Sweet Home 3D 4.4
This topic has been viewed 391178 times and has 95 replies
Re: Sweet Home 3D 4.4
Can I just delete the content of the entries in autoCompletionStrings# ?
Actually, that was a stupid question. Sorry. Just did, and it works. Recent files are back. Me happy [:)].
By the way, the new version splash warning confuses me a bit.
[font=courier new]The home "C:\xxx\xxx\xxxx.sh3d" was created with a more recent version of Sweet Home 3D.
The information added to home in that version won't appear with the version of Sweet Home 3D you use now.
[/font]
As far as I can tell all of the information added in 4.4 BETA is also available when using 4.3.
Before changing anything in eTeks\Sweet Home 3D private folder, I would create a backup of it, so if something goes wrong, you can get back your previous settings.
No, a rotated texture won't appear as rotated in version 4.3 and if you save a sh3d file with Sweet Home 3D 4.3 in which you used a rotated texture, it won't appear as rotated anymore when you reopen it in version 4.4. Same thing for dropOnTopElevation value, and future information that might be added in coming beta versions.
pmralbuquerque
Country: Portugal
Post by pmralbuquerque »
Hi Emmanuel,
there are some menu commands needing translation, but I can't find them in the language file available on the site. Is it my error?
Regards,
Pedro.
Pedro, the new features are only translated in English and French at this moment.
Once all the features I want to add will be in the beta version, I'll write to you and other translators to translate all of them in one go. Easier for me and for you [;)]
pmralbuquerque
Country: Portugal
OK. Keep up the excellent work and thank you.
Still looks very good! No crashes, no unexpected results, no hangs after testing a couple of files. New functions appear to work, except possibly (?):
The recent textures, it seems, are not saved in preferences (like recent colours). At least here (Win 8.1, Java version 1.7.0_51 / 32 bit) they have not been available in the next session. But maybe that was intentional?
BTW, I would actually prefer if the set of recent textures (and colours) followed the sh3d file (saved in the home). My two serious project are so different (one mountain shelter with lots of bare wood and coarse textures, one urban with painted walls and fine textures), and when I change between them I really do not need the other set of textures. And if I work on different machines, I would really prefer that I could pick (easily) the recent textures used in that project (and not re-import my own .sh3t). Just a thought [:)]
...list is longer than 8092 characters... ..It will be fixed in the next version.
After I emptied <entry key="autoCompletionStrings#3">, the recent file list and other prefrences behave well [:)]. Have not reached 8092 characters yet, but it keeps filling with all names of imported furniture, whether it has been changed or not. My 2p worth is that this is not a vital function and could certainly be cropped at a lot less than 8000.
PS
Got it, silly of me, I thought you had implemented something which disabled all new info . How about: "The information added that is specific to the newer version will not work with the version of Sweet Home 3D you use now and will be lost if file is saved ." Totally minor point, of course.
Library editing restrictions: When modifying a texture from a texture library, it was never possible to change the size (i.e. "modify"). With 4.4b, it is possible to change the angle of the texture, but not the size/scale.
PS Maybe I missed something in the PluginTexturesCatalog.properties to make textures scalable afterwards?
I know. Colors are just a number, so it's easy to save recent colors. Textures are images with other information that may come from the default library, from .sh3t files or individually imported textures, and this is more complicate to save/read when recent textures list is saved in preferences. I keep it in mind for later.
How about: "The information added that is specific to the newer version will not work with the version of Sweet Home 3D you use now and will be lost if file is saved."
Thanks for the suggestion. I think "will not work" is too severe and let the user think it won't work, whereas it could work partly. But I agree with the warning that the information could be lost if the home is saved.
Yes. The effect of changing the texture size may depend on whether the 3D model defines some texture coordinates or not. I think this concept is complicate to explain to beginners and even to advanced users because a 3D model isn't obliged to define all its texture coordinates if they exist. To avoid some comments like "I changed the texture size but this had no effect on the 3D model", I prefer not to propose this feature at the moment.
There's a solution that would avoid the user to worry about texture coordinates, but it's buggy and I'm not sure it can be exported at OBJ format. Don't worry I keep it in mind and will investigate further if I can circumvent the issue I discovered.
No, but I hope you understood why from my previous comment.
Got it! And thanks for explaining. These are very minor issues. Please, see users reporting stuff they do not understand as a vote of confidence [:)]
Anyway - happy with 4.4b - great improvements on a very good product.
interele
Post by interele »
Is it possible to have the No Offscreen Images version
as an installable option
Ta
