Process for orthographic, outlined, sectioned, images.
This topic has been viewed 17936 times and has 27 replies
Re: Process for orthographic, outlined, sectioned, images.
I just tried under Windows 10 and it worked, but apparently, you have to select both in the outline setting of Pan 3D view plug-in.
I had already tried (restarting SH3D after making the setting change) - unfortunately with no success:I just tried under Windows 10 and it worked, but apparently, you have to select both in the outline setting of Pan 3D view plug-in.
https://postimg.cc/ZBtXTKSK
Anyway, appreciate you having had a look.
Do you use the last version of Side view plug-in?
1.0 at the minute.
I had tried to update yesterday to 1.1 Beta 5 using Daniele's plugin manager but after the message box "Are you sure you want to install it" followed by YES click it had (and still does) reports an Error to the 1.1.Beta5.sh3p url
Apologies Emmanuel,
I just installed 1.1 from the plugins section at your homepage - the outline is now there in Win 10.
- Daniels118
- Country: Italy
The problem with the Plugin Manager was that the beta version of Side view plugin is no longer available for download at that url. I have updated the plugins list with the final release of the Side view plugin (1.1) which can now be installed without any issue.
Sorry for removing the Beta version of the plug-in, but I tend to do some clean up when final releases are out. Great it works now for you Niman [:)]
Have pencilled in a, recurring, calender item for successful plannning/building control application(s) occurrence - a very well deserved donation for you both ;- )
Nearly ready to start some serious drawing here - after I order the Turkey...
