problem with make a Photo
This topic has been viewed 8967 times and has 25 replies
Re: problem with make a Photo
I hope someone here can help me. I know enough to know that I need to increase the memory usage for my program. I have the 64 bit java and sweethome.jar downloaded. My proplem is that I am a complete novice and I don't understand the instructions in the FAQ regarding......execute the java -Xmx4096m -jar path\to\SweetHome3D-4.0.jar command for 4 GB.......How exactly do I accomplish this? Can someone please give me step by step instructions? I am running windows 7 on my machine. I need this quick. My project is for a college course. It is due Monday. I have finished my design, but it is large and has a lot of furnishings. The program keeps locking up.
Hi Jusmara,
my Email was blocket by your Provider!.
Peter
Peter
centi, couldn't you explain in the forum? It may be helpful for other users one day...
Step by step (windows7 64bit):
download the file SweetHome3D-4.0.jar and save in to Folder "C:\Program Files (x86)\SweetHome3D\"
right mouse Key on Desktop -> new text file -> start.txt
rename start.txt into start.bat
edit the file and write the following into:
@echo off
{Java -Xmx4096m -jar "C:\Program Files (x86)\SweetHome3D\SweetHome3D-4.0.jar"}
exit
(between the {..} have to be in one line and without { }.)
save the file.
redy!
double-click this file and sweet home starts.
In this way, makes Sweet Home 3D no Problems.
Peter
@echo off
exit
save the file.
redy!
Peter
Hello Centi and Emmanuel. Thanks for trying so hard to help me, but I am still a little bit lost. I have the sweethome file downloaded and saved into the correct folder (C:\Program Files (x86)\SweetHome3D) I am missunderstanding your instructions at the point that you say "right mouse Key on Desktop" I don't know exactly what you mean. If you mean to right click the mouse on my desk top, a window appears with a list of options starting with "view" and ending in "personalize" I don't think that is what you intend for me to do. If I understand your instructions, I need to find the file called "start.txt" then rename it "start.bat" I then open that file and write
@echo off
exit
Exactly as you have it above with the text between the {} all in one line but without the {}. Is that correct? If so, the first thing I need to know is exactly where and how to find "start.txt"
@echo off
exit
yes I mean Desk top.
Sorry, my Windows talk German
right mouse key on free place on desktop, then new, and then textdokument.
Then you have a new file on desktop with name what you want.
You self can give the Name for this file, for example start.txt or sh3d.txt or what you want.
regards
Peter
regards
Peter
Ok Peter. I have made the file and it is on my desktop. I named it sweethome start. When I double click it. It just opens the file and I see this.
@echo off
exit
Nothing actually happens other than the file I created is now open and I have the opportunity to change the code. Do I need to move the file somewhere else, or is the above code incorrect somehow. What you see here is copied and pasted from the file I created on my desktop.
@echo off
exit
i wrote rename this file.txt in file.bat...
that's all
regards
Peter
that's all
regards
Peter
Now sweet home closes automatically ! grrrrrrrr !
while you work on sweet home
don't close the black window.
leave this window open or minimize it.
and you will be happy
ragards
Peter
ragards
Peter
