Portable version of Sweet Home 3D
This topic has been viewed 118051 times and has 32 replies
Re: Portable version
Ce dossier ne contient que des fichiers temporaires qu'un bug dans la version de Java pour Windows empêche de supprimer à la fin du programme. Contourner ce bug qu'Oracle n'a pas l'air enclin à corriger est faisable sous Java 7 et beaucoup plus compliqué sous Java 6. Donc il faudra patienter encore quelques temps...
In the version 4.1 (119 MB), I found a way to delete the work folder and the temporary files it contains when the program ends normally, under Java 7 as well as in previous Java versions.
supseb, I hope this time you'll agree to qualify the new version as portable, even if the work folder will still be there after a program crash.
Thanks a lot !
But (sorry for that), isn't it possible to move this work folder in the same directory as SweetHome ?
I'll post this new in the Liberkey forum.
I chose to create by default the work folder in user home folder for performance reasons. Very often, portable versions are run on a USB key with poor performances at writing time.isn't it possible to move this work folder in the same directory as SweetHome ?
Nevertheless if you absolutely want to move this work folder in the folder where portable executables are found, you should make the following changes:
- under Windows, add to the portable version installation folder the two files SweetHome3D-windows-x86.l4j.ini and SweetHome3D-windows-x64.l4j.ini containing the following text:
-Dcom.eteks.sweethome3d.tools.temporarySubFolder="%EXEDIR%\work"Code: Select all
<key>com.eteks.sweethome3d.tools.temporarySubFolder</key>
<string>$APP_PACKAGE/../work</string>
<key>com.eteks.sweethome3d.deploymentInformation</key>- under Linux, edit the command files SweetHome3D-linux-x86 and SweetHome3D-linux-x64 and add the following text between java and -Xmx option:
-Dcom.eteks.sweethome3d.tools.temporarySubFolder="$PROGRAM_DIR"/workEmmanuel Puybaret, Sweet Home 3D creator
Thanks a lot for your response, it helps me a lot !
I have one more question about adding a plugin to the portable version.
Do I just need to put the executable jar file of the plugin into the data/plugins directory?
YesDo I just need to put the executable jar file of the plugin into the data/plugins directory?
ok. thank you for the reply. didn't worked this morning, but I will try again.
Hi again,
I created 2 small plug-ins.
If I open them with the executable jar file of SH3D from inside eclipse everything works fine.
But if I put the jar files in the data/plugins folder of the portable version, SH3D freezes and doesn't open up.
If I take the jar files out of the folder again, the portable version opens up again.
What could that be?
What could that be?
What do you mean by "freezes"? Do you see only the splash screen?
I tried again on my side and it worked with no problem.
