SweetHome3D On Surface Book Hi Res Display
This topic has been viewed 13403 times and has 13 replies
Slate
Re: SweetHome3D On Surface Book Hi Res Display
Post by Slate »
Hello I also have a Microsoft Surface Book with 3000x2000 display and I'm not having any luck getting the display to look decent. It seems no matter what I try I still have a truncated left menu in Sweet Home 3D.
I've tried both the Windows 5.5.2 version and adding an ini file with 1 line or the 5 lines of code mentioned here to no avail, and the Java Web Start 5.5.2 version.
Any thoughts?
Are you sure the .ini file doesn't have an additional .txt extension?
Slate
Post by Slate »
Arg you're absolutely right, I recently switched computers and I didn't realize the option to view file extensions was still turned off so the file was actually showing .ini.txt instead of just .ini. Many thanks for your spot-on reply!
Thanks for your feedback [:)]
I feared that the solution I programmed didn't work anymore on some configurations...
