SH3D detects prefixes and displays "Modify deformation".I still don't know if "modify deformation" gets added during the process of making the object (...)
Sweet Home 3D 6.0
This topic has been viewed 1241760 times and has 196 replies
Re: Sweet Home 3D 6.0
ndorigatti
- Country: Italia
Dear Pubayet,
I think i've found a use case that is not managed by rotation implementation.
I have a door with the "rotating" part composed of a small frame and a mirror.
Before sh 6.0 my model had the mirror obj item named as:
sweethome3d_window_mirror
for making it reflect.
Now since i want the mirror to rotate around the hinge, i tryed to rename the item but with no success..
I've seen there is sweethome3d_windows_pane_on_hinge but this makes the part transparent and not a mirror! Any hint?
ndorigatti
- Country: Italia
What i mean is that according to your explanation at first page:
There is one name missing here, I'd add sweethome3d_window_mirror_on_hinge_
and similarly for rails. This would allow to have openable mirror door (I have one at home!) and also turnable mirrors like:
- The parts of an opening able to turn around the hinge numbered x should be prefixed by sweethome3d_opening_on_hinge_ followed by the same number x. For example, sweethome3d_opening_on_hinge_1_door and sweethome3d_opening_on_hinge_1_handle will rotate around the axis defined by sweethome3d_hinge_1, or defined by sweethome3d_hinge_1_top and sweethome3d_hinge_1_bottom. If you want to define transparent panes directly without a transparent material, you can also use the prefix sweethome3d_window_pane_on_hinge_ followed by the hinge number. The axis direction of the hinge x is guessed from the largest dimension of the global bounding box of the hinge parts. Thus, if the largest dimension of a hinge is its height, the axis will be vertical, if its largest dimension is its depth the axis will be horizontal in Y direction and if its largest dimension is its width the axis will be also horizontal but in X direction. Axes can only be parallel to X, Y or Z axes at the moment, but this looks largely enough. The axis may be defined with some dummy parts that are not visible (like in the kitchen cabinet).
[font=courier new]sweethome3d_window_mirror_on_hinge_[/font] or [font=courier new]sweethome3d_mirror_on_hinge_[/font] prefixes don't exist, so you can't make a mirror turn yet.
I'll see if it's possible in a coming version.
ndorigatti
- Country: Italia
ok thanks for the confirmation! in the meantime i've prepared my door with the first prefix you wrote, so if ever will be possible, i'll be already there![font=courier new]sweethome3d_window_mirror_on_hinge_[/font] or [font=courier new]sweethome3d_mirror_on_hinge_[/font] prefixes don't exist, so you can't make a mirror turn yet.
I just have to remember to not rotate the door!
thanks!
For your information, I released the portable version 6.0 today.
Probably just me but thought i would post anyway, i got the latest version from amazon earlier but i couldn't get the shape generator plugin or 1.6 of the photo rendering to work, so now i have the free ver. 6 again.
The latest version available at Amazon is still the version 5.7. Hope they will fix their internal reorganization soon so I can release a 6.0 update there too.
OK thx Emmanuel
After upgrading to 6.0, I am unable to save my drawing?
