Furniture Library Editor released
This topic has been viewed 3820732 times and has 252 replies
selden
Country: usa
Re: Furniture Library Editor released
Post by selden »
No luck: Java complains it doesn't understand the option. (rolls eyes)
Selden
However, when I tried to drag-and-drop of the directory folder containing the .obj and .mtl files into the main pane of that window, nothing happens but I get this error message in the cli (I'm using cygwin bash) command window:
You can't drag a folder in the Furniture Library Editor. You can select multiple OBJ files and/or ZIP files containing OBJ/MTL files and drag&drop those in the FLE window.
[s]I use the Java runtime provided with Sweet Home 3D and that one works perfectly fine.[/s]
Correction, for the FLE is use an older runtime: 1.7.0_261.
HeideN
Country: Sverige
Post by HeideN »
I finally got the library to open on my old windows 7 but when I try to create a new library I only got one funiture , when I import another it only changes the first one to the new object, I’ve tried the import button and drag and drop ( I can see the import process ) what is I doing wrong?
