Tiny display in Win 8.1
This topic has been viewed 73074 times and has 34 replies
adlerhn
Country: Europe
Re: Tiny display in Win 8.1
Post by adlerhn »
-Dcom.eteks.sweethome3d.resolutionScale=2.5
-Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel
-Dswing.plaf.metal.controlFont=Dialog-11
-Dswing.plaf.metal.userFont=SansSerif-11
-Dswing.plaf.metal.systemFont=SansSerif-11
That works beautifully! I had set -Dcom.eteks.sweethome3d.resolutionScale=2, but some fonts were huge. I have now set the other parameters as suggested (keeping resolutionScale=2 though), and everything looks great.
hds
Country: België
Post by hds »
Is there a solution for the online version? I have a 4K lapop screen...
mtm216
Country: USA
Post by mtm216 »
Just to say that on Windows 10 on a Surface book I had the same issue, but this .ini file fix worked perfectly - Thanks
Gavinx
Post by Gavinx »
I am running a Lenovo Yoga and am having the problems mentioned above.
After applying the SweetHome3D.l4j.ini fix I got some relief. Everything displays correctly except for the list of furniture items used in the plan - which is displayed as a list in the lower left panel of the screen.
This list is scrunched up.
Is there a fix for this?
Thanks
Country: UK
Post by Miker777 »
Hi.
I made this change to sh3d and must say the text size is much better for me, but, if i open - close - reopen a separate function, eg, photo or create shape, each time i open it the text size enlarges until it becomes unusuable, any idea why this would be.
Thanks
Country: UK
Post by Miker777 »
Images might explain it better.
Normal
rajeshdave
Country: India
Post by rajeshdave »
Solve the Problem thanks a lot is there any way to make the tools icons look bigger
Thank you
Mike, I found the bug you reported. It will be fixed in the next version. Thanks for reporting it [:)]
Country: UK
Post by Miker777 »
Your the man [:D]
Sorry i keep finding them [:p]
As long as you report them (gently), it's not a problem! [:)]
