confused Freezing in SH3D and Furniture Editor importing models
This topic has been viewed 82078 times and has 51 replies
henrisson
Country: United States
Re: Freezing in SH3D and Furniture Editor importing models
Post by henrisson »
Looks like it's working for me (Intel Mac). Thanks!!!
Thanks for your test. So the problem probably comes from JOGL 2.4.0 or the way to use it.
Could you also try the version 6.5.2a [edit: removed link] where I made a small change (this version will run natively on Mac M1)?
Hope to read the results of the tests of other users too. Please, give some feedback because I still didn't find any way to reproduce this issue.
henrisson
Post by henrisson »
6.5.2a crashes on furniture import.
sb0373
Country: Germany
Post by sb0373 »
Same for CentOS 8.
$ /opt/SweetHome3D/SweetHome3D-Java3D-1_5_2
#  SIGSEGV (0xb) at pc=0x00007fc37e3c0ee9, pid=121542, tid=0x00007fc35a3be700
# JRE version: Java(TM) SE Runtime Environment (8.0_202-b08) (build 1.8.0_202-b08)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.202-b08 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C  [libawt_xawt.so+0x45ee9]  ReadRegionsInList.constprop.5+0x4e9
# Core dump written. Default location: /opt/core or core.121542
# An error report file with more information is saved as:
# /tmp/hs_err_pid121542.log
Importing a furniture library works. Importing just a furniture piece fauls.
sb0373
Country: Germany
Post by sb0373 »
Sorry, that is the 6.5.2 version, not 6.5.2a
sb0373
Country: Germany
Post by sb0373 »
Actually workaround for me is to use the jar version, import the furniture and then you can use it in the bundled version.
I released yesterday a Mac App Store version 6.5.5 that should fix the issues that some of you recently encountered on Mac Intel. This version is bundled with Oracle Java 8.0_202 and JOGL 2.3.2 for x86_64 architecture and Zulu OpenJDK 15.0.2 and JOGL 2.4.0 RC 20210110 for arm64 architecture. I would have preferred to use OpenJDK 15 for both architectures but that prevents from creating a universal application which uses two different versions of JOGL (maybe I'll find another solution).
Users who still have problems under Mac M1 may run the program with Rosetta where the bug shouldn't appear (there's an option for this purpose In the Finder Information dialog box of Sweet Home 3D app).
From the different reports I got, the bug is probably a deadlock due to some changes in JOGL 2.4 required to run with recent macOS toolkit, but as I'm not the developer of this library and moreover, as I never experienced this issue myself, it might take more time to fix it and I preferred to release now this version to reduce the number of hindered users.
I developed a free version bundled with the same Java and JOGL versions too, but as it weights 30 MB more and can't be notarized, I prefer to not distribute it at the moment and in case of problems, I recommend to switch to the version 6.5.2 based on JOGL 2.3.2 (68 MB) that I released a few weeks ago. At least, users of the free version may install the version of their choice which is not the case of the Mac App Store version.
henrisson
Post by henrisson »
Confirming the app store version isn't crashing anymore.
Many thanks Emmanuel!
paepcke
Post by paepcke »
Thank you so much for this fix. I am brand new to SH3D, and was excited yesterday to discover the libraries. Yet like others I encountered the beach ball of death for the application upon importing a .dae model with what I thought was the latest version. Your fix worked.
As this issue may still happen in version 6.6, I created a special version 6.6 based on JOGL RC 2.3.2 for the users who encountered it.
This version won't run natively under ARM processors.
