Staircase generator plug-in
This topic has been viewed 3500585 times and has 98 replies
Xlance
Re: Staircase generator plug-in
Post by Xlance »
@el_dario
Version 4.2 or later will be posted on sourceforge as soon as it's ready [:)]
el_dario
Post by el_dario »
Thank you for your reply, @Xlance! I eagerly await the release of version 4.2, so I can try out these new features! :)
Xlance
Post by Xlance »
NEW in version 4.2
Import Plan image of Staircase in 2D Shape Designer and Trace it to get Precise cutout *.svg path
1.CHOOSE Plan image of Staircase to Trace
2.TRACE then SAVE values of custom cutout into *.svg
3.LOAD *.svg file then COPY values of custom cutout
4.PASTE values of custom cutout into field (make sure to un-select 'generate cutout' check box)
5.CREATE staircase (custom cutout will be embedded with model)
Take screenshot
https://ibb.co/Hp7L50hg
Open 2D Shape Designer and choose image to load
https://ibb.co/kgcqv5DS
Trace outline/cutout then save in *.svg
https://ibb.co/hJPJcnb7
Load *.svg and copy values
https://ibb.co/SjhZx5Z
Paste values into custom cutout field (make sure to un-select 'generate cutout' check box)
https://ibb.co/21Pkb45G
Result
https://ibb.co/3Y0zDr4F
Why so difficult? You can easily calculate an SVG cutout string using the v lines in a room object (or any other object where an outline can be calculated from). It is much easier to draw a room then the screenshot copies. Here's the code for it in PHP and C#.
Both code listings are made to to be readable by non-programmers too. This was a test for me so a little optimization is probably possible.
The C# code is close to Java code so should be easy to convert.
The PHP code is amateur work, I only use it for my websites.
C# code:
using System;
using System.IO;
using System.Collections;
using System.Collections.Generic;
using System.Text;
namespace SH3D
	public class SVG
		// constructor
		public SVG () {}
		/// <summary>
		/// Create an SVG cutout string from the given obj file
		/// </summary>
		/// <returns>
		/// The SVG cutout string
		/// </returns>
		/// <param name='sourcefile'>
		/// The obj file to use for creating the SVG string.
		/// A cutout string is generated using the v lines in the first group, best result with a room object.
		/// </param>
		public string CreateSVGcutout (string sourcefile)
			if (!File.Exists (sourcefile)) { return string.Empty; }
#region create vertice list
			// Create an empty list to hold all vertices (v lines)
			List<Vertice> vertices = new List<Vertice> ();
			// Read all lines in the obj file into a string array
			String[] lines = File.ReadAllLines (sourcefile);
			bool start = false;
			// For each line that starts with "v " create a Vertice object and add it to the vertices list.
			// z is set to 0 by default, not used for a SVG cutout.
			foreach (string line in lines) {
				if (line.StartsWith ("v ")) {
					start = true;
					string[] parts = line.Split (new char[] {' '});
					// 0 = "v", 1=X, 2=Z, 3=Y
					Vertice v = new Vertice (double.Parse(parts [1]), double.Parse(parts [3]), 0.0d);
					vertices.Add (v);
				} else {
					// First set of v lines done, ignore the rest
					if (start) {
						break;
#endregion create vertice list
#region object bounderies
			// Get the object bounderies, I.E. the width and depth of the object
			// These are needed to calculate the L points
			// Calculating this enables processing objects that dont't have 0,0 as the position coordinates.
			double minwidth = 0.0;
			double maxwidth = 0.0;
			double mindepth = 0.0;
			double maxdepth = 0.0;
			bool first = true;
			foreach (Vertice v in vertices) {
				if (first) {
					minwidth = v.X;
					maxwidth = v.X;
					mindepth = v.Y;
					maxdepth = v.Y;
					first = false;
				} else {
					minwidth = Math.Min (minwidth, v.X);
					maxwidth = Math.Max (maxwidth, v.X);
					mindepth = Math.Min (mindepth, v.Y);
					maxdepth = Math.Max (maxdepth, v.Y);
			double width = 0.0d;
			if (minwidth < 0) {
				if (maxwidth < 0) {	// - / -
					width = Math.Abs (minwidth) - Math.Abs (maxwidth);
				} else { // - / +
					width = Math.Abs (minwidth) + maxwidth;
			} else { // + / +
				width = maxwidth - minwidth;
			double depth = 0.0d;
			if (mindepth < 0) {
				if (maxdepth < 0) { // - / -
					depth = Math.Abs (mindepth) - Math.Abs (maxdepth);
				} else { // - / +
					depth = Math.Abs (mindepth) + Math.Abs (maxdepth);
			} else { // + / +
				depth = maxdepth - mindepth;
			// Recalculate the vertice points so they start from the correct origin
			for (int i=0; i< vertices.Count; i++) {
				vertices[i].X = vertices[i].X-minwidth;
				vertices[i].Y = vertices[i].Y-mindepth;
#endregion object bounderies
#region create SVG string
			string svg = "";
			first = true;
				if (first) {
					// first starts with "M"
					svg += "M" + Math.Round(v.X/width,4).ToString() + "," + Math.Round(v.Y/depth,4).ToString() + " ";
					first = false;
				} else {
					// add L points
					svg += "L" + Math.Round(v.X/width,4).ToString() + "," + Math.Round(v.Y/depth,4).ToString() + " ";
			svg += "z";	// z = back to start (M)
#endregion create SVG string
			// return the SVG string
			return svg;
PHP code:
<?php
include_once "base.php";
if (session_id() == "") { session_start(); }
class SVGCutout {
//	private $_exportpath = TMPPATH;
	public $lines;
	function __construct() {}
	// CEILING&WALL cutout
	function CreateSVGcutout(): string
		$vertices = array();
		$start = false;
		foreach(preg_split("/((\r?\n)|(\r\n?))/", $this->lines) as $line) {
			if (str_starts_with($line, 'v ')) {
				$start = true;
				$parts = preg_split('/\s+/', $line);
				$vertices[] = array($parts[1],$parts[3]);
			} else {
				if ($start === true) {
					// ignore the rest.
					break;
		// get the object bounderies, I.E. the width and depth of the object
		// these are needed to calculate the L points
		$minw = 0.0; $maxw = 0.0; $mind = 0.0; $maxd = 0.0;
		$first = true;
		// get the object boundaries
		for ($i = 0; $i < count($vertices); $i++) {
			if ($first === true) {
				$minw = (float)$vertices[$i][0];
				$maxw = (float)$vertices[$i][0];
				$mind = (float)$vertices[$i][1];
				$maxd = (float)$vertices[$i][1];
				$first = false;
			} else {
				$minw = min($minw, (float)$vertices[$i][0]);
				$maxw = max($maxw, (float)$vertices[$i][0]);
				$mind = min($mind, (float)$vertices[$i][1]);
				$maxd = max($maxd, (float)$vertices[$i][1]);
		// calculate the width and depth
		$width = 0.0;
		$depth = 0.0;
		if ($minw < 0) {
			if ($maxw < 0) { $width = abs($minw) - abs($maxw); }
			else { $width = abs($minw) + $maxw;	}
		} else { $width = $maxw - $minw; }
		if ($mind < 0) {
			if ($maxd < 0) { $depth = abs($mind) - abs($maxd); }
			else { $depth = abs($mind) + abs($maxd); }
		} else { $depth = $maxd - $mind; }
		// to avoid division by zero if either one gets to be 0
		if ($width == 0) { return "The width is 0"; }
		if ($depth == 0) { return "The depth is 0";	}
		// create the svg string
		$svg = "";
		$first = true;
			// recalculate the vertice points so they start from the correct origin
			$vertices[$i][0] = $vertices[$i][0]-$minw;
			$vertices[$i][1] = $vertices[$i][1]-$mind;
			// calculate the M and L values
			if ($first === true) { $svg .= "M"; $first = false;	}
			else { $svg .= "L"; }
			$svg .= (string)round(($vertices[$i][0])/$width,4) . "," . (string)round(($vertices[$i][1])/$depth,4) . " ";
		$svg .= "z";
//		$fs = fopen($this->_exportpath . "svgoutput.txt", "w");
//		fwrite($fs,$svg);
//		fclose($fs);
		return $svg;
Xlance
Post by Xlance »
An excellent solution. Thank You [:)]
However in many cases I need to get creative and design a cutout which does not correspond to model edges. e.g. circular for a T shaped
That's why this code solution is easier. You can draw a room in any form you need, for example a star or T and it will calculate the cutout. To be clear: this is independent from the staircase object, completely separate. It is as if you draw the outline as in your examples but now without screenshots and as a room object.
Xlance
Post by Xlance »
Version 4.2 Released on Sourceforge
(This update took a LOT of time and effort ;-)
Enjoy
https://sourceforge.net/p/sweethome3d/plug-ins/60/#a9db
nckv
Post by nckv »
Hi, thanks for this nice plugin! Could you maybe add a function to make the "first stairs count" asymmetric, i.e. different counts for the bottom treads and the top treads?
So basically add also a "last stairs count" or something? Or maybe better names are "lower tread count" and "upper tread count"?
I have a staircase where this is like that.
Also, the latest version 4.2 is not detected by the Plugin Manager plugin yet!
dorin
Post by dorin »
Maybe this could help you.
