Tudor Castle version 2
This topic has been viewed 152501 times and has 68 replies
AeowynFraser
Country: Lancaster, CA, USA
Re: Tudor Castle version 2
Post by AeowynFraser »
I got the pictures rendered quicker than I thought, for the first version.
http://www.mediafire.com/file/mjjiqdcuko4rj2b/TCR-2.sh3d/file
Front, both Aerial and Virtual Visitor views. I took out the large-bit-sized rose bushes and replaced them with small-bit-sized rose bushes (also in the backyard as shown below). Then I shortened the distance of the privacy wall near the garage so that it matches the other side of the house (removing most of the hedges along that wall) leaving one long hedge there and putting a matching hedge on the other side. I also widened both garage doors by a foot as they seemed like they might be a little too narrow for the SUV I put inside the garage. I changed out the large-bit-size Sassafras tree in the front yard for a small-bit-size Aspen tree which I enlarged to match the height and width of the removed Sassafras tree. Oh, and I also switched out the large-bit-size Porch Lights for small-bit-size Wall Lamps and reduced them to better fit in the spaces. I believe that's all the changes that I made here.
Front entrance. Here's a better look at the Wall Lamps. I also changed the textures used on the screen door so that they aren't so shiny.
North side of the house. I added a Wall Lamp here to light the path.
Backyard. Aerial view, Virtual Visitor view, and two different angles of the back porch. I lengthened the flower bed as well as added more flowers in it, added Wall Lamps to both back doors as well as two Classic Lampposts to both back corners, put in a fire in the fireplace, switched out the large-bit-size corner couch for a small-bit-size corner couch, switched out the hanging lamp for the ceiling fan, changed the textures on both screen doors, added some cushions to both dog houses, and moved the two benches apart and put an end table in between them. I believe that's all the changes I made here.
South side of the house. I added a Wall Lamp here to light the path.
Garage. I added Ford Edge. I believe that's all the changes I made here.
Front room, two different angles. As you can see, not only did I open up the stairwell I also opened up the Dining Room! In so do doing, I had no need for the corner curio cabinet and took it out. The sightline through to the kitchen is much more open. I believe that's all the changes I made here.
Dining room, two different angles. I widened the China cabinet some, changed the hanging lamp for the lamp with 5 lights on it, and since the stairwell is now open I took the picture frame off of that wall. I believe that's all the changes I made here.
Kitchen, two different angles. I took out the two hanging lamps for the one with three lights, took out the large-bit-size stove for a small-bit-size stove, and since the wall to the dining room is gone I took out the wall clock. I believe that's all the changes I made here.
Guest bedroom. I took out the queen size bed for the twin size bed, basically for the bit size, added a lamp on the nightstand, and moved the TV (mainly so that I could take this picture). I believe that's all the changes I made here.
Also, I changed all the doors throughout the house, basically for their bit size.
Guest Bathroom. I added the picture lamp above the vanity and changed the toilet paper dispenser. I believe that's all the changes I made here.
Bedrooms 1 and 2. The changes I made to both rooms were the same; changed some textures (ie. on the beds and chairs), and added both the computers on the desks and the lamps on the nightstands. I believe that's all the changes I made here.
Main bathroom. I changed the textures (green is my favorite color; if I were to build this house for myself and my roommates this would be the bathroom both their sons would share and neither of them is partial to green) as well as the toilet paper dispenser, and added the picture lamps over both vanity mirrors. I believe that's all the changes I made here.
Laundry room. Switched the cabinets so that the countertop is closer to the doorframe and is visible, added a floor drain (although it isn't visible in the picture), and changed the floor tiles. I believe that's all the changes I made here.
Family room, two different angles. I changed out the large-bit-size corner couch/armchair combination for the same furnishings below in the Front room (different textures used though), opened up the entryway from the landing/hallway area (I also opened up the hallway between Bedroom 2 and the Main bathroom to the landing/hallway area but none of the pictures I took show it), switched the placement Full bookcase and the enclosed bookcase so that there would be more room to walk behind the couch. I believe that's all the changes I made here.
Bedroom 3 (the bedroom that would be for my roommates if this house were built for us). Changed the wall color and added the lamps on the nightstands. I believe that's all the changes I made here.
Bathroom 2 (en suite to Bedroom 3). I believe the only changes I made here was the wall color and the toilet paper dispenser.
Sewing Loft. I opened up the entryway from the stairwell, took out one corner desk, corner shelves and hutch, and replaced it with the sewing desk, shelves and full bookcase, switched the large-bit-size sewing machine for the small-bit-size sewing machine, took out the high boy and replaced it with the filing cabinet and upper cabinet, took out the last hutch and replaced it with another upper cabinet, and switched the light over the mirror for the picture lamp. I believe that's all the changes I made here.
Master Bedroom (basically my bedroom, although it's larger than single me would need). Changed the wall color, carpeting and the textures on the bed, and added the lamps to the nightstands. I believe that's all the changes I made here.
Master Bathroom. Enlarged the tiles around the bathtub, changes the wall color and floor tiles, and replaced the ceiling lights for the picture lamps above the vanity mirrors. I believe that's all the changes I made here.
Main floor floor plan.
Middle floor floor plan.
Top floor floor plan.
AeowynFraser
I figured I might as well also share a picture of the Landing Hallway.
The door to Bedroom 1 is the sliver of dark wood on the left side of the picture, down the little hallway straight ahead you'll see the door to Bedroom 2 (the thin strip of dark wood that is), Linen closet, and the Main Bathroom. And of course the Laundry Room is just past the stairwell.
AeowynFraser
Here's something just for fun.
I have cleared out basically all the furnishings (that aren't built in) and wall textures so that anybody can decorate it however they like. I have it looking as if it's a brand new house and you walk through it as a prospective buyer. [:D]
This is of the version I just posted about, not the one with the 8-and-a-half-foot high main floor with the visible rafters.
[url=<a href="http://www.mediafire.com/file/l4sf1wkf4 ... .sh3d/file" target="_blank">http://www.mediafire.com/file/l4sf1wkf4 ... 3d/file</a>]Tudor Castle Rethink Unfurnished[/url]
Post by bdfd »
the latest link doesn't work for me ! [:D]
AeowynFraser
I don't know why but here's I guess a better link?
AeowynFraser
It's been a while since I'd visited this house plan. The thing is, I just had an idea about changing where I have the stairs placed (mainly so that I could add a fireplace inside the house. Unfortunately, I'm in Florida, thousands of miles away from my desktop computer that has the program on it, and cannot make the changes that I have in mind.
Hopefully I'll remember about the changes when I'm back in California to make the changes, although that won't be for many months from now.
AeowynFraser
Actually, the person I'm visiting in Florida loaned me an old laptop which I've been able to download the program onto. I've been in the process of making the changes as best as I can in between working on my college classes, and hopefully I'll be able to post pictures of the changes soon.
AeowynFraser
I've got all the pictures taken, I think.
So far, no noticeable change from these angles.
Now, here's where a few changes are noticeable. There's one window from the top floor that's been removed, and the two separate back doors with screens have been removed, one of which has been replaced with a set of sliding doors. The real changes have occurred inside.
Once you step through the front door, there are quite a few changes made. I'd moved the staircase from the back wall to the front wall, next to the Guest Bathroom, just so that I could include a fireplace in the space. I've also added additional storage, mostly because the changes made it difficult (if not impossible) to keep the China cabinet I'd had in there before. Since I'd included the built-in cabinetry, the two doors that had been flanking the stairs no longer worked, so I added the set of sliding doors. Since changing to the sliding doors, the furniture no longer worked so I had to remove the 3-seat couch and the armchair, and adding a second 2-seat couch.
Also, because of moving the stairs, the placement of the water heater moved as well; it's still under the stairs though. Nothing else in this area was changed.
Guest Bedroom and Bathroom; no changes here.
Now onto the next floor.
Big change. Both sets of stairs have been moved. Of course, the one from the floor below is now over by the laundry room, and the one heading to the next floor is now against the back wall. And since they are now separated, I've added the railing next to the set coming up from below as well as an additional column. Also, as you can see, I thought it best to move the door leading into Bedroom 1 over, mainly because I just thought it weird that it faced the stairs.
Bedroom 1. Not much changed here, just the placement of the door, and the dresser was moved over to accommodate that move.
Bedroom 2. Not much changed here, at least I don't think so, except for the fact that I swapped the bed and nightstand so that the bed is now against the wall, and used a less garish color on the bed sheet. I'm not sure if I'd previously shared about the wallpaper being added, but it was in there when I downloaded the file from MediaFire.
Both the Main Bathroom and the Laundry Room. Because of moving the stairs, I needed to reshape/reconfigure these two rooms. Previously there had been a small closet at the end of the hallway, but I took that out to give room to the new bathroom shape. Also, the laundry room kind of shrunk; there's half as much storage as there had been before.
Family Room. With the hallway changing shape, the furniture needed a bit of change as well.
The Secondary En Suite Bedroom and Bathroom. No changes here, at least not this time.
Heading to the top floor and the first stop is the Sewing Loft. Not much changed here except with regards to the stairs and the door into the Primary En Suite Bedroom. And the wall color on two of the walls instead of wallpaper on all walls. I also added a wall-mounted ironing board.
Primary En Suite Bedroom and Bathroom. With moving the stairs, I was able to move the closets near the door to the Sewing Loft, so there was more space for a small sitting area.
Garage; no changes here.
Each level's floor plan.
And, last but not least, here's the link to the file.
You put a lot of time and effort in this! Over time I have seen many changes and improvements. Very well done!
