Same image – like night & day - a miracle?
This topic has been viewed 17031 times and has 16 replies
enkonyito
Re: Same image – like night & day - a miracle?
Post by enkonyito »
@Ceciliabr
I think I prefer dark level 2. The difference might seem minimal on these small pictures, but will probably be a lot more visible on a larger image.
By default, the dark value is 0.
You can test the minimum night brightness (dark value 1/255) with the beta version of the plug-in .
[If it's possible, I'll try to embed a dark level test instead of changing the value in the source code.]
On the two lower images I can see there is a blue hue that is more visible on dark level 1 than on dark level 2, but it seems to be the other way around on the two bathroom images. Does this have anything to do with sky texture or colour?
As the SimpleRoom.sh3d project has an outside opening, I used a black texture for the sky.
EnkoNyito
Country: Copenhagen, Denmark
Post by Ceciliabr »
I did, but I did not notice any difference from the default renderer.
cec
enkonyito
Post by enkonyito »
With your project, the difference between dark value = 0 (default renderer) and dark value = 1 is not obvious. That's why I added dark value = 2.
The PVR-1.4_betaTest version will allow you to choose the desired dark level (0, 1 or 2). [:)]
Enko
EnkoNyito
Post by Ceciliabr »
Perfect!
With dark level 2 I can see the body of the bathtub.
This bathroom has no windows.
I will make a window and do another test after dinner :)
I think adjustable DARK LEVEL is a keeper.
cec
Post by Ceciliabr »
Bathroom with window.
cec
enkonyito
Post by enkonyito »
The option can also be used for the exterior.
I think I will also choose dark level 2 for the final version of the plug-in.
EnkoNyito
Post by VeroniQ »
I like dark level 2 renderings! Thank you EnkoNyito.
