massive color-difference
This topic has been viewed 43316 times and has 30 replies
Country: UK
Re: massive color-difference
Post by Mike53 »
Not so sure this is a new topic, i seem to recall questioning it a couple of years ago, i have found that using textures is far more accurate than colors, here are 2 images, 1 a screenshot the other a render.
and this is a Q4 render
not only does the red change to pink but it also shows how different objects color differently, the I beams are rooms and the roller support brackets are box's, both have the same color applied to them.
hal9000
Country: Spain
Post by hal9000 »
Well, more than 1 year after the last post, but... Has somebody tried to render one of these projects with YafaRay to see if the color difference between a pure color and a texture of the same color is still there?
UbuntuBirdy
Country: Switzerland
Post by UbuntuBirdy »
Interesting idea. Yes, I have, but unfortunately I have changed all my projects from colored to textured objects.
But I will this give a try.
Pascal
enkonyito
Post by enkonyito »
@UbuntuBirdy
This picture shows what's wrong in my opinion:
- The left cube has a texture which is only colored as #520015
- The right cube has the color #520015 directly
In my opinion both cubes should look the same, we should see exactly the same color. But only the textured cube shows the color #520015 as it should be.
I think the difference comes from the way Java 3D processes colors or textures.
Example of rendering in quality 1.
Enko
EnkoNyito
Country: UK
Post by Mike53 »
Not sure if this issue has been attended to but i am still getting the same issue
Roof with colour:-
Roof with texture:-
This is a known "problem". Using an even-coloured texture is the solution, as you already found out.
Country: UK
Post by Mike53 »
Just because it is something that is a "KNOWN PROBLEM" shouldn't mean we have to continue with "work arounds" rather than sorting the issues.
As a maintenance engineer i quite often use "work arounds" when needed to get a machine running, but, these are temporary, I return as soon as possible to properly make repair.
reddy.shyam
Post by reddy.shyam »
While we are at it, is my issue same as well? All my bright colors become pale when I generate an image. Please see attached.
Any setting I need to change while generating image?
Cannot attach any image host files for some reason. Tried imgur and prnt.sc`
kutlu9
Post by kutlu9 »
I'm having same problem as reddy.shyam. I was using the programm without any problems, suddenly my images become over exposed. Uninstall/reinstall didn't solved it.
I noticed sky texture or color doesn't render (rendering with only pure white color) making final image over exposed.
c0d3z3r0
Post by c0d3z3r0 »
The problem seems to be that Java3D expects Linear RGB as input color space:https://forum.jogamp.org/sRGB-and-gamma ... 38946.html
I've tested this by manually setting the RGB value of a wall to a gamma-corrected value ( lin=255*(val/255, 2.2) ), which makes yafaray and sunflow output the correct color.
There are two options: 1) feed in a generated texture or 2) convert the colors to linear RGB
Users browsing this forum: DuckDuckGo [Bot]
