Staircase generator plug-in
This topic has been viewed 3500476 times and has 98 replies
dorin
Re: Staircase generator plug-in
Post by dorin »
This plugin has some fantastic features
It's not my fault. All I did was try to help some beginners by adding some legal guidelines.
Could it be improved? Yes, but that might be my fault.
Man, if Gaudí had had this plugin
It would have been really bad for us. Too many restrictions.
If you'd had it at the right time, it might have helped you save some money and preserve your self-esteem.
A short story:
Edison was once asked:
“How did you come up with so many inventions?”
“Well, everyone knows that something can’t be done.
But there are some who don’t know that, and they do it.”
Xlance
Post by Xlance »
After lots of Tweaks and Fine-Tuning !
Type T
https://imgbox.com/XbRJOBBt
Type inv T
https://imgbox.com/wo9nwJOo
Type Y
https://imgbox.com/WLfiPo9T
Type inv Y
https://imgbox.com/pJLQBRiT
sjb007
Post by sjb007 »
Hmmm. Still not quite legal. Maybe this plan-form image helps:
https://imgbox.com/JbsGNK4X
sjb007
Post by sjb007 »
In case anyone wants to chuckle at the hoops we have to jump through...
https://assets.publishing.service.gov.uk/media/60d5bdcde90e07716f516cfd/Approved_Document_K.pdf
Section 1: Stairs and Ladders
Xlance
Post by Xlance »
Minimum Head Clearance Indicator 205 cm above each Step (International Building Code = 203 cm)
https://imgbox.com/aG58qK5C
Side View
https://imgbox.com/kp1wshU2
sjb007
Post by sjb007 »
Ah yes, the "International" code where everything is in inches... i.e. America.
I had a quick look, and you've made a mistake. To quote:
Stairways shall have a headroom clearance of not less than 80 inches (2032 mm) measured vertically from a line connecting the nosings.
I see that your indicators are in the center of the tread, so the tops will be lower than required.
Xlance
Post by Xlance »
@sjb007
Adjusted to sit on step noses !
https://imgbox.com/YU59QX6n
Added NEW Custom cut out shape input field for advanced control [:)]
https://imgbox.com/7gCXhcHX
Xlance
Post by Xlance »
Added a "Save as SVG" button next to the standard "Save" button in Shape Designer.
https://imgbox.com/9Zs9mvlj
When you save as SVG, it will normalize your drawn shapes to their bounding box, save a valid *.svg file, and display a convenient pop-up window with the raw SVG Path string (e.g., M 0.2500,0.2500 L ... Z) so you can instantly copy and paste it directly into the plugin's custom cut out field.
Xlance
Post by Xlance »
Custom 2D SVG Path in Designer and in 3D View
https://imgbox.com/JhIgd3UI
el_dario
Post by el_dario »
Thank you so much for your work, Xlance! Are your more recent versions of the Advanced Staircase Generator available for download somewhere, or is the development happening in private?
I ask because I can only find version 4.0, which does not include your recent work on T-shaped staircases, which I'd very much love to try out!
