{"name":"Sweet Home 3D","description":"News and tips about Sweet Home 3D","url":"https:\/\/www.sweethome3d.com","home":"https:\/\/www.sweethome3d.com\/zh-hans\/","gmt_offset":"0","timezone_string":"","page_for_posts":387,"page_on_front":1108,"show_on_front":"page","namespaces":["oembed\/1.0","wpml\/v1","flexible-table-block\/v1","rankmath\/v1","rankmath\/v1\/setupWizard","rankmath\/v1\/an","wp-super-cache\/v1","wpml\/st\/v1","wpml\/tm\/v1","wpml\/ate\/v1","wp-smush\/v1","hub-connector\/v1","rankmath\/v1\/ai-visibility","rankmath\/v1\/ca","rankmath\/v1\/in","rankmath\/v1\/status","rankmath\/v1\/link-genius","google-site-kit\/v1","wpmudev_pcs\/v1","wpmudev_blc\/v1","regenerate-thumbnails\/v1","otgs\/installer\/v1","mcp","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/www.sweethome3d.com\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"\u9700\u8981\u83b7\u53d6 oEmbed \u6570\u636e\u7684\u94fe\u63a5\u3002","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"\u9700\u8981\u83b7\u53d6 oEmbed \u6570\u636e\u7684\u94fe\u63a5\u3002","type":"string","format":"uri","required":true},"format":{"description":"\u4f7f\u7528\u7684 oEmbed \u683c\u5f0f\u3002","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"\u5d4c\u5165\u7684\u5143\u7d20\u7684\u6700\u5927\u5bbd\u5ea6\uff08\u50cf\u7d20\uff09\u3002","type":"integer","default":600,"required":false},"maxheight":{"description":"\u5d4c\u5165\u7684\u5143\u7d20\u7684\u6700\u5927\u9ad8\u5ea6\uff08\u50cf\u7d20\uff09\u3002","type":"integer","required":false},"discover":{"description":"\u5bf9\u672a\u7ecf\u6279\u51c6\u7684\u63d0\u4f9b\u8005\u662f\u5426\u8fdb\u884c oEmbed \u53d1\u73b0\u8bf7\u6c42\u3002","type":"boolean","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/oembed\/1.0\/proxy"}]}},"\/wpml\/v1":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1"}]}},"\/wpml\/v1\/custom-xml-config":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/custom-xml-config"}]}},"\/wpml\/v1\/custom-xml-config\/validate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/custom-xml-config\/validate"}]}},"\/flexible-table-block\/v1":{"namespace":"flexible-table-block\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"flexible-table-block\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/flexible-table-block\/v1"}]}},"\/flexible-table-block\/v1\/options":{"namespace":"flexible-table-block\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/flexible-table-block\/v1\/options"}]}},"\/rankmath\/v1":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1"}]}},"\/rankmath\/v1\/saveModule":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"module":{"type":"string","description":"Module slug","required":true},"state":{"type":"string","description":"Module state either on or off","enum":["on","off"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/saveModule"}]}},"\/rankmath\/v1\/toolsAction":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"action":{"type":"string","description":"Action to perform","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/toolsAction"}]}},"\/rankmath\/v1\/updateMode":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"mode":{"type":"string","description":"Mode to set","enum":["easy","advanced","custom"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/updateMode"}]}},"\/rankmath\/v1\/dashboardWidget":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/dashboardWidget"}]}},"\/rankmath\/v1\/updateSeoScore":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"postScores":{"type":"object","description":"Post scores","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/updateSeoScore"}]}},"\/rankmath\/v1\/updateSettings":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/updateSettings"}]}},"\/rankmath\/v1\/searchPage":{"namespace":"rankmath\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/searchPage"}]}},"\/rankmath\/v1\/disconnectSite":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"token":{"type":"string","description":"Site token","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/disconnectSite"}]}},"\/rankmath\/v1\/getFeaturedImageId":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"postId":{"type":"integer","description":"Post ID","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/getFeaturedImageId"}]}},"\/rankmath\/v1\/updateRedirection":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectID":{"type":"integer","description":"Object unique id","required":true},"objectType":{"type":"string","default":"post","description":"Object Type i.e. post, term, user","required":true},"hasRedirect":{"type":"boolean","description":"Whether the object has a redirect or not","required":true},"redirectionID":{"type":"string","description":"Redirection ID","required":false},"redirectionUrl":{"type":"string","description":"Redirection URL","required":false},"redirectionType":{"type":"string","default":"301","description":"Redirection Type","enum":["301","302","307","410","451"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/updateRedirection"}]}},"\/rankmath\/v1\/updateMeta":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectType":{"type":"string","description":"Object Type i.e. post, term, user","required":true},"objectID":{"type":"integer","description":"Object unique id","required":true},"meta":{"description":"Meta to add or update data.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/updateMeta"}]}},"\/rankmath\/v1\/updateSchemas":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectType":{"type":"string","description":"Object Type i.e. post, term, user","required":true},"objectID":{"type":"integer","description":"Object unique id","required":true},"schemas":{"description":"schemas to add or update data.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/updateSchemas"}]}},"\/rankmath\/v1\/updateMetaBulk":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"rows":{"description":"Selected posts to update the data for.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/updateMetaBulk"}]}},"\/rankmath\/v1\/setupWizard":{"namespace":"rankmath\/v1\/setupWizard","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/setupWizard","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/setupWizard"}]}},"\/rankmath\/v1\/setupWizard\/getStepData":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step":{"type":"string","description":"Current Step","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/setupWizard\/getStepData"}]}},"\/rankmath\/v1\/setupWizard\/updateStepData":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step":{"type":"string","description":"Current Step","required":true},"value":{"type":"object","description":"Current Step Data","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/setupWizard\/updateStepData"}]}},"\/rankmath\/v1\/setupWizard\/updateTrackingOptin":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"enable_tracking":{"type":"string","description":"Enable Tracking","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/setupWizard\/updateTrackingOptin"}]}},"\/rankmath\/v1\/saveTemplate":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postId":{"type":"integer","description":"Post ID.","required":false},"schema":{"type":"object","description":"Schema data.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/saveTemplate"}]}},"\/rankmath\/v1\/getVideoData":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectID":{"type":"integer","description":"Object unique id","required":true},"url":{"description":"Video URL.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/getVideoData"}]}},"\/rankmath\/v1\/an":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/an","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an"}]}},"\/rankmath\/v1\/an\/getKeywordPages":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"query":{"description":"Query to search.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/getKeywordPages"}]}},"\/rankmath\/v1\/an\/postsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/postsOverview"}]}},"\/rankmath\/v1\/an\/getTrackedKeywords":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/getTrackedKeywords"}]}},"\/rankmath\/v1\/an\/getTrackedKeywordsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Keyword to search.","type":"string","default":"","required":false},"orderby":{"default":"default","enum":["default","keyword"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/getTrackedKeywordsRows"}]}},"\/rankmath\/v1\/an\/getTrackedKeywordSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/getTrackedKeywordSummary"}]}},"\/rankmath\/v1\/an\/trackedKeywordsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/trackedKeywordsOverview"}]}},"\/rankmath\/v1\/an\/addTrackKeyword":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"keyword":{"description":"Keyword to add.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/addTrackKeyword"}]}},"\/rankmath\/v1\/an\/autoAddFocusKeywords":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"data":{"description":"Data to add.","type":"object","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/autoAddFocusKeywords"}]}},"\/rankmath\/v1\/an\/removeTrackKeyword":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc","ASC","DESC"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/removeTrackKeyword"}]}},"\/rankmath\/v1\/an\/deleteTrackedKeywords":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/deleteTrackedKeywords"}]}},"\/rankmath\/v1\/an\/getDesktopPagespeed":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"id":{"description":"Record id.","type":"integer","default":0,"required":false},"objectID":{"description":"Post id.","type":"integer","default":0,"required":false},"force":{"description":"Force update pagespeed.","type":"boolean","default":false,"required":false},"isAdminBar":{"description":"Is admin bar.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/getDesktopPagespeed"}]}},"\/rankmath\/v1\/an\/getMobilePagespeed":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"id":{"description":"Record id.","type":"integer","default":0,"required":false},"objectID":{"description":"Post id.","type":"integer","default":0,"required":false},"force":{"description":"Force update pagespeed.","type":"boolean","default":false,"required":false},"isAdminBar":{"description":"Is admin bar.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/getMobilePagespeed"}]}},"\/rankmath\/v1\/an\/getPageSEOScore":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"id":{"description":"Record id.","type":"integer","default":0,"required":false},"objectID":{"description":"Post id.","type":"integer","default":0,"required":false},"force":{"description":"Force update pagespeed.","type":"boolean","default":false,"required":false},"isAdminBar":{"description":"Is admin bar.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/getPageSEOScore"}]}},"\/rankmath\/v1\/an\/postsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/postsRows"}]}},"\/rankmath\/v1\/an\/inspectionStats":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/inspectionStats"}]}},"\/rankmath\/v1\/pingSettings":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"apiKey":{"description":"API Key.","type":"string","required":true},"username":{"description":"Username.","type":"string","required":true},"plan":{"description":"Plan.","type":"string","required":true},"keywords":{"description":"Keywords.","type":"string","required":true},"settings":{"description":"Settings.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/pingSettings"}]}},"\/rankmath\/v1\/searchIntent":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"The keyword used to determine the intent.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/searchIntent"}]}},"\/rankmath\/v1\/importCSV":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/importCSV"}]}},"\/rankmath\/v1\/cancelCsvImport":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/cancelCsvImport"}]}},"\/wp-super-cache\/v1":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-super-cache\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-super-cache\/v1"}]}},"\/wp-super-cache\/v1\/settings":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-super-cache\/v1\/settings"}]}},"\/wp-super-cache\/v1\/status":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-super-cache\/v1\/status"}]}},"\/wp-super-cache\/v1\/stats":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-super-cache\/v1\/stats"}]}},"\/wp-super-cache\/v1\/cache":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-super-cache\/v1\/cache"}]}},"\/wp-super-cache\/v1\/preload":{"namespace":"wp-super-cache\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-super-cache\/v1\/preload"}]}},"\/wp-super-cache\/v1\/cache\/test":{"namespace":"wp-super-cache\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-super-cache\/v1\/cache\/test"}]}},"\/wp-super-cache\/v1\/plugins":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-super-cache\/v1\/plugins"}]}},"\/wpml\/st\/v1":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/st\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/st\/v1"}]}},"\/wpml\/st\/v1\/strings\/settings":{"namespace":"wpml\/st\/v1","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"autoregisterType":{"type":"integer","default":0,"required":false},"shouldRegisterBackendStrings":{"type":"integer","default":0,"required":false},"setNoticeThatCachePluginCanBlockAutoregisterAsDismissed":{"type":"integer","default":0,"required":false},"setDetectStringsInJS":{"type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/st\/v1\/strings\/settings"}]}},"\/wpml\/st\/v1\/strings\/itemscount":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/st\/v1\/strings\/itemscount"}]}},"\/wpml\/st\/v1\/strings":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/st\/v1\/strings"}]}},"\/wpml\/st\/v1\/strings\/filters":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/st\/v1\/strings\/filters"}]}},"\/wpml\/st\/v1\/string-packages":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/st\/v1\/string-packages"}]}},"\/wpml\/st\/v1\/strings\/processstringsqueue":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/st\/v1\/strings\/processstringsqueue"}]}},"\/wpml\/tm\/v1":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/tm\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/store":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_job_id":{"type":"string","required":true},"ate_job_data":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/store"}]}},"\/wpml\/tm\/v1\/xliff\/fetch\/(?P<jobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/ams\/register_manager":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/register_manager"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/translators":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/translators"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/managers":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/managers"}]}},"\/wpml\/tm\/v1\/ams\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/status"}]}},"\/wpml\/tm\/v1\/ams\/console":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/console"}]}},"\/wpml\/tm\/v1\/ams\/engines":{"namespace":"wpml\/tm\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/engines"}]}},"\/wpml\/tm\/v1\/ate\/jobs":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ate\/jobs"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/jobs":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"local_job_ids":{"type":"string","required":false},"scope":{"type":"string","required":false},"id":{"type":"integer","required":false},"title":{"type":"string","required":false},"source_language":{"type":"string","required":false},"target_language":{"type":"string","required":false},"status":{"type":"string","required":false},"needs_update":{"type":"string","required":false},"limit":{"type":"integer","required":false},"offset":{"type":"integer","required":false},"sorting":{"required":false},"translated_by":{"type":"string","required":false},"sent_from":{"type":"string","required":false},"sent_to":{"type":"string","required":false},"deadline_from":{"type":"string","required":false},"deadline_to":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/jobs"}]}},"\/wpml\/tm\/v1\/jobs\/assign":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"jobId":{"required":true},"type":{"required":false},"translatorId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/jobs\/assign"}]}},"\/wpml\/tm\/v1\/jobs\/cancel":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/jobs\/cancel"}]}},"\/wpml\/tm\/v1\/tp\/xliff\/download\/(?P<job_id>\\d+)\/(?P<job_type>\\w+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"job_id":{"required":true},"job_type":{"required":true},"json":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/tp\/apply-translations":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/tp\/apply-translations"}]}},"\/wpml\/tm\/v1\/tp\/batches\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batchId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/tp\/batches\/sync"}]}},"\/wpml\/tm\/v1\/tp\/batches\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/tp\/batches\/status"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"lockKey":{"type":"string","required":false},"ateToken":{"type":"string","required":false},"page":{"type":"int","required":false},"numberOfPages":{"type":"int","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/sync"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/download":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/download"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/retry":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/retry"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/receive\/(?P<wpmlJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpmlJobId":{"type":"int","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)\/fix":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/ate\/v1":{"namespace":"wpml\/ate\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/ate\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/ate\/v1"}]}},"\/wpml\/ate\/v1\/ate\/proxy":{"namespace":"wpml\/ate\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/ate\/v1\/ate\/proxy"}]}},"\/wpml\/st\/v1\/import_mo_strings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"type":"array","required":false},"themes":{"type":"array","required":false},"other":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/st\/v1\/import_mo_strings"}]}},"\/wpml\/st\/v1\/pre_generate_mo_files":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/st\/v1\/pre_generate_mo_files"}]}},"\/wpml\/st\/v1\/settings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"group":{"required":true},"key":{"required":true},"data":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/st\/v1\/settings"}]}},"\/wpml\/v1\/updates":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/updates"}]}},"\/wpml\/v1\/troubleshooting\/posthog":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/troubleshooting\/posthog"}]}},"\/wpml\/v1\/troubleshooting\/enable-alias-domain":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/troubleshooting\/enable-alias-domain"}]}},"\/wpml\/v1\/troubleshooting\/reset-alias-domain":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/troubleshooting\/reset-alias-domain"}]}},"\/wpml\/v1\/item-sections\/populated":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/item-sections\/populated"}]}},"\/wpml\/v1\/posts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/posts"}]}},"\/wpml\/v1\/posts\/count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/posts\/count"}]}},"\/wpml\/v1\/send-to-translation\/validate-translation-options":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/send-to-translation\/validate-translation-options"}]}},"\/wpml\/v1\/send-to-translation\/default-batch-name":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/send-to-translation\/default-batch-name"}]}},"\/wpml\/v1\/send-to-translation\/validate-batch-name":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/send-to-translation\/validate-batch-name"}]}},"\/wpml\/v1\/set-review-translation-option":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/set-review-translation-option"}]}},"\/wpml\/v1\/posts\/hierarchical":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/posts\/hierarchical"}]}},"\/wpml\/v1\/posts\/taxonomies":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/posts\/taxonomies"}]}},"\/wpml\/v1\/posts\/terms":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/posts\/terms"}]}},"\/wpml\/v1\/translate-everything\/enable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/translate-everything\/enable"}]}},"\/wpml\/v1\/translate-everything\/disable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/translate-everything\/disable"}]}},"\/wpml\/v1\/cancelallautomaticjobs":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/cancelallautomaticjobs"}]}},"\/wpml\/v1\/getuntranslatedtypescount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/getuntranslatedtypescount"}]}},"\/wpml\/v1\/save-translator-note":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/save-translator-note"}]}},"\/wpml\/v1\/credits":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/credits"}]}},"\/wpml\/v1\/translation-proxy\/commit-batch":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/translation-proxy\/commit-batch"}]}},"\/wpml\/v1\/tranlsation-proxy\/getlastpickedup":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/tranlsation-proxy\/getlastpickedup"}]}},"\/wpml\/v1\/translation-proxy\/getRemoteJobsCount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/translation-proxy\/getRemoteJobsCount"}]}},"\/wpml\/v1\/gettranslationstatus":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/gettranslationstatus"}]}},"\/wpml\/v1\/getlocaltranslatorbyid":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/getlocaltranslatorbyid"}]}},"\/wpml\/v1\/reloadremotetranslationservice":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/reloadremotetranslationservice"}]}},"\/wpml\/v1\/gettranslationeditortype":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/gettranslationeditortype"}]}},"\/wpml\/v1\/translate-existing-content":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/translate-existing-content"}]}},"\/wpml\/v1\/get-needs-update-count-created-in-cte":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/get-needs-update-count-created-in-cte"}]}},"\/wpml\/v1\/get-engines":{"namespace":"wpml\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/get-engines"}]}},"\/wpml\/v1\/website-contexts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/website-contexts"}]}},"\/wpml\/v1\/has-posts-using-native-editor":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/has-posts-using-native-editor"}]}},"\/wpml\/v1\/get-credits-per-word":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/get-credits-per-word"}]}},"\/wpml\/v1\/get-words-to-translate-for-items":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/get-words-to-translate-for-items"}]}},"\/wpml\/v1\/get-words-to-translate-for-types":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/get-words-to-translate-for-types"}]}},"\/wpml\/v1\/save-automatic-translation-settings":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/save-automatic-translation-settings"}]}},"\/wpml\/v1\/getlocaltranslators":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/getlocaltranslators"}]}},"\/wpml\/v1\/account-balances":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/account-balances"}]}},"\/wpml\/v1\/glossary-count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/glossary-count"}]}},"\/wpml\/v1\/enable-ate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/enable-ate"}]}},"\/wpml\/v1\/get-dismissed-notices":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/get-dismissed-notices"}]}},"\/wpml\/v1\/minimum-requirements":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/minimum-requirements"}]}},"\/wpml\/v1\/rest\/status":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/rest\/status"}]}},"\/wpml\/v1\/dismiss-notice":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/dismiss-notice"}]}},"\/wpml\/v1\/dismiss-notice-per-user":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/dismiss-notice-per-user"}]}},"\/wpml\/v1\/cancel-jobs":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/cancel-jobs"}]}},"\/wpml\/v1\/unsolvable-jobs":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/unsolvable-jobs"}]}},"\/wpml\/v1\/resend-unsolvable-jobs":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/resend-unsolvable-jobs"}]}},"\/wpml\/v1\/wpml\/posthog\/capture-event":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/wpml\/posthog\/capture-event"}]}},"\/wpml\/v1\/capture\/event":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/capture\/event"}]}},"\/wpml\/v1\/wpml-proxy\/status":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/wpml-proxy\/status"}]}},"\/wpml\/v1\/wpml-content-stats":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/wpml-content-stats"}]}},"\/wpml\/v1\/wpml-ph-make-external-request":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpml\/v1\/wpml-ph-make-external-request"}]}},"\/wp-smush\/v1":{"namespace":"wp-smush\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-smush\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-smush\/v1"}]}},"\/wp-smush\/v1\/preset_configs":{"namespace":"wp-smush\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-smush\/v1\/preset_configs"}]}},"\/hub-connector\/v1":{"namespace":"hub-connector\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"hub-connector\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/hub-connector\/v1"}]}},"\/hub-connector\/v1\/sync":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"force":{"description":"Should do a force sync.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/hub-connector\/v1\/sync"}]}},"\/hub-connector\/v1\/logout":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/hub-connector\/v1\/logout"}]}},"\/rankmath\/v1\/ai-visibility":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/ai-visibility","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ai-visibility"}]}},"\/rankmath\/v1\/ai-visibility\/overview":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"refresh":{"description":"Force a refresh from the AI Visibility API.","type":"boolean","default":false,"required":false},"search":{"description":"Filter brands by name or URL.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ai-visibility\/overview"}]}},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"name":{"type":"string","required":false},"url":{"type":"string","required":false},"description":{"type":"string","required":false},"locale":{"type":"string","required":false},"language":{"type":"string","enum":["","US English","UK English","Arabic","Bulgarian","Chinese","Czech","Danish","Dutch","Estonian","Finnish","French","German","Greek","Hebrew","Hungarian","Indonesian","Italian","Japanese","Korean","Latvian","Lithuanian","Norwegian","Polish","Portuguese","Romanian","Russian","Slovak","Slovenian","Spanish","Swedish","Turkish"],"required":false},"status":{"type":"string","enum":["active","inactive"],"required":false},"interval":{"type":"string","enum":["daily","weekly","monthly"],"required":false},"platforms":{"description":"AI platforms to track for this brand. Supported values: \"chatgpt\", \"gemini\". Tracking more than one platform per brand requires the Expert plan.","type":"array","minItems":1,"items":{"type":"string","enum":["chatgpt","gemini"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"name":{"description":"Brand name.","type":"string","required":true},"url":{"description":"Brand website URL or domain.","type":"string","required":true},"description":{"description":"Short description of the brand or product.","type":"string","required":true},"locale":{"description":"ISO 3166-1 alpha-2 country code (e.g. &quot;US&quot;, &quot;HU&quot;).","type":"string","required":false},"language":{"description":"Output language to use when analyzing\/generating content for this brand. Independent of `locale` (target country). Required; immutable after creation.","type":"string","enum":["US English","UK English","Arabic","Bulgarian","Chinese","Czech","Danish","Dutch","Estonian","Finnish","French","German","Greek","Hebrew","Hungarian","Indonesian","Italian","Japanese","Korean","Latvian","Lithuanian","Norwegian","Polish","Portuguese","Romanian","Russian","Slovak","Slovenian","Spanish","Swedish","Turkish"],"required":true},"interval":{"description":"Analysis refresh cadence. Omitted \u2192 backend applies the account plan&#039;s default.","type":"string","enum":["daily","weekly","monthly"],"required":false},"platforms":{"description":"AI platforms to track for this brand. Supported values: \"chatgpt\", \"gemini\". Tracking more than one platform per brand requires the Expert plan.","type":"array","minItems":1,"items":{"type":"string","enum":["chatgpt","gemini"]},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ai-visibility\/brands"}]}},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/insights":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/queries":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/queries\/(?P<qid>[a-zA-Z0-9\\-]+)":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"qid":{"description":"Query UUID.","type":"string","required":true},"enabled":{"description":"Whether the query is enabled for analysis.","type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/generate-queries":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/trial\/activate":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ai-visibility\/trial\/activate"}]}},"\/rankmath\/v1\/ai-visibility\/checkout-url":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ai-visibility\/checkout-url"}]}},"\/rankmath\/v1\/ca":{"namespace":"rankmath\/v1\/ca","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/ca","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca"}]}},"\/rankmath\/v1\/ca\/researchKeyword":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"The keyword to be researched.","type":"string","required":true},"country":{"description":"The country for which the keyword should be researched.","type":"string","required":true},"objectID":{"description":"The ID of the post initiating the keyword research request.","type":"integer","required":true},"force_update":{"description":"If true, forces a fresh research request.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/researchKeyword"}]}},"\/rankmath\/v1\/ca\/getCredits":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/getCredits"}]}},"\/rankmath\/v1\/ca\/createPost":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"content":{"description":"The content of the new post.","type":"string","required":true},"title":{"description":"The title of the new post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/createPost"}]}},"\/rankmath\/v1\/ca\/saveOutput":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"outputs":{"description":"An array of AI-generated and existing outputs to be saved.","type":"array","required":false},"endpoint":{"description":"The API endpoint for which the output was generated.","type":"string","required":false},"isChat":{"description":"Indicates if the request was for the Chat endpoint.","type":"boolean","required":false},"attributes":{"description":"The parameters used to generate the AI output.","type":"object","required":false},"credits":{"description":"Credit usage details returned by the API.","type":"object","required":false},"usage":{"description":"Per-tool usage data returned by the API.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/saveOutput"}]}},"\/rankmath\/v1\/ca\/deleteOutput":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"isChat":{"description":"Indicates if the request to delete the output was for the Chat endpoint.","type":"boolean","required":false},"index":{"description":"The output index to delete, applicable only to the Chat endpoint.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/deleteOutput"}]}},"\/rankmath\/v1\/ca\/updateRecentPrompt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompt":{"description":"The selected prompt to be updated in the recent prompts.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/updateRecentPrompt"}]}},"\/rankmath\/v1\/ca\/updatePrompt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompt":{"description":"The prompt data to be saved in the database.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/updatePrompt"}]}},"\/rankmath\/v1\/ca\/savePrompts":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompts":{"description":"A list of prompts received from the API to be saved in the database.","type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/savePrompts"}]}},"\/rankmath\/v1\/ca\/pingContentAI":{"namespace":"rankmath\/v1\/ca","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"plan":{"description":"Rank Math AI plan to update in the Database.","type":"string","required":true},"refreshDate":{"description":"Content AI reset date to update in the Database","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/pingContentAI"}]}},"\/rankmath\/v1\/ca\/generateAlt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"attachmentIds":{"description":"List of attachment IDs for which to generate alt text.","type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/generateAlt"}]}},"\/rankmath\/v1\/ca\/updateCredits":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"credits":{"description":"Credit usage details returned by the API.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/ca\/updateCredits"}]}},"\/rankmath\/v1\/an\/dashboard":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/dashboard"}]}},"\/rankmath\/v1\/an\/keywordsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/keywordsOverview"}]}},"\/rankmath\/v1\/an\/postsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/postsSummary"}]}},"\/rankmath\/v1\/an\/postsRowsByObjects":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","required":false},"per_page":{"description":"Results per page.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/postsRowsByObjects"}]}},"\/rankmath\/v1\/an\/post\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Post ID.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/an\/keywordsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/keywordsSummary"}]}},"\/rankmath\/v1\/an\/analyticsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"postType":{"description":"Post Type.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/analyticsSummary"}]}},"\/rankmath\/v1\/an\/keywordsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","required":false},"perPage":{"description":"Results per page.","type":"integer","required":false},"orderBy":{"description":"Order by.","type":"string","required":false},"order":{"description":"Order.","type":"string","required":false},"search":{"description":"Search.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/keywordsRows"}]}},"\/rankmath\/v1\/an\/userPreferences":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"preferences":{"description":"User preferences.","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/userPreferences"}]}},"\/rankmath\/v1\/an\/inspectionResults":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","required":false},"perPage":{"description":"Results per page.","type":"integer","required":false},"orderBy":{"description":"Order by.","type":"string","required":false},"order":{"description":"Order.","type":"string","required":false},"search":{"description":"Search.","type":"string","required":false},"filter":{"description":"Filter.","type":"string","required":false},"filterType":{"description":"Filter type.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/inspectionResults"}]}},"\/rankmath\/v1\/an\/removeFrontendStats":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"toggleBar":{"description":"Toggle bar.","type":"boolean","required":false},"hide":{"description":"Hide.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/an\/removeFrontendStats"}]}},"\/rankmath\/v1\/in":{"namespace":"rankmath\/v1\/in","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/in","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/in"}]}},"\/rankmath\/v1\/in\/submitUrls":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"urls":{"description":"The list of urls to submit to the Instant Indexing API.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/in\/submitUrls"}]}},"\/rankmath\/v1\/in\/getLog":{"namespace":"rankmath\/v1\/in","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filter":{"description":"Filter log by type.","type":"string","enum":["all","manual","auto"],"default":"all","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/in\/getLog"}]}},"\/rankmath\/v1\/in\/clearLog":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filter":{"description":"Clear log by type.","type":"string","enum":["all","manual","auto"],"default":"all","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/in\/clearLog"}]}},"\/rankmath\/v1\/in\/resetKey":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/in\/resetKey"}]}},"\/rankmath\/v1\/links\/posts":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"Search in post title.","type":"string","default":"","required":false},"post_type":{"description":"Filter by post type. Supports multiple values.","type":"array","items":{"type":"string"},"default":[],"required":false},"is_orphan":{"description":"Filter by orphan status (orphan, linked).","type":"string","default":"","required":false},"seo_score_range":{"description":"Filter by SEO score range (great, good, bad, no-score).","type":"string","default":"","required":false},"post_id":{"description":"Filter by post ID.","type":"integer","default":0,"required":false},"orderby":{"description":"Order by field.","type":"string","default":"post_title","required":false},"order":{"description":"Order direction (ASC, DESC).","type":"string","default":"ASC","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/links\/posts"}]}},"\/rankmath\/v1\/links\/posts-stats":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/links\/posts-stats"}]}},"\/rankmath\/v1\/links\/links":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"Search in URL.","type":"string","default":"","required":false},"source_id":{"description":"Filter by source post ID.","type":"integer","default":0,"required":false},"target_post_id":{"description":"Filter by target post ID.","type":"integer","default":0,"required":false},"is_internal":{"description":"Filter by link type (1 = internal, 0 = external).","type":"string","default":"","required":false},"orderby":{"description":"Order by field.","type":"string","default":"id","required":false},"order":{"description":"Order direction (ASC, DESC).","type":"string","default":"DESC","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/links\/links"}]}},"\/rankmath\/v1\/links\/links-stats":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/links\/links-stats"}]}},"\/rankmath\/v1\/status":{"namespace":"rankmath\/v1\/status","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/status","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/status"}]}},"\/rankmath\/v1\/status\/getViewData":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/status\/getViewData"}]}},"\/rankmath\/v1\/status\/updateViewData":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/status\/updateViewData"}]}},"\/rankmath\/v1\/status\/importSettings":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/status\/importSettings"}]}},"\/rankmath\/v1\/status\/exportSettings":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/status\/exportSettings"}]}},"\/rankmath\/v1\/status\/runBackup":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/status\/runBackup"}]}},"\/rankmath\/v1\/link-genius":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/link-genius","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius"}]}},"\/rankmath\/v1\/link-genius\/links":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"source_id":{"description":"Filter by source post ID.","type":"integer","default":0,"required":false},"target_post_id":{"description":"Filter by target post ID.","type":"integer","default":0,"required":false},"is_internal":{"description":"Filter by link type.","type":"string","default":"","required":false},"is_nofollow":{"description":"Filter by nofollow status.","type":"string","default":"","required":false},"anchor_type":{"description":"Filter by anchor type (HPLNK, CNCL, HLANG, IMAGE).","type":"string","default":"","required":false},"target_blank":{"description":"Filter by target blank status.","type":"string","default":"","required":false},"search":{"description":"Search in anchor text or URL.","type":"string","default":"","required":false},"orderby":{"description":"Order by field.","type":"string","default":"created_at","required":false},"order":{"description":"Order direction.","type":"string","default":"DESC","required":false},"status_code":{"description":"Filter by HTTP status code (e.g., 404). Supports multiple values.","type":"array","items":{"type":"string"},"default":[],"required":false},"status_category":{"description":"Filter by status category (2xx, 3xx, 4xx, 5xx, timeout, error).","type":"string","default":"","required":false},"is_broken":{"description":"Filter broken links (4xx, 5xx, timeout, error).","type":"boolean","default":false,"required":false},"is_success":{"description":"Filter successful links (2xx).","type":"boolean","default":false,"required":false},"is_redirect":{"description":"Filter redirect links (3xx).","type":"string","default":"","required":false},"robots_blocked":{"description":"Filter links blocked by robots.txt.","type":"string","default":"","required":false},"unchecked":{"description":"Filter unchecked links (no status data).","type":"string","default":"","required":false},"is_marked_safe":{"description":"Filter links marked as safe.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/links"}]}},"\/rankmath\/v1\/link-genius\/links\/(?P<id>\\d+)\/details":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Link ID.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/delete":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_ids":{"description":"Link IDs to delete.","type":"array","required":false},"filters":{"description":"Filter criteria for selecting links to delete.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/delete"}]}},"\/rankmath\/v1\/link-genius\/undo-delete":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID to restore.","type":"integer","required":true},"original_content":{"description":"Original post content to restore.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/undo-delete"}]}},"\/rankmath\/v1\/link-genius\/remove-nofollow":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_id":{"description":"Link ID to remove nofollow from.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/remove-nofollow"}]}},"\/rankmath\/v1\/link-genius\/update":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_id":{"description":"Link ID to update.","type":"integer","required":true},"new_url":{"description":"New URL for the link.","type":"string","required":true},"new_anchor":{"description":"New anchor text for the link.","type":"string","required":true},"is_nofollow":{"description":"Whether the link should have nofollow attribute.","type":"integer","default":0,"required":false},"target_blank":{"description":"Whether the link should open in a new tab.","type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/update"}]}},"\/rankmath\/v1\/link-genius\/bulk-actions\/restore":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batch_id":{"description":"Batch ID to restore from snapshots.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/bulk-actions\/restore"}]}},"\/rankmath\/v1\/link-genius\/link-suggestions":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID.","type":"integer","required":true},"text":{"description":"Selected text used for suggestions.","type":"string","required":false},"current":{"description":"Current editor state summary.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/link-suggestions"}]}},"\/rankmath\/v1\/link-genius\/link-opportunities":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID.","type":"integer","required":true},"current":{"description":"Current editor state summary.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/link-opportunities"}]}},"\/rankmath\/v1\/link-genius\/related-posts":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID.","type":"integer","required":true},"current":{"description":"Current editor state summary.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/related-posts"}]}},"\/rankmath\/v1\/link-genius\/audit\/stats":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/audit\/stats"}]}},"\/rankmath\/v1\/link-genius\/audit\/start":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filters":{"description":"Filters to apply (is_internal, unchecked_only, etc.).","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/audit\/start"}]}},"\/rankmath\/v1\/link-genius\/audit\/recheck":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_ids":{"description":"Array of link IDs to recheck.","type":"array","required":false},"filters":{"description":"Filter criteria for selecting links to recheck.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/audit\/recheck"}]}},"\/rankmath\/v1\/link-genius\/audit\/mark-safe":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_ids":{"description":"Link IDs to mark as safe.","type":"array","required":false},"reason":{"description":"Reason for marking as safe.","type":"string","required":false},"filters":{"description":"Filter criteria for selecting links to mark as safe.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/audit\/mark-safe"}]}},"\/rankmath\/v1\/link-genius\/export":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"description":"Export type (links or posts).","type":"string","required":true},"format":{"description":"Export format (csv, json, excel).","type":"string","required":true},"filters":{"description":"Filters to apply to the export.","type":"object","required":false},"columns":{"description":"Column definitions.","type":"array","required":true},"total":{"description":"Total number of records to export.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/export"}]}},"\/rankmath\/v1\/link-genius\/posts":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"Search in post title.","type":"string","default":"","required":false},"post_type":{"description":"Filter by post type. Supports multiple values.","type":"array","items":{"type":"string"},"default":[],"required":false},"is_orphan":{"description":"Filter by orphan status.","type":"string","default":"","required":false},"seo_score_range":{"description":"Filter by SEO score range.","type":"string","default":"","required":false},"orderby":{"description":"Order by field.","type":"string","default":"post_title","required":false},"order":{"description":"Order direction.","type":"string","default":"ASC","required":false},"min_incoming_links":{"description":"Minimum incoming links count filter.","type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/posts"}]}},"\/rankmath\/v1\/link-genius\/posts-stats":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/posts-stats"}]}},"\/rankmath\/v1\/link-genius\/stats":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/stats"}]}},"\/rankmath\/v1\/link-genius\/regenerate":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/regenerate"}]}},"\/rankmath\/v1\/link-genius\/operations\/progress":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"operation":{"description":"Operation type.","type":"string","enum":["regenerate","audit","bulk_delete","bulk_mark_safe","bulk_restore","bulk_update_preview","bulk_update_apply","keyword_map_preview","keyword_map_apply","export"],"required":true},"id":{"description":"Optional operation ID (for keyword maps).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/operations\/progress"}]}},"\/rankmath\/v1\/link-genius\/operations\/cancel":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"operation":{"description":"Operation type to cancel.","type":"string","enum":["regenerate","audit","bulk_delete","bulk_mark_safe","bulk_restore","bulk_update_preview","bulk_update_apply","keyword_map_preview","keyword_map_apply","export"],"required":true},"id":{"description":"Optional operation ID (for keyword maps).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/operations\/cancel"}]}},"\/rankmath\/v1\/link-genius\/operations\/clear":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"operation":{"description":"Operation type to clear.","type":"string","enum":["regenerate","audit","bulk_delete","bulk_mark_safe","bulk_restore","bulk_update_preview","bulk_update_apply","keyword_map_preview","keyword_map_apply","export"],"required":true},"id":{"description":"Optional operation ID (for keyword maps).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/operations\/clear"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/preview":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filters":{"description":"Search filters for finding links.","type":"object","required":true},"update_config":{"description":"Update configuration.","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/preview"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/preview\/results":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/preview\/results"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/history":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/history"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/history\/(?P<batch_id>[a-zA-Z0-9_]+)":{"namespace":"rankmath\/v1\/link-genius","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"batch_id":{"description":"Batch ID to delete.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/bulk-update\/apply":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filters":{"description":"Search filters for finding links.","type":"object","required":true},"update_config":{"description":"Update configuration.","type":"object","required":true},"selected_link_ids":{"description":"Optional array of specific link IDs to update.","type":"array","items":{"type":"integer"},"required":false},"is_rollback":{"description":"Whether this is a rollback operation (prevents history creation).","type":"boolean","default":false,"required":false},"rollback_batch_id":{"description":"Batch ID being rolled back (for status update).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/apply"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/rollback":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batch_id":{"description":"Batch ID to rollback.","type":"string","required":true},"selected_post_ids":{"description":"Optional array of specific post IDs to rollback.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/rollback"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/changes\/(?P<batch_id>[a-zA-Z0-9_]+)":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"batch_id":{"description":"Batch ID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/preview":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/preview\/results":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"keyword_map_id":{"description":"Keyword map ID.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/preview\/results"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/history":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/history"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps":{"namespace":"rankmath\/v1\/link-genius","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"orderby":{"description":"Column to order by.","type":"string","default":"created_at","enum":["id","name","created_at","updated_at","last_executed_at","execution_count"],"required":false},"order":{"description":"Order direction.","type":"string","default":"DESC","enum":["ASC","DESC"],"required":false},"enabled":{"description":"Filter by enabled status.","type":"boolean","required":false},"search":{"description":"Search term.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Keyword map name.","type":"string","required":true},"description":{"description":"Keyword map description.","type":"string","required":false},"target_url":{"description":"Target URL.","type":"string","required":true},"is_enabled":{"description":"Whether the keyword map is enabled.","type":"boolean","default":true,"required":false},"max_links_per_post":{"description":"Maximum links per post.","type":"integer","default":3,"minimum":1,"required":false},"auto_link_on_publish":{"description":"Enable auto-linking on publish.","type":"boolean","default":false,"required":false},"case_sensitive":{"description":"Enable case-sensitive keyword matching.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/link-genius","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Keyword map name.","type":"string","required":false},"description":{"description":"Keyword map description.","type":"string","required":false},"target_url":{"description":"Target URL.","type":"string","required":false},"is_enabled":{"description":"Whether the keyword map is enabled.","type":"boolean","default":true,"required":false},"max_links_per_post":{"description":"Maximum links per post.","type":"integer","default":3,"minimum":1,"required":false},"auto_link_on_publish":{"description":"Enable auto-linking on publish.","type":"boolean","default":false,"required":false},"case_sensitive":{"description":"Enable case-sensitive keyword matching.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-toggle":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"description":"Array of keyword map IDs.","type":"array","items":{"type":"integer"},"required":true},"enabled":{"description":"New enabled status.","type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-toggle"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-delete":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"description":"Array of keyword map IDs.","type":"array","items":{"type":"integer"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-delete"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/execute":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/variations":{"namespace":"rankmath\/v1\/link-genius","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"variation":{"description":"Variation text.","type":"string","required":true},"source":{"description":"Variation source.","type":"string","default":"manual","enum":["manual","ai"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/variations\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/link-genius","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/generate-variations":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/generate-variations":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"Keyword to generate variations for.","type":"string","required":true},"context":{"description":"Optional context to help generate better variations.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/generate-variations"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/accept-variations":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"variations":{"description":"Array of variations to accept.","type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"google-site-kit\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1"}]}},"\/google-site-kit\/v1\/core\/site\/data\/setup-tag":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/setup-tag"}]}},"\/google-site-kit\/v1\/core\/site\/data\/connection":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/connection"}]}},"\/google-site-kit\/v1\/core\/user\/data\/authentication":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/authentication"}]}},"\/google-site-kit\/v1\/core\/user\/data\/disconnect":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/disconnect"}]}},"\/google-site-kit\/v1\/core\/user\/data\/get-token":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/get-token"}]}},"\/google-site-kit\/v1\/core\/user\/data\/user-input-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"questions":{"purpose":{"type":"array","items":{"type":"string"}},"postFrequency":{"type":"array","items":{"type":"string"}},"goals":{"type":"array","items":{"type":"string"}},"includeConversionEvents":{"type":"array","items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/user-input-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/audience-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"configuredAudiences":{"type":"array","items":{"type":"string"}},"isAudienceSegmentationWidgetHidden":{"type":"boolean"},"didSetAudiences":{"type":"boolean"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/audience-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"newEventsCalloutDismissedAt":{"type":"integer"},"lostEventsCalloutDismissedAt":{"type":"integer"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/list":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/list"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/activation":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/activation"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"\u7528\u4e8e\u6a21\u5757\u5316\u6807\u8bc6\u7b26","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/info"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/check-access":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"\u7528\u4e8e\u6a21\u5757\u5316\u6807\u8bc6\u7b26","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/check-access"}]}},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"\u7528\u4e8e\u6a21\u5757\u5316\u6807\u8bc6\u7b26","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"\u7528\u4e8e\u6a21\u5757\u5316\u6807\u8bc6\u7b26","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"\u7528\u4e8e\u6a21\u5757\u5316\u6807\u8bc6\u7b26","default":null,"required":false},"data":{"type":"object","description":"\u8bbe\u7f6e\u6210\u529f","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/data-available":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"\u7528\u4e8e\u6a21\u5757\u5316\u6807\u8bc6\u7b26","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/(?P<datapoint>[a-z\\-]+)":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"\u7528\u4e8e\u6a21\u5757\u5316\u6807\u8bc6\u7b26","default":null,"required":false},"datapoint":{"type":"string","description":"\u6a21\u5757\u5316\u6570\u636e\u70b9\u7684\u5730\u5740","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"\u7528\u4e8e\u6a21\u5757\u5316\u6807\u8bc6\u7b26","default":null,"required":false},"datapoint":{"type":"string","description":"\u6a21\u5757\u5316\u6570\u636e\u70b9\u7684\u5730\u5740","default":null,"required":false},"data":{"type":"object","description":"\u6570\u636e\u7528\u4e8e\u8bbe\u7f6e","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/core\/modules\/data\/recover-modules":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/recover-modules"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-items":{"namespace":"google-site-kit\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"data":{"type":"object","description":"","default":null,"minProperties":1,"additionalProperties":false,"properties":{"slugs":{"type":"array","required":true,"items":{"type":"string"}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-item":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-item"}]}},"\/google-site-kit\/v1\/core\/user\/data\/expirable-items":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/expirable-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","description":"","default":null,"items":{"type":"object","additionalProperties":false,"properties":{"slug":{"type":"string","required":true},"expiration":{"type":"integer","required":true}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers"}]}},"\/google-site-kit\/v1\/core\/user\/data\/permissions":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/permissions"}]}},"\/google-site-kit\/v1\/core\/user\/data\/nonces":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/nonces"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-trigger":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"triggerID":{"type":"string","required":true},"ttl":{"type":"integer","minimum":0}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-trigger"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-event":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"session":{"type":"object","required":true,"properties":{"session_id":{"type":"string","required":true},"session_token":{"type":"string","required":true}}},"event":{"type":"object","required":true,"properties":{"survey_shown":{"type":"object"},"survey_closed":{"type":"object"},"question_answered":{"type":"object"},"completion_shown":{"type":"object"},"follow_up_link_clicked":{"type":"object"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-event"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset-persistent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset-persistent"}]}},"\/google-site-kit\/v1\/core\/site\/data\/developer-plugin":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/developer-plugin"}]}},"\/google-site-kit\/v1\/core\/user\/data\/tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":true}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/tracking"}]}},"\/google-site-kit\/v1\/core\/search\/data\/entity-search":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"query":{"type":"string","description":"\u8981\u641c\u7d22\u7684\u6587\u672c\u5185\u5bb9","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/search\/data\/entity-search"}]}},"\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":false}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings"}]}},"\/google-site-kit\/v1\/core\/site\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/notifications"}]}},"\/google-site-kit\/v1\/core\/site\/data\/mark-notification":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/mark-notification"}]}},"\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test"}]}},"\/google-site-kit\/v1\/core\/site\/data\/health-checks":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/health-checks"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour"}]}},"\/google-site-kit\/v1\/core\/user\/data\/key-metrics":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"isWidgetHidden":{"type":"boolean","required":true},"widgetSlugs":{"type":"array","required":false,"maxItems":8,"items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/key-metrics"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-mode":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean"},"regions":{"type":"array","items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-mode"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-info"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate"}]}},"\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status"}]}},"\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking"}]}},"\/wpmudev_pcs\/v1":{"namespace":"wpmudev_pcs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpmudev_pcs\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpmudev_pcs\/v1"}]}},"\/wpmudev_pcs\/v1\/plugincrosssell\/install_plugin":{"namespace":"wpmudev_pcs\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpmudev_pcs\/v1\/plugincrosssell\/install_plugin"}]}},"\/wpmudev_pcs\/v1\/plugincrosssell\/activate_plugin":{"namespace":"wpmudev_pcs\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpmudev_pcs\/v1\/plugincrosssell\/activate_plugin"}]}},"\/wpmudev_blc\/v1":{"namespace":"wpmudev_blc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpmudev_blc\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpmudev_blc\/v1"}]}},"\/wpmudev_blc\/v1\/avatars":{"namespace":"wpmudev_blc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpmudev_blc\/v1\/avatars"}]}},"\/wpmudev_blc\/v1\/scan":{"namespace":"wpmudev_blc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpmudev_blc\/v1\/scan"}]}},"\/wpmudev_blc\/v1\/settings":{"namespace":"wpmudev_blc\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wpmudev_blc\/v1\/settings"}]}},"\/regenerate-thumbnails\/v1":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"regenerate-thumbnails\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/regenerate-thumbnails\/v1"}]}},"\/regenerate-thumbnails\/v1\/regenerate\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"only_regenerate_missing_thumbnails":{"description":"\u662f\u5426\u4ec5\u91cd\u65b0\u751f\u6210\u7f3a\u5931\u7684\u7f29\u7565\u56fe\u3002\u542f\u7528\u6b64\u529f\u80fd\u4f1a\u66f4\u5feb\u3002","type":"boolean","default":true,"required":false},"delete_unregistered_thumbnail_files":{"description":"\u662f\u5426\u5220\u9664\u4efb\u4f55\u65e7\u7684\uff0c\u73b0\u5728\u672a\u6ce8\u518c\u7684\u7f29\u7565\u56fe\u6587\u4ef6\u3002","type":"boolean","default":false,"required":false},"update_usages_in_posts":{"description":"\u662f\u5426\u66f4\u65b0\u4efb\u4f55\u4f7f\u7528\u6b64\u9644\u4ef6\u7684\u6587\u7ae0\u4e2d\u7684img\u6807\u7b7e\u3002","type":"boolean","default":true,"required":false},"update_usages_in_posts_post_type":{"description":"\u8981\u66f4\u65b0\u7684\u6587\u7ae0\u7c7b\u578b\u3002 \u9ed8\u8ba4\u4e3a\u6240\u6709\u516c\u5f00\u6587\u7ae0\u7c7b\u578b\u3002","type":"array","default":[],"required":false},"update_usages_in_posts_post_ids":{"description":"\u9700\u8981\u66f4\u65b0\u7684\u5177\u4f53\u6587\u7ae0ID\uff0c\u800c\u4e0d\u662f\u6240\u6709\u4f7f\u7528\u6b64\u9644\u4ef6\u7684\u6587\u7ae0\u3002","type":"array","default":[],"required":false},"update_usages_in_posts_posts_per_loop":{"description":"\u6bcf\u6b21\u5904\u7406\u7684\u6587\u7ae0\u6570\u91cf\uff0c\u6b64\u9009\u9879\u63a7\u5236\u5185\u5b58\u4f7f\u7528\u91cf\uff0c\u4e00\u822c\u4e0d\u9700\u8981\u8c03\u6574\u3002","type":"integer","default":10,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/regenerate-thumbnails\/v1\/attachmentinfo\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/regenerate-thumbnails\/v1\/featuredimages":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/regenerate-thumbnails\/v1\/featuredimages"}]}},"\/otgs\/installer\/v1":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"otgs\/installer\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/otgs\/installer\/v1"}]}},"\/otgs\/installer\/v1\/push\/fetch-subscription":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/otgs\/installer\/v1\/push\/fetch-subscription"}]}},"\/mcp":{"namespace":"mcp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"mcp","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/mcp"}]}},"\/mcp\/mcp-oauth-server":{"namespace":"mcp","methods":["POST","GET","DELETE"],"endpoints":[{"methods":["POST","GET","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/mcp\/mcp-oauth-server"}]}},"\/mcp\/mcp-adapter-default-server":{"namespace":"mcp","methods":["POST","GET","DELETE"],"endpoints":[{"methods":["POST","GET","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/mcp\/mcp-adapter-default-server"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u5982\u4f55\u89e3\u91ca\u641c\u7d22\u8f93\u5165\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u57fa\u4e8e\u591a\u4e2a\u5206\u7c7b\u6cd5\u95f4\u7684\u5173\u7cfb\u9650\u5236\u7ed3\u679c\u96c6\u3002","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 categories \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u4e86\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"\u662f\u5426\u5728\u9650\u5236\u7ed3\u679c\u96c6\u7684\u9879\u76ee\u4e2d\u5305\u542b\u5b50\u9879\u76ee\u3002","type":"boolean","default":false},"operator":{"description":"\u9879\u76ee\u662f\u5426\u5fc5\u987b\u5206\u914d\u6240\u6709\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u672f\u8bed\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 categories \u5206\u7c7b\u6cd5\u4e2d\u672a\u6307\u5b9a\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"\u662f\u5426\u5728\u9650\u5236\u7ed3\u679c\u96c6\u7684\u9879\u76ee\u4e2d\u5305\u542b\u5b50\u9879\u76ee\u3002","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 tags \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u4e86\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u9879\u76ee\u662f\u5426\u5fc5\u987b\u5206\u914d\u6240\u6709\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u672f\u8bed\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 tags \u5206\u7c7b\u6cd5\u4e2d\u672a\u6307\u5b9a\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u7f6e\u9876\u9879\u76ee\u3002","type":"boolean","required":false},"ignore_sticky":{"description":"\u662f\u5426\u5ffd\u7565\u7f6e\u9876\u6587\u7ae0\u3002","type":"boolean","default":true,"required":false},"format":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5206\u914d\u4e00\u4e2a\u6216\u591a\u4e2a\u6307\u5b9a\u683c\u5f0f\u7684\u9879\u3002","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6587\u7ae0\u7684\u5f62\u5f0f\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u6587\u7ae0\u662f\u5426\u4e3a\u7f6e\u9876\u3002","type":"boolean","required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"categories":{"description":"\u5728 category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u5728 post_tag \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u8986\u76d6\u9ed8\u8ba4\u6458\u8981\u957f\u5ea6\u3002","type":"integer","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6587\u7ae0\u7684\u5f62\u5f0f\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u6587\u7ae0\u662f\u5426\u4e3a\u7f6e\u9876\u3002","type":"boolean","required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"categories":{"description":"\u5728 category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u5728 post_tag \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6587\u7ae0\u7684\u5f62\u5f0f\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u6587\u7ae0\u662f\u5426\u4e3a\u7f6e\u9876\u3002","type":"boolean","required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"categories":{"description":"\u5728 category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u5728 post_tag \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u7279\u5b9a menu_order \u7684\u6587\u7ae0\u3002","type":"integer","required":false},"search_semantics":{"description":"\u5982\u4f55\u89e3\u91ca\u641c\u7d22\u8f93\u5165\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u7279\u5b9a\u7236 ID \u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u9664\u7279\u5b9a\u7236 ID \u4e4b\u5916\u7684\u6240\u6709\u9879\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"parent":{"description":"\u6587\u7ae0\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u6587\u7ae0\u4e0e\u5176\u4ed6\u6587\u7ae0\u7684\u987a\u5e8f\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u8986\u76d6\u9ed8\u8ba4\u6458\u8981\u957f\u5ea6\u3002","type":"integer","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"parent":{"description":"\u6587\u7ae0\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u6587\u7ae0\u4e0e\u5176\u4ed6\u6587\u7ae0\u7684\u987a\u5e8f\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u6587\u7ae0\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u6587\u7ae0\u4e0e\u5176\u4ed6\u6587\u7ae0\u7684\u987a\u5e8f\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u5982\u4f55\u89e3\u91ca\u641c\u7d22\u8f93\u5165\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u7279\u5b9a\u7236 ID \u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u9664\u7279\u5b9a\u7236 ID \u4e4b\u5916\u7684\u6240\u6709\u9879\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u7279\u5b9a\u5a92\u4f53\u7c7b\u578b\u7684\u9644\u4ef6\u3002","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u7279\u5b9a MIME \u7c7b\u578b\u7684\u9644\u4ef6\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"smush":{"description":"\u538b\u7f29\u6570\u636e\u3002","type":"string","required":false},"alt_text":{"description":"\u5728\u9644\u4ef6\u672a\u80fd\u663e\u793a\u65f6\u663e\u793a\u7684\u66ff\u6362\u6587\u672c\u3002","type":"string","required":false},"caption":{"description":"\u9644\u4ef6\u8bf4\u660e\u6587\u5b57\u3002","type":"object","properties":{"raw":{"description":"\u9644\u4ef6\u7684\u8bf4\u660e\u6587\u5b57\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7684 HTML \u8bf4\u660e\u6587\u5b57\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u9644\u4ef6\u7684\u63cf\u8ff0\u3002","type":"object","properties":{"raw":{"description":"\u9644\u4ef6\u7684\u63cf\u8ff0\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7684 HTML \u63cf\u8ff0\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"\u9644\u4ef6\u6240\u5c5e\u6587\u7ae0\u7684 ID\u3002","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"\u662f\u5426\u751f\u6210\u56fe\u50cf\u5b50\u5c3a\u5bf8\u3002","required":false},"convert_format":{"type":"boolean","default":true,"description":"\u662f\u5426\u8f6c\u6362\u56fe\u50cf\u683c\u5f0f\u3002","required":false},"url":{"type":"string","format":"uri","description":"\u8981\u4fa7\u8f7d\u5230\u5a92\u4f53\u5e93\u800c\u975e\u4e0a\u4f20\u6587\u4ef6\u7684\u5916\u90e8\u56fe\u7247 URL\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"smush":{"description":"\u538b\u7f29\u6570\u636e\u3002","type":"string","required":false},"alt_text":{"description":"\u5728\u9644\u4ef6\u672a\u80fd\u663e\u793a\u65f6\u663e\u793a\u7684\u66ff\u6362\u6587\u672c\u3002","type":"string","required":false},"caption":{"description":"\u9644\u4ef6\u8bf4\u660e\u6587\u5b57\u3002","type":"object","properties":{"raw":{"description":"\u9644\u4ef6\u7684\u8bf4\u660e\u6587\u5b57\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7684 HTML \u8bf4\u660e\u6587\u5b57\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u9644\u4ef6\u7684\u63cf\u8ff0\u3002","type":"object","properties":{"raw":{"description":"\u9644\u4ef6\u7684\u63cf\u8ff0\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7684 HTML \u63cf\u8ff0\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"\u9644\u4ef6\u6240\u5c5e\u6587\u7ae0\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u9644\u4ef6\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"\u5df2\u7ecf\u7f16\u8f91\u7684\u56fe\u7247\u6587\u4ef6 \u7684 URL\u3002","type":"string","format":"uri","required":true},"modifiers":{"description":"\u56fe\u7247\u7f16\u8f91\u6570\u7ec4\u3002","type":"array","minItems":1,"items":{"description":"\u56fe\u7247\u7f16\u8f91","type":"object","required":["type","args"],"oneOf":[{"title":"\u7ffb\u8f6c","properties":{"type":{"description":"\u7ffb\u8f6c\u7c7b\u578b\u3002","type":"string","enum":["flip"]},"args":{"description":"\u7ffb\u8f6c\u53c2\u6570\u3002","type":"object","required":["flip"],"properties":{"flip":{"description":"\u7ffb\u8f6c\u65b9\u5411\u3002","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"\u662f\u5426\u6c34\u5e73\u7ffb\u8f6c\u3002","type":"boolean"},"vertical":{"description":"\u662f\u5426\u5782\u76f4\u7ffb\u8f6c\u3002","type":"boolean"}}}}}}},{"title":"\u65cb\u8f6c","properties":{"type":{"description":"\u65cb\u8f6c\u7c7b\u578b\u3002","type":"string","enum":["rotate"]},"args":{"description":"\u65cb\u8f6c\u53c2\u6570\u3002","type":"object","required":["angle"],"properties":{"angle":{"description":"\u987a\u65f6\u9488\u65cb\u8f6c\u7684\u89d2\u5ea6\u3002","type":"number"}}}}},{"title":"\u88c1\u526a","properties":{"type":{"description":"\u88c1\u526a\u65b9\u5f0f\u3002","type":"string","enum":["crop"]},"args":{"description":"\u88c1\u526a\u53c2\u6570\u3002","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"\u4ece\u5de6\u8fb9\u5f00\u59cb\u88c1\u526a\u7684\u6c34\u5e73\u4f4d\u7f6e\u4ee5\u5360\u7528\u56fe\u7247\u5bbd\u5ea6\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002","type":"number"},"top":{"description":"\u4ece\u9876\u90e8\u5f00\u59cb\u88c1\u526a\u7684\u5782\u76f4\u4f4d\u7f6e\u4ee5\u5360\u7528\u56fe\u7247\u9ad8\u5ea6\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002","type":"number"},"width":{"description":"\u88c1\u526a\u5bbd\u5ea6\u4ee5\u5360\u7528\u56fe\u7247\u5bbd\u5ea6\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002","type":"number"},"height":{"description":"\u88c1\u526a\u7684\u9ad8\u5ea6\u4ee5\u5360\u7528\u56fe\u7247\u9ad8\u5ea6\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002","type":"number"}}}}}]},"required":false},"rotation":{"description":"\u987a\u65f6\u9488\u65cb\u8f6c\u7684\u89d2\u5ea6\u91cf\u3002\u5df2\u5f03\u7528\uff1a\u8bf7\u6539\u4e3a\u4f7f\u7528 `modifiers` \u53c2\u6570\u3002","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"\u4ece X \u8f74\u5f00\u59cb\u88c1\u526a\u7684\u4f4d\u7f6e\u4ee5\u5360\u7528\u56fe\u7247\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002\u5df2\u5f03\u7528\u3002\u4f7f\u7528`modifiers`\u4ee3\u66ff\u3002","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"\u4ece Y \u8f74\u5f00\u59cb\u88c1\u526a\u7684\u4f4d\u7f6e\u4ee5\u5360\u7528\u56fe\u7247\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002\u5df2\u5f03\u7528\u3002\u4f7f\u7528`modifiers`\u4ee3\u66ff\u3002","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"\u88c1\u526a\u5bbd\u5ea6\u4ee5\u56fe\u7247\u6240\u5360\u7528\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002\u5df2\u5f03\u7528\u3002\u4f7f\u7528`modifiers`\u4ee3\u66ff\u3002","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"\u88c1\u526a\u9ad8\u5ea6\u4ee5\u56fe\u7247\u6240\u7ad9\u7528\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002\u5df2\u5f03\u7528\u3002\u4f7f\u7528`modifiers`\u4ee3\u66ff\u3002","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"\u9644\u4ef6\u8bf4\u660e\u6587\u5b57\u3002","type":"object","properties":{"raw":{"description":"\u9644\u4ef6\u7684\u8bf4\u660e\u6587\u5b57\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7684 HTML \u8bf4\u660e\u6587\u5b57\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u9644\u4ef6\u7684\u63cf\u8ff0\u3002","type":"object","properties":{"raw":{"description":"\u9644\u4ef6\u7684\u63cf\u8ff0\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7684 HTML \u63cf\u8ff0\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"\u9644\u4ef6\u6240\u5c5e\u6587\u7ae0\u7684 ID\u3002","type":"integer","required":false},"alt_text":{"description":"\u5728\u9644\u4ef6\u672a\u80fd\u663e\u793a\u65f6\u663e\u793a\u7684\u66ff\u6362\u6587\u672c\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/sideload":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u9644\u4ef6\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"image_size":{"description":"\u56fe\u7247\u5927\u5c0f\u3002\u53ef\u4ee5\u662f\u5355\u4e2a\u5c3a\u5bf8\u540d\u79f0\u6216\u5c3a\u5bf8\u540d\u79f0\u6570\u7ec4\uff0c\u4ee5\u5728\u591a\u4e2a\u5c3a\u5bf8\u4e0b\u6ce8\u518c\u76f8\u540c\u7684\u6587\u4ef6\u3002","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"convert_format":{"type":"boolean","default":true,"description":"\u662f\u5426\u8f6c\u6362\u56fe\u50cf\u683c\u5f0f\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/finalize":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u9644\u4ef6\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"sub_sizes":{"description":"\u4ece\u4fa7\u8f7d\u54cd\u5e94\u4e2d\u6536\u96c6\u7684\u5b50\u5c3a\u5bf8\u5143\u6570\u636e\u6570\u7ec4\u3002","type":"array","default":[],"maxItems":100,"items":{"type":"object","properties":{"image_size":{"description":"\u5c3a\u5bf8\u540d\u79f0\uff0c\u6216\u5f53\u5355\u4e2a\u6587\u4ef6\u5728\u5177\u6709\u5339\u914d\u5c3a\u5bf8\u7684\u591a\u4e2a\u5c3a\u5bf8\u4e0b\u6ce8\u518c\u65f6\u7684\u5c3a\u5bf8\u540d\u79f0\u6570\u7ec4\u3002","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"width":{"type":"integer","minimum":1},"height":{"type":"integer","minimum":1},"file":{"type":"string","minLength":1},"mime_type":{"type":"string","pattern":"^image\/.*"},"filesize":{"type":"integer","minimum":1},"original_image":{"type":"string","minLength":1}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u5982\u4f55\u89e3\u91ca\u641c\u7d22\u8f93\u5165\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u57fa\u4e8e\u591a\u4e2a\u5206\u7c7b\u6cd5\u95f4\u7684\u5173\u7cfb\u9650\u5236\u7ed3\u679c\u96c6\u3002","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 menus \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u4e86\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u9879\u76ee\u662f\u5426\u5fc5\u987b\u5206\u914d\u6240\u6709\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u672f\u8bed\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 menus \u5206\u7c7b\u6cd5\u4e2d\u672a\u6307\u5b9a\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u7279\u5b9a menu_order \u7684\u6587\u7ae0\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\u3002","type":["string","object"],"properties":{"raw":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u5bf9\u8c61\u7684 HTML \u6807\u9898\uff0c\u8f6c\u6362\u540e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"\u539f\u59cb\u8868\u793a\u7684\u5bf9\u8c61\u7ec4\uff0c\u5982\u300cpost_type\u300d\u6216\u300ctaxonomy\u300d\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"\u5bf9\u8c61\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"\u5bf9\u8c61\u7684\u7236\u5bf9\u8c61 ID\u3002","type":"integer","minimum":0,"required":false},"attr_title":{"description":"\u6b64\u83dc\u5355\u9879\u7684 link \u5143\u7d20\u7684 title \u5c5e\u6027\u7684\u6587\u672c\u3002","type":"string","required":false},"classes":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684\u7c7b\u540d\u79f0\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"menu_order":{"default":1,"description":"\u5bfc\u822a\u83dc\u5355\u9879\u7684 nav_menu_item \u7684 DB ID\uff08\u5982\u679c\u6709\uff09\uff0c\u5426\u5219\u4e3a 0\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u5bf9\u8c61\u521d\u59cb\u7684\u8868\u793a\u7c7b\u578b\uff0c\u5982 \u300c\u5206\u7c7b\u300d\u3001\u300c\u6587\u7ae0\u300d\u548c\u300c\u9644\u4ef6\u300d\u3002","type":"string","required":false},"object_id":{"default":0,"description":"\u6b64\u83dc\u5355\u9879\u8868\u793a\u7684\u539f\u59cb\u5bf9\u8c61\u7684\u6570\u636e\u5e93 ID\uff0c\u4f8b\u5982\u6587\u7ae0\u7684 ID \u6216\u5206\u7c7b\u7684 term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684 target \u5c5e\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u8be5\u83dc\u5355\u9879\u6307\u5411\u7684 URL\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u8be5\u83dc\u5355\u9879\u7684\u94fe\u63a5\u4e2d\u8868\u793a\u7684 XFN \u5173\u7cfb\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u6b64\u5bf9\u8c61\u5728 nav_menu \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u7684\u9879\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"title":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\u3002","type":["string","object"],"properties":{"raw":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u5bf9\u8c61\u7684 HTML \u6807\u9898\uff0c\u8f6c\u6362\u540e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"\u539f\u59cb\u8868\u793a\u7684\u5bf9\u8c61\u7ec4\uff0c\u5982\u300cpost_type\u300d\u6216\u300ctaxonomy\u300d\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"\u5bf9\u8c61\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"\u5bf9\u8c61\u7684\u7236\u5bf9\u8c61 ID\u3002","type":"integer","minimum":0,"required":false},"attr_title":{"description":"\u6b64\u83dc\u5355\u9879\u7684 link \u5143\u7d20\u7684 title \u5c5e\u6027\u7684\u6587\u672c\u3002","type":"string","required":false},"classes":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684\u7c7b\u540d\u79f0\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"menu_order":{"description":"\u5bfc\u822a\u83dc\u5355\u9879\u7684 nav_menu_item \u7684 DB ID\uff08\u5982\u679c\u6709\uff09\uff0c\u5426\u5219\u4e3a 0\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u5bf9\u8c61\u521d\u59cb\u7684\u8868\u793a\u7c7b\u578b\uff0c\u5982 \u300c\u5206\u7c7b\u300d\u3001\u300c\u6587\u7ae0\u300d\u548c\u300c\u9644\u4ef6\u300d\u3002","type":"string","required":false},"object_id":{"description":"\u6b64\u83dc\u5355\u9879\u8868\u793a\u7684\u539f\u59cb\u5bf9\u8c61\u7684\u6570\u636e\u5e93 ID\uff0c\u4f8b\u5982\u6587\u7ae0\u7684 ID \u6216\u5206\u7c7b\u7684 term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684 target \u5c5e\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u8be5\u83dc\u5355\u9879\u6307\u5411\u7684 URL\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u8be5\u83dc\u5355\u9879\u7684\u94fe\u63a5\u4e2d\u8868\u793a\u7684 XFN \u5173\u7cfb\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u6b64\u5bf9\u8c61\u5728 nav_menu \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u7684\u9879\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u5bf9\u8c61\u7684\u7236\u5bf9\u8c61 ID\u3002","type":"integer","minimum":0,"required":false},"title":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\u3002","type":["string","object"],"properties":{"raw":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u5bf9\u8c61\u7684 HTML \u6807\u9898\uff0c\u8f6c\u6362\u540e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"\u539f\u59cb\u8868\u793a\u7684\u5bf9\u8c61\u7ec4\uff0c\u5982\u300cpost_type\u300d\u6216\u300ctaxonomy\u300d\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"\u5bf9\u8c61\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"\u6b64\u83dc\u5355\u9879\u7684 link \u5143\u7d20\u7684 title \u5c5e\u6027\u7684\u6587\u672c\u3002","type":"string","required":false},"classes":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684\u7c7b\u540d\u79f0\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"menu_order":{"description":"\u5bfc\u822a\u83dc\u5355\u9879\u7684 nav_menu_item \u7684 DB ID\uff08\u5982\u679c\u6709\uff09\uff0c\u5426\u5219\u4e3a 0\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u5bf9\u8c61\u521d\u59cb\u7684\u8868\u793a\u7c7b\u578b\uff0c\u5982 \u300c\u5206\u7c7b\u300d\u3001\u300c\u6587\u7ae0\u300d\u548c\u300c\u9644\u4ef6\u300d\u3002","type":"string","required":false},"object_id":{"description":"\u6b64\u83dc\u5355\u9879\u8868\u793a\u7684\u539f\u59cb\u5bf9\u8c61\u7684\u6570\u636e\u5e93 ID\uff0c\u4f8b\u5982\u6587\u7ae0\u7684 ID \u6216\u5206\u7c7b\u7684 term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684 target \u5c5e\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u8be5\u83dc\u5355\u9879\u6307\u5411\u7684 URL\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u8be5\u83dc\u5355\u9879\u7684\u94fe\u63a5\u4e2d\u8868\u793a\u7684 XFN \u5173\u7cfb\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u6b64\u5bf9\u8c61\u5728 nav_menu \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u7684\u9879\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u5982\u4f55\u89e3\u91ca\u641c\u7d22\u8f93\u5165\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u57fa\u4e8e\u591a\u4e2a\u5206\u7c7b\u6cd5\u95f4\u7684\u5173\u7cfb\u9650\u5236\u7ed3\u679c\u96c6\u3002","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 wp_pattern_category \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u4e86\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u9879\u76ee\u662f\u5426\u5fc5\u987b\u5206\u914d\u6240\u6709\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u672f\u8bed\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 wp_pattern_category \u5206\u7c7b\u6cd5\u4e2d\u672a\u6307\u5b9a\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u5728 wp_pattern_category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u8986\u76d6\u9ed8\u8ba4\u6458\u8981\u957f\u5ea6\u3002","type":"integer","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u5728 wp_pattern_category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u5728 wp_pattern_category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"\u9650\u5236\u4e3a\u6307\u5b9a\u7684\u6587\u7ae0 ID\u3002","type":"integer","required":false},"area":{"description":"\u9650\u5236\u4e3a\u6307\u5b9a\u7684\u6a21\u677f\u7ec4\u4ef6\u533a\u3002","type":"string","required":false},"post_type":{"description":"\u8981\u83b7\u53d6\u6a21\u677f\u7684\u6587\u7ae0\u7c7b\u578b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"default":"","description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"default":"publish","description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u83b7\u53d6\u56de\u9000\u6240\u7528\u7684\u6a21\u677f\u7684\u522b\u540d\uff1a","type":"string","required":true},"is_custom":{"description":"\u8868\u660e\u6a21\u677f\u662f\u81ea\u5b9a\u4e49\u7684\uff0c\u8fd8\u662f\u5c5e\u4e8e\u6a21\u677f\u5c42\u7ea7\u7684\u4e00\u90e8\u5206","type":"boolean","required":false},"template_prefix":{"description":"\u6240\u521b\u5efa\u6a21\u677f\u7684\u6a21\u677f\u524d\u7f00\u3002\u7528\u4e8e\u63d0\u53d6\u4e3b\u6a21\u677f\u7c7b\u578b\uff0c\u4f8b\u5982\u5728 `taxonomy-books` \u4e2d\u63d0\u53d6 `taxonomy`","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"area":{"description":"\u6a21\u677f\u7ec4\u4ef6\u7528\u9014\uff08\u9875\u7709\u3001\u9875\u811a\u7b49\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"\u9650\u5236\u4e3a\u6307\u5b9a\u7684\u6587\u7ae0 ID\u3002","type":"integer","required":false},"area":{"description":"\u9650\u5236\u4e3a\u6307\u5b9a\u7684\u6a21\u677f\u7ec4\u4ef6\u533a\u3002","type":"string","required":false},"post_type":{"description":"\u8981\u83b7\u53d6\u6a21\u677f\u7684\u6587\u7ae0\u7c7b\u578b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"default":"","description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"default":"publish","description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"area":{"description":"\u6a21\u677f\u7ec4\u4ef6\u7528\u9014\uff08\u9875\u7709\u3001\u9875\u811a\u7b49\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u83b7\u53d6\u56de\u9000\u6240\u7528\u7684\u6a21\u677f\u7684\u522b\u540d\uff1a","type":"string","required":true},"is_custom":{"description":"\u8868\u660e\u6a21\u677f\u662f\u81ea\u5b9a\u4e49\u7684\uff0c\u8fd8\u662f\u5c5e\u4e8e\u6a21\u677f\u5c42\u7ea7\u7684\u4e00\u90e8\u5206","type":"boolean","required":false},"template_prefix":{"description":"\u6240\u521b\u5efa\u6a21\u677f\u7684\u6a21\u677f\u524d\u7f00\u3002\u7528\u4e8e\u63d0\u53d6\u4e3b\u6a21\u677f\u7c7b\u578b\uff0c\u4f8b\u5982\u5728 `taxonomy-books` \u4e2d\u63d0\u53d6 `taxonomy`","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"area":{"description":"\u6a21\u677f\u7ec4\u4ef6\u7528\u9014\uff08\u9875\u7709\u3001\u9875\u811a\u7b49\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u5168\u5c40\u6837\u5f0f\u4fee\u8ba2\u7248\u7236\u7248\u672c\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u5168\u5c40\u6837\u5f0f\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"\u4e3b\u9898\u6807\u8bc6\u7b26","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"\u4e3b\u9898\u6807\u8bc6\u7b26","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"\u5168\u5c40\u6837\u5f0f\u914d\u7f6e\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"\u5168\u5c40\u6837\u5f0f\u3002","type":["object"],"required":false},"settings":{"description":"\u5168\u5c40\u8bbe\u7f6e\u3002","type":["object"],"required":false},"title":{"description":"\u5168\u5c40\u6837\u5f0f\u53d8\u4f53\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5168\u5c40\u6837\u5f0f\u53d8\u4f53\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u5982\u4f55\u89e3\u91ca\u641c\u7d22\u8f93\u5165\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u5982\u4f55\u89e3\u91ca\u641c\u7d22\u8f93\u5165\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"\u7528\u4e8e\u6392\u7248\u8bbe\u7f6e\u7684 theme.json \u6a21\u5f0f\u7248\u672c\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"\u4ee5\u5b57\u7b26\u4e32\u5f62\u5f0f\u7f16\u7801\u7684 theme.json \u683c\u5f0f\u7684 font-family \u58f0\u660e\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"theme_json_version":{"description":"\u7528\u4e8e\u6392\u7248\u8bbe\u7f6e\u7684 theme.json \u6a21\u5f0f\u7248\u672c\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"\u4ee5\u5b57\u7b26\u4e32\u5f62\u5f0f\u7f16\u7801\u7684 theme.json \u683c\u5f0f\u7684 font-family \u58f0\u660e\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"\u5b57\u4f53\u9762\u7684\u7236\u5b57\u4f53\u7cfb\u5217\u7684 ID\u3002","type":"integer","required":true},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u5982\u4f55\u89e3\u91ca\u641c\u7d22\u8f93\u5165\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"id","enum":["id","include"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"\u5b57\u4f53\u9762\u7684\u7236\u5b57\u4f53\u7cfb\u5217\u7684 ID\u3002","type":"integer","required":true},"theme_json_version":{"description":"\u7528\u4e8e\u6392\u7248\u8bbe\u7f6e\u7684 theme.json \u6a21\u5f0f\u7248\u672c\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"\u5728 theme.json \u683c\u5f0f\u4e2d\u4ee5\u5b57\u7b26\u4e32\u5f62\u5f0f\u7f16\u7801\u7684 font-face \u58f0\u660e\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"\u5b57\u4f53\u9762\u7684\u7236\u5b57\u4f53\u7cfb\u5217\u7684 ID\u3002","type":"integer","required":true},"id":{"description":"\u5b57\u4f53\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":true},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"\u5b57\u4f53\u9762\u7684\u7236\u5b57\u4f53\u7cfb\u5217\u7684 ID\u3002","type":"integer","required":true},"id":{"description":"\u5b57\u4f53\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rm_content_editor":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u5982\u4f55\u89e3\u91ca\u641c\u7d22\u8f93\u5165\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/rm_content_editor"}]}},"\/wp\/v2\/rm_content_editor\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rm_content_editor\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rm_content_editor\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rank_math_schema":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u5982\u4f55\u89e3\u91ca\u641c\u7d22\u8f93\u5165\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/rank_math_schema"}]}},"\/wp\/v2\/rank_math_schema\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"\u6587\u7ae0\u7c7b\u578b\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"\u72b6\u6001\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"\u9650\u5236\u7ed3\u679c\u4e3a\u5173\u8054\u5230\u7279\u5b9a\u6587\u7ae0\u7c7b\u578b\u7684\u5206\u7c7b\u6cd5\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"\u5206\u7c7b\u6cd5\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u9879\u76ee\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u9690\u85cf\u672a\u88ab\u6307\u5b9a\u5230\u4efb\u4f55\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"boolean","default":false,"required":false},"parent":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u7236\u9879\u76ee\u7684\u9879\u76ee\u3002","type":"integer","required":false},"post":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u5206\u7c7b\u6cd5\u9879\u76ee\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":true},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"parent":{"description":"\u7236\u672f\u8bed ID\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":false},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"parent":{"description":"\u7236\u672f\u8bed ID\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u9879\u76ee\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u9879\u76ee\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u9690\u85cf\u672a\u88ab\u6307\u5b9a\u5230\u4efb\u4f55\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u5206\u7c7b\u6cd5\u9879\u76ee\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":true},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":false},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u9879\u76ee\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u9879\u76ee\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u9690\u85cf\u672a\u88ab\u6307\u5b9a\u5230\u4efb\u4f55\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u5206\u7c7b\u6cd5\u9879\u76ee\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":true},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"locations":{"description":"\u5206\u914d\u7ed9\u83dc\u5355\u7684\u4f4d\u7f6e\u3002","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"\u662f\u5426\u81ea\u52a8\u6dfb\u52a0\u9876\u7ea7\u9875\u9762\u5230\u6b64\u83dc\u5355\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":false},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"locations":{"description":"\u5206\u914d\u7ed9\u83dc\u5355\u7684\u4f4d\u7f6e\u3002","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"\u662f\u5426\u81ea\u52a8\u6dfb\u52a0\u9876\u7ea7\u9875\u9762\u5230\u6b64\u83dc\u5355\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u9879\u76ee\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u9879\u76ee\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u9690\u85cf\u672a\u88ab\u6307\u5b9a\u5230\u4efb\u4f55\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u5206\u7c7b\u6cd5\u9879\u76ee\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":true},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":false},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u9879\u76ee\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rank_math_redirection_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u9879\u76ee\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u9690\u85cf\u672a\u88ab\u6307\u5b9a\u5230\u4efb\u4f55\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"boolean","default":false,"required":false},"parent":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u7236\u9879\u76ee\u7684\u9879\u76ee\u3002","type":"integer","required":false},"post":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u5206\u7c7b\u6cd5\u9879\u76ee\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":true},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"parent":{"description":"\u7236\u672f\u8bed ID\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/rank_math_redirection_category"}]}},"\/wp\/v2\/rank_math_redirection_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":false},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"parent":{"description":"\u7236\u672f\u8bed ID\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u9879\u76ee\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"default":"asc","description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"\u6309\u7528\u6237\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u7528\u6237\u3002","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5339\u914d\u81f3\u5c11\u4e00\u4e2a\u89d2\u8272\u7684\u7528\u6237\uff0c\u63a5\u53d7.csv \u683c\u5f0f\u5217\u8868\u6216\u5355\u4e2a\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5339\u914d\u81f3\u5c11\u4e00\u9879\u63d0\u4f9b\u7684\u7279\u5b9a\u529f\u80fd\u7684\u7528\u6237\u3002\u63a5\u53d7 CSV \u5217\u8868\u6216\u5355\u4e2a\u529f\u80fd\u3002","type":"array","items":{"type":"string"},"required":false},"who":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u7528\u6237\u4e2d\u7684\u6240\u6709\u4f5c\u8005\u3002","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e8e\u5df2\u53d1\u5e03\u6587\u7ae0\u7684\u7528\u6237\u3002","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","rm_content_editor":"rm_content_editor","rank_math_schema":"rank_math_schema"}},"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"\u7528\u6237\u7684\u767b\u5f55\u540d\u3002","type":"string","required":true},"name":{"description":"\u7528\u6237\u7684\u663e\u793a\u540d\u3002","type":"string","required":false},"first_name":{"description":"\u7528\u6237\u7684\u540d\u5b57\u3002","type":"string","required":false},"last_name":{"description":"\u7528\u6237\u7684\u59d3\u6c0f\u3002","type":"string","required":false},"email":{"description":"\u7528\u6237\u7684\u90ae\u7bb1\u5730\u5740\u3002","type":"string","format":"email","required":true},"url":{"description":"\u7528\u6237\u7684 URL\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u7528\u6237\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"locale":{"description":"\u7528\u6237\u7684\u5730\u533a\u8bed\u8a00\u3002","type":"string","enum":["","en_US","bg_BG","cs_CZ","de_DE","el","es_ES","fr_FR","hu_HU","it_IT","ja","nl_NL","pl_PL","pt_BR","pt_PT","ru_RU","sk_SK","sl_SI","sv_SE","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"\u7528\u6237\u7684\u6635\u79f0\u3002","type":"string","required":false},"slug":{"description":"\u7528\u6237\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"roles":{"description":"\u7528\u6237\u88ab\u8d4b\u4e88\u7684\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u7528\u6237\u7684\u5bc6\u7801\uff08\u4ece\u4e0d\u88ab\u5305\u542b\uff09\u3002","type":"string","required":true},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u65e5\u671f\u548c\u65f6\u95f4\u7684\u504f\u597d\u8bbe\u7f6e\u5df2\u66f4\u65b0\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u7528\u6237\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u7528\u6237\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"username":{"description":"\u7528\u6237\u7684\u767b\u5f55\u540d\u3002","type":"string","required":false},"name":{"description":"\u7528\u6237\u7684\u663e\u793a\u540d\u3002","type":"string","required":false},"first_name":{"description":"\u7528\u6237\u7684\u540d\u5b57\u3002","type":"string","required":false},"last_name":{"description":"\u7528\u6237\u7684\u59d3\u6c0f\u3002","type":"string","required":false},"email":{"description":"\u7528\u6237\u7684\u90ae\u7bb1\u5730\u5740\u3002","type":"string","format":"email","required":false},"url":{"description":"\u7528\u6237\u7684 URL\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u7528\u6237\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"locale":{"description":"\u7528\u6237\u7684\u5730\u533a\u8bed\u8a00\u3002","type":"string","enum":["","en_US","bg_BG","cs_CZ","de_DE","el","es_ES","fr_FR","hu_HU","it_IT","ja","nl_NL","pl_PL","pt_BR","pt_PT","ru_RU","sk_SK","sl_SI","sv_SE","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"\u7528\u6237\u7684\u6635\u79f0\u3002","type":"string","required":false},"slug":{"description":"\u7528\u6237\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"roles":{"description":"\u7528\u6237\u88ab\u8d4b\u4e88\u7684\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u7528\u6237\u7684\u5bc6\u7801\uff08\u4ece\u4e0d\u88ab\u5305\u542b\uff09\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u65e5\u671f\u548c\u65f6\u95f4\u7684\u504f\u597d\u8bbe\u7f6e\u5df2\u66f4\u65b0\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u7528\u6237\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u7528\u6237\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"reassign":{"type":"integer","description":"\u5c06\u88ab\u5220\u9664\u7528\u6237\u7684\u6587\u7ae0\u548c\u94fe\u63a5\u91cd\u65b0\u6307\u5b9a\u5230\u6b64\u7528\u6237 ID\u3002","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"\u7528\u6237\u7684\u767b\u5f55\u540d\u3002","type":"string","required":false},"name":{"description":"\u7528\u6237\u7684\u663e\u793a\u540d\u3002","type":"string","required":false},"first_name":{"description":"\u7528\u6237\u7684\u540d\u5b57\u3002","type":"string","required":false},"last_name":{"description":"\u7528\u6237\u7684\u59d3\u6c0f\u3002","type":"string","required":false},"email":{"description":"\u7528\u6237\u7684\u90ae\u7bb1\u5730\u5740\u3002","type":"string","format":"email","required":false},"url":{"description":"\u7528\u6237\u7684 URL\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u7528\u6237\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"locale":{"description":"\u7528\u6237\u7684\u5730\u533a\u8bed\u8a00\u3002","type":"string","enum":["","en_US","bg_BG","cs_CZ","de_DE","el","es_ES","fr_FR","hu_HU","it_IT","ja","nl_NL","pl_PL","pt_BR","pt_PT","ru_RU","sk_SK","sl_SI","sv_SE","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"\u7528\u6237\u7684\u6635\u79f0\u3002","type":"string","required":false},"slug":{"description":"\u7528\u6237\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"roles":{"description":"\u7528\u6237\u88ab\u8d4b\u4e88\u7684\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u7528\u6237\u7684\u5bc6\u7801\uff08\u4ece\u4e0d\u88ab\u5305\u542b\uff09\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u65e5\u671f\u548c\u65f6\u95f4\u7684\u504f\u597d\u8bbe\u7f6e\u5df2\u66f4\u65b0\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u7528\u6237\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"reassign":{"type":"integer","description":"\u5c06\u88ab\u5220\u9664\u7528\u6237\u7684\u6587\u7ae0\u548c\u94fe\u63a5\u91cd\u65b0\u6307\u5b9a\u5230\u6b64\u7528\u6237 ID\u3002","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"\u7531\u5e94\u7528\u7a0b\u5e8f\u63d0\u4f9b\u7684\u7528\u4e8e\u552f\u4e00\u8bc6\u522b\u7684 UUID\u3002\u5efa\u8bae\u4f7f\u7528\u542b\u6709 URL \u6216 DNS \u547d\u540d\u7a7a\u95f4\u7684 UUID v5\u3002","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"\u5e94\u7528\u7a0b\u5e8f\u5bc6\u7801\u540d\u79f0\u3002","type":"string","minLength":1,"pattern":".*\\S.*","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"\u7531\u5e94\u7528\u7a0b\u5e8f\u63d0\u4f9b\u7684\u7528\u4e8e\u552f\u4e00\u8bc6\u522b\u7684 UUID\u3002\u5efa\u8bae\u4f7f\u7528\u542b\u6709 URL \u6216 DNS \u547d\u540d\u7a7a\u95f4\u7684 UUID v5\u3002","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"\u5e94\u7528\u7a0b\u5e8f\u5bc6\u7801\u540d\u79f0\u3002","type":"string","minLength":1,"pattern":".*\\S.*","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u8bc4\u8bba\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u7528\u6237 ID \u7684\u8bc4\u8bba\uff0c\u9700\u8981\u6388\u6743\u3002","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a\u7ed9\u7279\u5b9a\u7528\u6237 ID \u7684\u8bc4\u8bba\uff0c\u9700\u8981\u6388\u6743\u3002","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u4f5c\u8005\u7684\u90ae\u7bb1\u5730\u5740\uff0c\u9700\u8981\u6388\u6743\u3002","format":"email","type":"string","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u8bc4\u8bba\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u8bc4\u8bba\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7236 ID \u7684\u8bc4\u8bba\u3002","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a\u7236 ID \u7684\u8bc4\u8bba\u3002","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5173\u8054\u5230\u6307\u5b9a\u6587\u7ae0 ID \u7684\u8bc4\u8bba\u3002","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u8bbe\u7f6e\u7279\u5b9a\u72b6\u6001\u7684\u8bc4\u8bba\uff0c\u9700\u8981\u6388\u6743\u3002","type":"string","required":false},"type":{"default":"comment","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u8bbe\u7f6e\u7279\u5b9a\u7c7b\u578b\u7684\u8bc4\u8bba\uff0c\u9700\u8981\u6388\u6743\u3002","type":"string","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"author":{"description":"\u7528\u6237\u5bf9\u8c61\u7684 ID\uff0c\u5982\u679c\u4f5c\u8005\u662f\u7528\u6237\u3002","type":"integer","required":false},"author_email":{"description":"\u8bc4\u8bba\u8005\u7684\u90ae\u7bb1\u5730\u5740\u3002","type":"string","format":"email","required":false},"author_ip":{"description":"\u8bc4\u8bba\u8005\u7684 IP \u5730\u5740\u3002","type":"string","format":"ip","required":false},"author_name":{"description":"\u8bc4\u8bba\u8005\u7684\u663e\u793a\u540d\u3002","type":"string","required":false},"author_url":{"description":"\u8bc4\u8bba\u8005\u7684\u7f51\u5740\u3002","type":"string","format":"uri","required":false},"author_user_agent":{"description":"\u8bc4\u8bba\u8005\u7684 User-Agent\u3002","type":"string","required":false},"content":{"description":"\u8bc4\u8bba\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u8bc4\u8bba\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8bc4\u8bba\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"\u8bc4\u8bba\u53d1\u8868\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":"string","format":"date-time","required":false},"date_gmt":{"description":"\u8bc4\u8bba\u53d1\u8868\u7684 GMT \u65e5\u671f\u3002","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"\u8bc4\u8bba\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"post":{"default":0,"description":"\u5173\u8054\u6587\u7ae0\u5bf9\u8c61\u7684 ID\u3002","type":"integer","required":false},"status":{"description":"\u8bc4\u8bba\u7684\u72b6\u6001\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u6279\u6ce8\u89e3\u51b3\u72b6\u6001","default":"","enum":["resolved","reopen"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u8bc4\u8bba\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u8bc4\u8bba\u6240\u5c5e\u6587\u7ae0\u7684\u5bc6\u7801\uff08\u5982\u679c\u8be5\u6587\u7ae0\u88ab\u5bc6\u7801\u4fdd\u62a4\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u8bc4\u8bba\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"author":{"description":"\u7528\u6237\u5bf9\u8c61\u7684 ID\uff0c\u5982\u679c\u4f5c\u8005\u662f\u7528\u6237\u3002","type":"integer","required":false},"author_email":{"description":"\u8bc4\u8bba\u8005\u7684\u90ae\u7bb1\u5730\u5740\u3002","type":"string","format":"email","required":false},"author_ip":{"description":"\u8bc4\u8bba\u8005\u7684 IP \u5730\u5740\u3002","type":"string","format":"ip","required":false},"author_name":{"description":"\u8bc4\u8bba\u8005\u7684\u663e\u793a\u540d\u3002","type":"string","required":false},"author_url":{"description":"\u8bc4\u8bba\u8005\u7684\u7f51\u5740\u3002","type":"string","format":"uri","required":false},"author_user_agent":{"description":"\u8bc4\u8bba\u8005\u7684 User-Agent\u3002","type":"string","required":false},"content":{"description":"\u8bc4\u8bba\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u8bc4\u8bba\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8bc4\u8bba\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"\u8bc4\u8bba\u53d1\u8868\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":"string","format":"date-time","required":false},"date_gmt":{"description":"\u8bc4\u8bba\u53d1\u8868\u7684 GMT \u65e5\u671f\u3002","type":"string","format":"date-time","required":false},"parent":{"description":"\u8bc4\u8bba\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"post":{"description":"\u5173\u8054\u6587\u7ae0\u5bf9\u8c61\u7684 ID\u3002","type":"integer","required":false},"status":{"description":"\u8bc4\u8bba\u7684\u72b6\u6001\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u6279\u6ce8\u89e3\u51b3\u72b6\u6001","default":"","enum":["resolved","reopen"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u8bc4\u8bba\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"password":{"description":"\u8bc4\u8bba\u6240\u5c5e\u6587\u7ae0\u7684\u5bc6\u7801\uff08\u5982\u679c\u8be5\u6587\u7ae0\u88ab\u5bc6\u7801\u4fdd\u62a4\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"type":{"default":"post","description":"\u9650\u5236\u7ed3\u679c\u4e3a\u4e00\u79cd\u5bf9\u8c61\u7c7b\u578b\u3002","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"\u9650\u5236\u7ed3\u679c\u4e3a\u4e00\u79cd\u6216\u591a\u79cd\u5bf9\u8c61\u5b50\u7c7b\u578b\u3002","type":"array","items":{"enum":["post","page","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"\u6b64\u533a\u5757\u7684\u552f\u4e00\u6ce8\u518c\u540d\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"\u6b64\u533a\u5757\u7684\u5c5e\u6027\u3002","type":"object","default":[],"required":false},"post_id":{"description":"\u6587\u7ae0\u4e0a\u4e0b\u6587\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"\u533a\u5757\u547d\u540d\u7a7a\u95f4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"\u533a\u5757\u547d\u540d\u7a7a\u95f4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u533a\u5757\u540d\u79f0","type":"string","required":false},"namespace":{"description":"\u533a\u5757\u547d\u540d\u7a7a\u95f4\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"\u6807\u9898","description":"\u7ad9\u70b9\u6807\u9898\u3002","type":"string","required":false},"description":{"title":"\u526f\u6807\u9898","description":"\u7ad9\u70b9\u526f\u6807\u9898\u3002","type":"string","required":false},"url":{"title":"","description":"\u7ad9\u70b9 URL\u3002","type":"string","format":"uri","required":false},"email":{"title":"","description":"\u6b64\u5730\u5740\u88ab\u7528\u4f5c\u7ba1\u7406\u7528\u9014\uff0c\u5982\u65b0\u7528\u6237\u901a\u77e5\u3002","type":"string","format":"email","required":false},"timezone":{"title":"","description":"\u548c\u60a8\u5728\u540c\u4e00\u4e2a\u65f6\u533a\u7684\u57ce\u5e02\u3002","type":"string","required":false},"date_format":{"title":"","description":"\u5bf9\u6240\u6709\u65e5\u671f\u5b57\u7b26\u4e32\u9002\u7528\u7684\u65e5\u671f\u683c\u5f0f\u3002","type":"string","required":false},"time_format":{"title":"","description":"\u5bf9\u6240\u6709\u65f6\u95f4\u5b57\u7b26\u4e32\u9002\u7528\u7684\u65f6\u95f4\u683c\u5f0f\u3002","type":"string","required":false},"start_of_week":{"title":"","description":"\u4e00\u5468\u4ece\u5468\u51e0\u5f00\u59cb\u3002","type":"integer","required":false},"language":{"title":"","description":"WordPress \u5730\u533a\u8bed\u8a00\u4ee3\u7801\u3002","type":"string","required":false},"use_smilies":{"title":"","description":"\u5c06\u8868\u60c5\u7b26\u53f7\u5982:-) \u548c:-P \u8f6c\u6362\u4e3a\u56fe\u7247\u663e\u793a\u3002","type":"boolean","required":false},"default_category":{"title":"","description":"\u9ed8\u8ba4\u6587\u7ae0\u5206\u7c7b\u3002","type":"integer","required":false},"default_post_format":{"title":"","description":"\u9ed8\u8ba4\u6587\u7ae0\u5f62\u5f0f\u3002","type":"string","required":false},"posts_per_page":{"title":"\u6bcf\u9875\u6700\u591a\u6587\u7ae0\u6570","description":"\u6700\u591a\u663e\u793a\u7684\u535a\u5ba2\u9875\u9762\u6570\u91cf\u3002","type":"integer","required":false},"show_on_front":{"title":"\u5728\u524d\u9762\u663e\u793a","description":"\u9700\u8981\u5728\u9996\u9875\u4e0a\u663e\u793a\u7684\u9879\u76ee","type":"string","required":false},"page_on_front":{"title":"\u524d\u4e00\u9875","description":"\u9700\u8981\u5728\u9996\u9875\u4e0a\u663e\u793a\u7684\u9875\u9762 ID","type":"integer","required":false},"page_for_posts":{"title":"","description":"\u9700\u8981\u663e\u793a\u6700\u65b0\u6587\u7ae0\u7684\u9875\u9762 ID","type":"integer","required":false},"default_ping_status":{"title":"","description":"\u5141\u8bb8\u5728\u6587\u7ae0\u4e2d\u63a5\u6536\u6765\u81ea\u5176\u4ed6\u535a\u5ba2\u7684\u94fe\u63a5\u901a\u77e5\uff08Pingback \u548c Trackback\uff09\u3002","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"\u5141\u8bb8\u5bf9\u65b0\u6587\u7ae0\u53d1\u8868\u8bc4\u8bba","description":"\u5141\u8bb8\u4ed6\u4eba\u5728\u65b0\u6587\u7ae0\u4e0a\u53d1\u8868\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"\u7ad9\u70b9 logo","type":"integer","required":false},"site_icon":{"title":"\u56fe\u6807","description":"\u7ad9\u70b9\u56fe\u6807\u3002","type":"integer","required":false},"aab_settings_defaults":{"title":"","description":"","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u4e86\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u4e3b\u9898\u3002","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"\u4e3b\u9898\u7684\u6837\u5f0f\u8868\u3002\u8fd9\u662f\u4e3b\u9898\u7684\u552f\u4e00\u6807\u8bc6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"status":{"description":"\u9650\u5236\u7ed3\u679c\u96c6\u4e3a\u5177\u6709\u7ed9\u5b9a\u72b6\u6001\u7684\u63d2\u4ef6\u3002","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org \u63d2\u4ef6\u76ee\u5f55\u522b\u540d\u3002","pattern":"[\\w\\-]+","required":true},"status":{"description":"\u63d2\u4ef6\u542f\u7528\u72b6\u6001\u3002","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"\u63d2\u4ef6\u542f\u7528\u72b6\u6001\u3002","type":"string","enum":["inactive","active"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u5df2\u6ce8\u518c\u7684\u8fb9\u680f ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"\u5d4c\u5957\u5c0f\u5de5\u5177\u3002","type":"array","items":{"type":["object","string"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7c7b\u578b ID\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7c7b\u578b ID\u3002","type":"string","required":true},"instance":{"description":"\u5c0f\u5de5\u5177\u7684\u5f53\u524d\u8bbe\u7f6e\u5b9e\u4f8b\u3002","type":"object","required":false},"form_data":{"description":"\u5e8f\u5217\u5316\u5c0f\u5de5\u5177\u8868\u5355\u6570\u636e\uff0c\u4ee5\u7f16\u7801\u4e3a\u8bbe\u7f6e\u5b9e\u4f8b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7c7b\u578b ID\u3002","type":"string","required":true},"instance":{"description":"\u5c0f\u5de5\u5177\u7684\u5f53\u524d\u8bbe\u7f6e\u5b9e\u4f8b\u3002","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"\u8fd4\u56de\u5c0f\u5de5\u5177\u7684\u4fa7\u8fb9\u680f\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"id_base":{"description":"\u5c0f\u5de5\u5177\u7684\u7c7b\u578b\u3002\u5bf9\u5e94\u4e8e widget-types \u7aef\u70b9\u7684 ID\u3002","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"\u5c0f\u5de5\u5177\u6240\u5c5e\u7684\u4fa7\u8fb9\u680f\u3002","type":"string","required":true},"instance":{"description":"\u5c0f\u5de5\u5177\u7684\u5b9e\u4f8b\u8bbe\u7f6e\uff08\u5982\u679c\u652f\u6301\uff09\u3002","type":"object","properties":{"encoded":{"description":"\u5b9e\u4f8b\u8bbe\u7f6e\u7684 Base64 \u7f16\u7801\u8868\u793a\u3002","type":"string","context":["edit"]},"hash":{"description":"\u5b9e\u4f8b\u8bbe\u7f6e\u7684\u52a0\u5bc6\u54c8\u5e0c\u503c\u3002","type":"string","context":["edit"]},"raw":{"description":"\u672a\u7f16\u7801\u7684\u5b9e\u4f8b\u8bbe\u7f6e\uff08\u5982\u679c\u652f\u6301\uff09\u3002","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"\u6765\u81ea\u5c0f\u5de5\u5177\u7ba1\u7406\u8868\u5355\u7684 URL \u7f16\u7801\u8868\u5355\u6570\u636e\u3002\u7528\u4e8e\u66f4\u65b0\u4e0d\u652f\u6301\u5b9e\u4f8b\u7684\u5c0f\u5de5\u5177\uff08\u6307\u5199\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"id_base":{"description":"\u5c0f\u5de5\u5177\u7684\u7c7b\u578b\u3002\u5bf9\u5e94\u4e8e widget-types \u7aef\u70b9\u7684 ID\u3002","type":"string","required":false},"sidebar":{"description":"\u5c0f\u5de5\u5177\u6240\u5c5e\u7684\u4fa7\u8fb9\u680f\u3002","type":"string","required":false},"instance":{"description":"\u5c0f\u5de5\u5177\u7684\u5b9e\u4f8b\u8bbe\u7f6e\uff08\u5982\u679c\u652f\u6301\uff09\u3002","type":"object","properties":{"encoded":{"description":"\u5b9e\u4f8b\u8bbe\u7f6e\u7684 Base64 \u7f16\u7801\u8868\u793a\u3002","type":"string","context":["edit"]},"hash":{"description":"\u5b9e\u4f8b\u8bbe\u7f6e\u7684\u52a0\u5bc6\u54c8\u5e0c\u503c\u3002","type":"string","context":["edit"]},"raw":{"description":"\u672a\u7f16\u7801\u7684\u5b9e\u4f8b\u8bbe\u7f6e\uff08\u5982\u679c\u652f\u6301\uff09\u3002","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"\u6765\u81ea\u5c0f\u5de5\u5177\u7ba1\u7406\u8868\u5355\u7684 URL \u7f16\u7801\u8868\u5355\u6570\u636e\u3002\u7528\u4e8e\u66f4\u65b0\u4e0d\u652f\u6301\u5b9e\u4f8b\u7684\u5c0f\u5de5\u5177\uff08\u6307\u5199\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"\u5f3a\u884c\u79fb\u9664\u5c0f\u5de5\u5177\uff0c\u8d27\u5c06\u5176\u79fb\u52a8\u5230\u672a\u542f\u7528\u7684\u5c0f\u5de5\u5177\u4fa7\u8fb9\u680f\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5339\u914d\u641c\u7d22\u8bcd\u7684\u533a\u5757\u3002","type":"string","minLength":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","minLength":1,"required":false},"category":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u4e0e\u5206\u7c7b ID \u5339\u914d\u7684\u7ed3\u679c\u3002","type":"integer","minimum":1,"required":false},"keyword":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u4e0e\u5173\u952e\u5b57 ID \u5339\u914d\u7684\u7ed3\u679c\u3002","type":"integer","minimum":1,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u4e0e\u6837\u677f\uff08\u522b\u540d\uff09\u5339\u914d\u7684\u7ed3\u679c\u3002","type":"array","required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"\u8981\u5904\u7406\u7684 URL\u3002","type":"string","format":"uri","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"\u83dc\u5355\u4f4d\u7f6e\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u80fd\u529b\u5206\u7c7b\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"\u80fd\u529b\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"\u6267\u884c\u80fd\u529b\u7684\u8f93\u5165\u53c2\u6570\u3002","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u7279\u5b9a\u80fd\u529b\u5206\u7c7b\u4e2d\u7684\u80fd\u529b\u3002","type":"string","required":false},"namespace":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u7279\u5b9a\u547d\u540d\u7a7a\u95f4\u4e2d\u7684\u80fd\u529b\u3002","type":"string","required":false},"meta":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u4e0e\u6240\u6709\u7ed9\u5b9a\u5143\u5b57\u6bb5\u5339\u914d\u7684\u80fd\u529b\u3002","type":"object","properties":{"annotations":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u4e0e\u7ed9\u5b9a\u884c\u4e3a\u6ce8\u91ca\u76f8\u5339\u914d\u7684\u80fd\u529b\u3002","type":"object","properties":{"readonly":{"description":"\u80fd\u529b\u662f\u5426\u4e0d\u4f1a\u6539\u53d8\u5176\u73af\u5883\u3002","type":["boolean","null"]},"destructive":{"description":"\u8be5\u80fd\u529b\u662f\u5426\u53ef\u4ee5\u5bf9\u5176\u73af\u5883\u6267\u884c\u7834\u574f\u6027\u66f4\u65b0\u3002","type":["boolean","null"]},"idempotent":{"description":"\u4f7f\u7528\u76f8\u540c\u53c2\u6570\u91cd\u590d\u8c03\u7528\u662f\u5426\u6ca1\u6709\u989d\u5916\u6548\u679c\u3002","type":["boolean","null"]}},"additionalProperties":true}},"additionalProperties":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u80fd\u529b\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"collection":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5c5e\u4e8e\u7ed9\u5b9a\u96c6\u5408\u522b\u540d\u7684\u56fe\u6807\u3002","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<collection>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"collection":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5c5e\u4e8e\u7ed9\u5b9a\u96c6\u5408\u522b\u540d\u7684\u56fe\u6807\u3002","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/icons\/(?P<name>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?\/[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u56fe\u6807\u540d\u79f0\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/icon-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/icon-collections"}]}},"\/wp\/v2\/icon-collections\/(?P<slug>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u56fe\u6807\u96c6\u5408\u522b\u540d\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"\u5b9e\u4f53\u7c7b\u578b\u3002","type":"string","required":true},"name":{"description":"\u5b9e\u4f53\u540d\u79f0\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":0,"site_icon":87,"site_icon_url":"","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/www.sweethome3d.com\/zh-hans\/wp-json\/"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
