Sweet Home 3D JS Online
This topic has been viewed 875626 times and has 51 replies
Re: Sweet Home 3D JS Online
Finally, the error under Windows can be fixed easily: in build.xml Ant file, just replace colons (:) in the two following lines
<arg value="../SweetHome3D/src:tools/JSweet/src" />
<arg value="def:com/eteks/sweethome3d/model:com/eteks/sweethome3d/tools:com/eteks/sweethome3d/viewcontroller:com/eteks/sweethome3d/io" />
by [font=courier new]${path.separator}[/font] (see fix here).
By the way, if you want to generate SweetHome3DJS.war file, don't forget to run Ant default target in SweetHome3D project too. SweetHome3D.jar is required to generate the war file.
chukwu
Country: Nigeria
Post by chukwu »
Hello, AMAZING STUFF Puybaret.
I have been having issues building the war file for SweetHome3DJS.
the .jar for SweetHome3D builds successfully, but all the ant commands fail for SweetHome3DJS
BUILD FAILED
/Users/sweethome3d-code-r7868-trunk/SweetHome3DJS/build.xml:88: The following error occurred while executing this line:
As you didn't report the error, it's difficult to help you.
Did you read the discussion with emirhanbskc which might help you?
chukwu
Country: Nigeria
Post by chukwu »
Hello, yes, I read the discussion, i have done everything in the readme, everything else builds, am I meant to put the sweethome3d.jar in any particular folder after building it?
How do i report the error, can i put a log here?
this is where the error starts:
transpiledLibraries:
[javac] /Users/Downloads/sweethome3d-code-r7868-trunk/SweetHome3DJS/build.xml:30: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[java] INFO: JSweet transpiler version 2.4.0-RC1 (build date: 2020-07-21 17:21:35)
[java] 2021-07-07 18:13:40.040 ERROR JSweetConfig:149 - class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader 'bootstrap')
[java] java.lang.ClassCastException: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader 'bootstrap')
[java] at org.jsweet.JSweetConfig.initClassPath(JSweetConfig.java:86)
[java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:270)
[java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:239)
[java] 2021-07-07 18:13:40.040 INFO JSweetCommandLineLauncher:671 - input dirs: [../SweetHome3D/src, tools/JSweet/src]
[java] 2021-07-07 18:13:40.040 INFO JSweetCommandLineLauncher:682 - classpath: null
[java] 2021-07-07 18:13:40.040 INFO JSweetCommandLineLauncher:697 - included: [def.*, com/eteks/sweethome3d/model.*, com/eteks/sweethome3d/tools.*, com/eteks/sweethome3d/viewcontroller.*, com/eteks/sweethome3d/io.*]
[java] 2021-07-07 18:13:40.040 INFO JSweetCommandLineLauncher:698 - excluded: []
[java] 2021-07-07 18:13:40.040 INFO JSweetCommandLineLauncher:747 - ts output dir: tools/JSweet/build/ts
[java] 2021-07-07 18:13:40.040 INFO JSweetCommandLineLauncher:754 - js output dir: tools/JSweet/build/js
[java] java.lang.IllegalAccessError: superclass access check failed: class org.jsweet.transpiler.util.AbstractTreeScanner (in unnamed module @0x2eb231a6) cannot access class com.sun.tools.javac.tree.TreeScanner (in module jdk.compiler) because module jdk.compiler does not export com.sun.tools.javac.tree to unnamed module @0x2eb231a6
warm regards
Building Sweet Home 3D JS project requires JDK 8, and not a further version. Is it your case?
[Note that building recent versions requires JDK 11, not JDK 8]
chukwu
Country: Nigeria
Post by chukwu »
yes please, my mac uses jdk 8. Do I have to put the sweethome3d.jar in any specific folder to aid the building?
I'm pretty sure you're not using JDK 8 to build the project. I just tried with JDK 15 and got the same error. If you use Terminal, set [font=courier new]JAVA_HOME[/font] environment variable to ensure Ant uses the right JDK.
No, just leave it in its default place, but SweetHome3D and SweetHom3DJS projects must be in the same folder.
chukwu
Country: Nigeria
Post by chukwu »
Thanks alot, I eventually used my windows compartment to build it. It works!
son87a
Post by son87a »
I try to deploy sweethome3djs online. But i got error:
HTTP Status 500 - Unable to compile class for JSP:
type Exception report
message Unable to compile class for JSP:
description The server encountered an internal error that prevented it from fulfilling this request.
exception
org.apache.jasper.JasperException: Unable to compile class for JSP:
An error occurred at line: 51 in the jsp file: /readHome.jsp
Resource specification not allowed here for source level below 1.7
48:        }
49:
50:        synchronized (homeFile.getAbsolutePath().intern()) {
51:          try (InputStream input = new FileInputStream(homeFile);
52:               ByteArrayOutputStream output = new ByteArrayOutputStream()) {
53:            byte[] buffer = new byte[8096];
54:            int size;
An error occurred at line: 67 in the jsp file: /readHome.jsp
64:
65:      response.setIntHeader("Content-length", homeFileContent.length);
66:      response.setHeader("Content-Disposition", "attachment; filename=" + homeFile.getName());
67:      try (OutputStream servletOut = response.getOutputStream()) {
68:        servletOut.write(homeFileContent);
69:      }
70:    } %>
Stacktrace:
	org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:103)
	org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:366)
	org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:494)
	org.apache.jasper.compiler.Compiler.compile(Compiler.java:379)
	org.apache.jasper.compiler.Compiler.compile(Compiler.java:354)
	org.apache.jasper.compiler.Compiler.compile(Compiler.java:341)
	org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:662)
	org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:364)
	org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:395)
	org.apache.jasper.servlet.JspServlet.service(JspServlet.java:339)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
My java version:
 java -version
openjdk version "1.8.0_312"
OpenJDK Runtime Environment (build 1.8.0_312-b07)
OpenJDK 64-Bit Server VM (build 25.312-b07, mixed mode)
My Tomcat version:
Server version: Apache Tomcat/7.0.76
Server built:   Nov 16 2020 16:51:26 UTC
Server number:  7.0.76.0
OS Name:        Linux
OS Version:     3.10.0-1160.36.2.el7.x86_64
Architecture:   amd64
JVM Version:    1.8.0_312-b07
JVM Vendor:     Red Hat, Inc.
Can you help me ?
It's strange because even if [font=courier new]try (resource) { }[/font] syntax is allowed only from Java 7, your server seems to use a JDK 8. Maybe try to run the server with JDK 11.
