Dark Mode
This topic has been viewed 247176 times and has 34 replies
byDMA
Country: GERMANY | POLAND
Re: Dark Mode | Some impressions Beta-1
Post by byDMA »
If under FlatDarkLaf or other LaF don't look OK (columns wide, fonts, borders, icons size etc) I suspect it is the fault of LaF not of the applications.
No. This has nothing to do with FlatLaf at all. Set MetalLookAndFeel again and you will see that it has nothing to do with the topic. This is exactly how it behaves here and there. I don't want to discuss scaling.
1. start with scaling 2x
2. start GR plugin
3. maximize the plugin window
4. then make it smaller again
-> the frames are going through each other. You can no longer set the normal view manually. You have to close the plugin and restart it. Without scaling, this works well and the window gets smaller again and the frames are ok, only the font... you can't see anything ;-)
https://sun9-61.userapi.com/impg/DZvWA- ... type=album
byDMA
Post by byDMA »
But in full modus with Flatlaf looks great :)
ganonderp
Post by ganonderp »
Any progress with this?
I literally cannot use the app at all without a dark mode, I'm legally blind and dark mode is an absolute requirement for me... as it is, I'm completely cut off from using this software due to the lack of dark mode... can anyone help this blind guy out?
byDMA
Post by byDMA »
What do you mean by progress? It is still running. Where are there problems? It doesn't go over the surface. You have to adjust it as I described it.
MarioSambol
Country: Croatia
Post by MarioSambol »
What about those of us who have an aversion and problems with such a way of starting dark mode. If only there was a way to somehow put it in the installation and make it selectable as an option?
