false},"type":{"default":"comment","description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u6d3e\u70ba\u6307\u5b9a\u985e\u578b\u7684\u7559\u8a00\u3002\u9019\u9805\u64cd\u4f5c\u9700\u8981\u6388\u6b0a\u3002","type":"string","required":false},"password":{"description":"\u6587\u7ae0\u53d7\u5230\u5bc6\u78bc\u4fdd\u8b77\u6642\u7684\u6587\u7ae0\u5bc6\u78bc\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"author":{"description":"\u7576\u7559\u8a00\u8005\u662f\u7db2\u7ad9\u4f7f\u7528\u8005\u6642\uff0c\u4f7f\u7528\u8005\u7269\u4ef6\u7684 ID\u3002","type":"integer","required":false},"author_email":{"description":"\u7559\u8a00\u8005\u7684\u96fb\u5b50\u90f5\u4ef6\u5730\u5740\u3002","type":"string","format":"email","required":false},"author_ip":{"description":"\u7559\u8a00\u8005\u7684 IP \u4f4d\u5740\u3002","type":"string","format":"ip","required":false},"author_name":{"description":"\u7559\u8a00\u8005\u7684\u986f\u793a\u540d\u7a31\u3002","type":"string","required":false},"author_url":{"description":"\u7559\u8a00\u8005\u7684\u7db2\u5740\u3002","type":"string","format":"uri","required":false},"author_user_agent":{"description":"\u7559\u8a00\u8005\u7684\u4f7f\u7528\u8005\u4ee3\u7406\u7a0b\u5f0f","type":"string","required":false},"content":{"description":"\u7559\u8a00\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7559\u8a00\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u7559\u8a00\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u7559\u8a00\u7684\u767c\u4f48\u65e5\u671f\u3002","type":"string","format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u7559\u8a00\u7684\u767c\u4f48\u65e5\u671f\u3002","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"\u4e0a\u5c64\u7559\u8a00\u7684 ID\u3002","type":"integer","required":false},"post":{"default":0,"description":"\u95dc\u806f\u6587\u7ae0\u7269\u4ef6\u7684 ID\u3002","type":"integer","required":false},"status":{"description":"\u7559\u8a00\u7684\u72c0\u614b\u3002","type":"string","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u8a3b\u8a18\u89e3\u6c7a\u72c0\u614b","default":"","enum":["resolved","reopen"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u7559\u8a00\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u7559\u8a00\u7684\u4e0a\u5c64\u6587\u7ae0\u7684\u5bc6\u78bc (\u82e5\u6587\u7ae0\u53d7\u5bc6\u78bc\u4fdd\u8b77)\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u7559\u8a00\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"author":{"description":"\u7576\u7559\u8a00\u8005\u662f\u7db2\u7ad9\u4f7f\u7528\u8005\u6642\uff0c\u4f7f\u7528\u8005\u7269\u4ef6\u7684 ID\u3002","type":"integer","required":false},"author_email":{"description":"\u7559\u8a00\u8005\u7684\u96fb\u5b50\u90f5\u4ef6\u5730\u5740\u3002","type":"string","format":"email","required":false},"author_ip":{"description":"\u7559\u8a00\u8005\u7684 IP \u4f4d\u5740\u3002","type":"string","format":"ip","required":false},"author_name":{"description":"\u7559\u8a00\u8005\u7684\u986f\u793a\u540d\u7a31\u3002","type":"string","required":false},"author_url":{"description":"\u7559\u8a00\u8005\u7684\u7db2\u5740\u3002","type":"string","format":"uri","required":false},"author_user_agent":{"description":"\u7559\u8a00\u8005\u7684\u4f7f\u7528\u8005\u4ee3\u7406\u7a0b\u5f0f","type":"string","required":false},"content":{"description":"\u7559\u8a00\u7684\u5167\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u5132\u5b58\u65bc\u8cc7\u6599\u5eab\u4e2d\u7684\u7559\u8a00\u5167\u5bb9\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u7559\u8a00\u7528\u65bc\u8f49\u63db\u70ba\u986f\u793a\u7528\u9014\u7684 HTML \u683c\u5f0f\u5167\u5bb9\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"\u4ee5\u9019\u500b\u7db2\u7ad9\u7684\u6642\u5340\u986f\u793a\u7559\u8a00\u7684\u767c\u4f48\u65e5\u671f\u3002","type":"string","format":"date-time","required":false},"date_gmt":{"description":"\u4ee5 GMT \u683c\u5f0f\u986f\u793a\u7559\u8a00\u7684\u767c\u4f48\u65e5\u671f\u3002","type":"string","format":"date-time","required":false},"parent":{"description":"\u4e0a\u5c64\u7559\u8a00\u7684 ID\u3002","type":"integer","required":false},"post":{"description":"\u95dc\u806f\u6587\u7ae0\u7269\u4ef6\u7684 ID\u3002","type":"integer","required":false},"status":{"description":"\u7559\u8a00\u7684\u72c0\u614b\u3002","type":"string","required":false},"meta":{"description":"\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u3002","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u8a3b\u8a18\u89e3\u6c7a\u72c0\u614b","default":"","enum":["resolved","reopen"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u7559\u8a00\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7565\u904e\u79fb\u81f3\u56de\u6536\u6876\u7684\u7a0b\u5e8f\u9032\u884c\u5f37\u5236\u522a\u9664\u3002","required":false},"password":{"description":"\u7559\u8a00\u7684\u4e0a\u5c64\u6587\u7ae0\u7684\u5bc6\u78bc (\u82e5\u6587\u7ae0\u53d7\u5bc6\u78bc\u4fdd\u8b77)\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"type":{"default":"post","description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7269\u4ef6\u985e\u578b\u7684\u9805\u76ee\u3002","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u4e00\u6216\u591a\u500b\u7269\u4ef6\u5b50\u985e\u578b\u7684\u9805\u76ee\u3002","type":"array","items":{"enum":["post","page","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"\u78ba\u4fdd\u7d50\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"\u5340\u584a\u7684\u552f\u4e00\u8a3b\u518a\u540d\u7a31\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"\u5340\u584a\u7684\u5c6c\u6027\u3002","type":"object","default":[],"required":false},"post_id":{"description":"\u6587\u7ae0\u5167\u5bb9\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"\u5340\u584a\u547d\u540d\u7a7a\u9593\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"\u5340\u584a\u547d\u540d\u7a7a\u9593\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u5340\u584a\u540d\u7a31\u3002","type":"string","required":false},"namespace":{"description":"\u5340\u584a\u547d\u540d\u7a7a\u9593\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"\u6a19\u984c","description":"\u7db2\u7ad9\u6a19\u984c\u3002","type":"string","required":false},"description":{"title":"\u7db2\u7ad9\u8aaa\u660e","description":"\u7db2\u7ad9\u8aaa\u660e\u3002","type":"string","required":false},"url":{"title":"","description":"\u7db2\u7ad9\u7db2\u5740\u3002","type":"string","format":"uri","required":false},"email":{"title":"","description":"\u9019\u500b\u96fb\u5b50\u90f5\u4ef6\u5730\u5740\u7528\u65bc\u7ba1\u7406\u76ee\u7684\u3002\u4f8b\u5982\u63a5\u6536\u65b0\u4f7f\u7528\u8005\u8a3b\u518a\u901a\u77e5\u3002","type":"string","format":"email","required":false},"timezone":{"title":"","description":"\u8207\u5c45\u5730\u76f8\u540c\u6642\u5340\u7684\u57ce\u5e02\u3002","type":"string","required":false},"date_format":{"title":"","description":"\u5168\u90e8\u65e5\u671f\u5b57\u4e32\u7684\u65e5\u671f\u683c\u5f0f\u3002","type":"string","required":false},"time_format":{"title":"","description":"\u5168\u90e8\u6642\u9593\u5b57\u4e32\u7684\u6642\u9593\u683c\u5f0f\u3002","type":"string","required":false},"start_of_week":{"title":"","description":"\u6bcf\u9031\u7684\u958b\u59cb\u65e5\u671f\u3002","type":"integer","required":false},"language":{"title":"","description":"WordPress \u5730\u5340\u8a9e\u8a00\u4ee3\u78bc\u3002","type":"string","required":false},"use_smilies":{"title":"","description":"\u81ea\u52d5\u5728\u986f\u793a\u6642\u5c07 :-) \u53ca :-P \u9019\u985e\u8868\u60c5\u7b26\u865f\u8f49\u63db\u6210\u5716\u7247\u3002","type":"boolean","required":false},"default_category":{"title":"","description":"\u9810\u8a2d\u6587\u7ae0\u5206\u985e\u3002","type":"integer","required":false},"default_post_format":{"title":"","description":"\u9810\u8a2d\u6587\u7ae0\u683c\u5f0f\u3002","type":"string","required":false},"posts_per_page":{"title":"\u6bcf\u9801\u5167\u5bb9\u986f\u793a\u6578\u91cf\u4e0a\u9650","description":"\u7db2\u7ad9\u6587\u7ae0\u9801\u9762\u6bcf\u9801\u6587\u7ae0\u986f\u793a\u6578\u91cf\u3002","type":"integer","required":false},"show_on_front":{"title":"\u986f\u793a\u65bc\u9996\u9801","description":"\u8981\u986f\u793a\u65bc\u975c\u614b\u9996\u9801\u7684\u9805\u76ee","type":"string","required":false},"page_on_front":{"title":"\u9996\u9801\u9801\u9762","description":"\u8981\u986f\u793a\u70ba\u975c\u614b\u9996\u9801\u9801\u9762\u7684\u9801\u9762 ID","type":"integer","required":false},"page_for_posts":{"title":"","description":"\u8981\u986f\u793a\u6700\u65b0\u6587\u7ae0\u9801\u9762\u7684\u9801\u9762 ID","type":"integer","required":false},"default_ping_status":{"title":"","description":"\u958b\u653e\u5176\u4ed6\u7db2\u7ad9\u5c0d\u65b0\u6587\u7ae0\u50b3\u9001\u9023\u7d50\u901a\u77e5 (\u5373\u81ea\u52d5\u5f15\u7528\u901a\u77e5\u53ca\u5f15\u7528\u901a\u77e5)\u3002","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"\u958b\u653e\u5728\u65b0\u6587\u7ae0\u4e2d\u767c\u4f48\u7559\u8a00","description":"\u958b\u653e\u4f7f\u7528\u8005\u5728\u65b0\u6587\u7ae0\u4e2d\u767c\u4f48\u7559\u8a00","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"\u6a19\u8a8c","description":"\u7db2\u7ad9\u6a19\u8a8c\u3002","type":"integer","required":false},"site_icon":{"title":"\u5716\u793a","description":"\u7db2\u7ad9\u5716\u793a\u3002","type":"integer","required":false},"aab_settings_defaults":{"title":"","description":"","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u5df2\u6307\u6d3e\u4e00\u6216\u591a\u500b\u72c0\u614b\u7684\u4f48\u666f\u4e3b\u984c\u3002","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"\u4f48\u666f\u4e3b\u984c\u6a23\u5f0f\u8868\u662f\u4f48\u666f\u4e3b\u984c\u7684\u552f\u4e00\u8b58\u5225\u65b9\u5f0f\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"status":{"description":"\u5c07\u7d50\u679c\u9650\u5236\u70ba\u5177\u6709\u6307\u5b9a\u72c0\u614b\u7684\u5916\u639b\u3002","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org \u5916\u639b\u76ee\u9304\u4ee3\u7a31\u3002","pattern":"[\\w\\-]+","required":true},"status":{"description":"\u5916\u639b\u555f\u7528\u72c0\u614b\u3002","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"\u5916\u639b\u555f\u7528\u72c0\u614b\u3002","type":"string","enum":["inactive","active"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u5df2\u8a3b\u518a\u8cc7\u8a0a\u6b04\u7684 ID\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"\u5de2\u72c0\u5c0f\u5de5\u5177\u3002","type":"array","items":{"type":["object","string"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u5c0f\u5de5\u5177\u985e\u578b ID\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u5c0f\u5de5\u5177\u985e\u578b ID\u3002","type":"string","required":true},"instance":{"description":"\u76ee\u524d\u7684\u5c0f\u5de5\u5177\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a\u3002","type":"object","required":false},"form_data":{"description":"\u5c07\u5c0f\u5de5\u5177\u8868\u55ae\u8cc7\u6599\u5e8f\u5217\u5316\u4ee5\u7de8\u78bc\u81f3\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u5c0f\u5de5\u5177\u985e\u578b ID\u3002","type":"string","required":true},"instance":{"description":"\u76ee\u524d\u7684\u5c0f\u5de5\u5177\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a\u3002","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"\u50b3\u56de\u5c0f\u5de5\u5177\u7684\u8cc7\u8a0a\u6b04\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"string","required":false},"id_base":{"description":"\u5c0f\u5de5\u5177\u7684\u985e\u578b\u3002\u9019\u6703\u8207 widget-types \u7aef\u9ede\u7684 ID \u9032\u884c\u5c0d\u61c9\u3002","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"\u5c0f\u5de5\u5177\u6240\u5c6c\u7684\u8cc7\u8a0a\u6b04\u3002","type":"string","required":true},"instance":{"description":"\u5c0f\u5de5\u5177\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a (\u53d6\u6c7a\u65bc\u662f\u5426\u652f\u63f4)\u3002","type":"object","properties":{"encoded":{"description":"\u7d93\u904e Base64 \u7de8\u78bc\u7684\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a\u8868\u793a\u65b9\u5f0f\u3002","type":"string","context":["edit"]},"hash":{"description":"\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a\u7684\u52a0\u5bc6\u7de8\u8b6f\u96dc\u6e4a\u503c\u3002","type":"string","context":["edit"]},"raw":{"description":"\u672a\u7de8\u78bc\u7684\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a (\u53d6\u6c7a\u65bc\u662f\u5426\u652f\u63f4)\u3002","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"\u5c0f\u5de5\u5177\u7ba1\u7406\u8868\u55ae\u7684 URL \u7de8\u78bc\u578b\u5f0f\u8cc7\u6599\u3002\u9019\u9805\u8cc7\u6599\u7528\u65bc\u66f4\u65b0\u4e0d\u652f\u63f4\u57f7\u884c\u500b\u9ad4\u7684\u5c0f\u5de5\u5177\u3002\u50c5\u80fd\u5beb\u5165\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"string","required":false},"id_base":{"description":"\u5c0f\u5de5\u5177\u7684\u985e\u578b\u3002\u9019\u6703\u8207 widget-types \u7aef\u9ede\u7684 ID \u9032\u884c\u5c0d\u61c9\u3002","type":"string","required":false},"sidebar":{"description":"\u5c0f\u5de5\u5177\u6240\u5c6c\u7684\u8cc7\u8a0a\u6b04\u3002","type":"string","required":false},"instance":{"description":"\u5c0f\u5de5\u5177\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a (\u53d6\u6c7a\u65bc\u662f\u5426\u652f\u63f4)\u3002","type":"object","properties":{"encoded":{"description":"\u7d93\u904e Base64 \u7de8\u78bc\u7684\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a\u8868\u793a\u65b9\u5f0f\u3002","type":"string","context":["edit"]},"hash":{"description":"\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a\u7684\u52a0\u5bc6\u7de8\u8b6f\u96dc\u6e4a\u503c\u3002","type":"string","context":["edit"]},"raw":{"description":"\u672a\u7de8\u78bc\u7684\u57f7\u884c\u500b\u9ad4\u8a2d\u5b9a (\u53d6\u6c7a\u65bc\u662f\u5426\u652f\u63f4)\u3002","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"\u5c0f\u5de5\u5177\u7ba1\u7406\u8868\u55ae\u7684 URL \u7de8\u78bc\u578b\u5f0f\u8cc7\u6599\u3002\u9019\u9805\u8cc7\u6599\u7528\u65bc\u66f4\u65b0\u4e0d\u652f\u63f4\u57f7\u884c\u500b\u9ad4\u7684\u5c0f\u5de5\u5177\u3002\u50c5\u80fd\u5beb\u5165\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"\u662f\u5426\u5f37\u5236\u79fb\u9664\u5c0f\u5de5\u5177\u6216\u5c07\u5c0f\u5de5\u5177\u79fb\u81f3\u672a\u4f7f\u7528\u7684\u8cc7\u8a0a\u6b04\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"\u5c07\u7d50\u679c\u96c6\u9650\u5b9a\u70ba\u7b26\u5408\u641c\u5c0b\u95dc\u9375\u5b57\u7684\u5340\u584a\u3002","type":"string","minLength":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","minLength":1,"required":false},"category":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u5206\u985e ID \u7684\u9805\u76ee\u3002","type":"integer","minimum":1,"required":false},"keyword":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u95dc\u9375\u5b57 ID \u7684\u9805\u76ee\u3002","type":"integer","minimum":1,"required":false},"slug":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u5340\u584a\u7248\u9762\u914d\u7f6e\u4ee3\u7a31\u7684\u9805\u76ee\u3002","type":"array","required":false},"offset":{"description":"\u5728\u9805\u76ee\u7684\u7d50\u679c\u96c6\u4e2d\u7565\u904e\u6307\u5b9a\u6578\u91cf\u7d50\u679c\u3002","type":"integer","required":false},"order":{"description":"\u6392\u5e8f\u65b9\u5f0f\u5c6c\u6027\u70ba\u905e\u589e\u6216\u905e\u6e1b\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u4f9d\u6587\u7ae0\u5c6c\u6027\u70ba\u96c6\u5408\u9032\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"\u9700\u8981\u8655\u7406\u7684\u7db2\u5740\u3002","type":"string","format":"uri","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"\u7531\u82f1\u6578\u5b57\u5143\u7d44\u6210\u7684\u9078\u55ae\u4f4d\u7f6e\u8b58\u5225\u78bc\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u529f\u80fd\u5206\u985e\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"\u529f\u80fd\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"\u529f\u80fd\u57f7\u884c\u7684\u8f38\u5165\u53c3\u6578\u3002","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7279\u5b9a\u529f\u80fd\u5206\u985e\u7684\u529f\u80fd\u3002","type":"string","required":false},"namespace":{"description":"\u5c07\u7d50\u679c\u9650\u5236\u70ba\u7279\u5b9a\u547d\u540d\u7a7a\u9593\u4e2d\u7684\u529f\u80fd\u3002","type":"string","required":false},"meta":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u6240\u6709\u6307\u5b9a\u4e2d\u7e7c\u8cc7\u6599\u6b04\u4f4d\u7684\u529f\u80fd\u3002","type":"object","properties":{"annotations":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u6307\u5b9a\u884c\u70ba\u8a3b\u89e3\u7684\u529f\u80fd\u3002","type":"object","properties":{"readonly":{"description":"\u6b64\u529f\u80fd\u662f\u5426\u4e0d\u6703\u4fee\u6539\u5176\u74b0\u5883\u3002","type":["boolean","null"]},"destructive":{"description":"\u6b64\u529f\u80fd\u662f\u5426\u53ef\u80fd\u5c0d\u5176\u74b0\u5883\u9032\u884c\u7834\u58de\u6027\u66f4\u65b0\u3002","type":["boolean","null"]},"idempotent":{"description":"\u4f7f\u7528\u76f8\u540c\u5f15\u6578\u91cd\u8907\u547c\u53eb\u6642\uff0c\u662f\u5426\u4e0d\u6703\u7522\u751f\u984d\u5916\u5f71\u97ff\u3002","type":["boolean","null"]}},"additionalProperties":true}},"additionalProperties":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u529f\u80fd\u7684\u552f\u4e00\u8b58\u5225\u78bc\u3002","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"collection":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u6307\u5b9a\u5716\u793a\u96c6\u4ee3\u7a31\u6240\u5c0d\u61c9\u7684\u5716\u793a\u3002","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<collection>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"collection":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u6307\u5b9a\u5716\u793a\u96c6\u4ee3\u7a31\u6240\u5c0d\u61c9\u7684\u5716\u793a\u3002","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/icons\/(?P<name>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?\/[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u5716\u793a\u540d\u7a31\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/icon-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u76ee\u524d\u9801\u6578\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u96c6\u4e2d\u6240\u50b3\u56de\u7684\u9805\u76ee\u6578\u76ee\u4e0a\u9650\u503c\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c07\u7d50\u679c\u9650\u5b9a\u70ba\u7b26\u5408\u689d\u4ef6\u7684\u5b57\u4e32\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/icon-collections"}]}},"\/wp\/v2\/icon-collections\/(?P<slug>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u5716\u793a\u96c6\u4ee3\u7a31\u3002","type":"string","required":false},"context":{"description":"\u5fc5\u9808\u5728\u8981\u6c42\u63d0\u51fa\u7684\u7bc4\u570d\u5167\u3001\u5fc5\u9808\u78ba\u5b9a\u56de\u61c9\u6642\u6b04\u4f4d\u986f\u793a\u7684\u65b9\u5f0f\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"\u5be6\u9ad4\u7a2e\u985e\u3002","type":"string","required":true},"name":{"description":"\u5be6\u9ad4\u540d\u7a31\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":0,"site_icon":87,"site_icon_url":"","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/www.sweethome3d.com\/zh-hant\/wp-json\/"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
