Save does not save !! HELP !
This topic has been viewed 16614 times and has 12 replies
Re: Save does not save !! HELP !
You ran SweetHome3D from the tar file correctly. [:)]
I'm pretty sure that the message in the console shows that you succeeded to import a 3DS file but couldn't use it later. Quite strange... Anyway it's not an issue with some missing textures because texture images are missing so often in 3D models distributed on the web, that I chose to ignore the missing ones rather than refusing the 3D models that use them.
Would you have a link to the "Armchair N230808.3DS" file or [url=mailto:[email protected]]send it to me privately[/url]?
Send me also your SH3D file. I should be able to fix it by program and it will help me to find your issue. But from your first messages... I thought you couldn't save any SH3D file???
GTX
Country: St.Petersburg, Russia
Post by GTX »
Yesterday got the same problem as ocumo3D. Luckily the unsaved project was a simple test, so I didn't get crazy losing all the work :)
Well, I have been using Sweet Home 3D v.3.7 under Windows XP SP3 for about a week without any problems. Yesterday I opened the existing project, added some furniture and imported different models (3ds and obj's and other) and so one. Then I noticed saving did not perform. I tried different filenames and folders to save file in but didn't get any success.
Today I read this thread and checked recovery and work folders
\eTeks\Sweet Home 3D\recovery\ is empty
\eTeks\Sweet Home 3D\work\ contains some folders with files
Maybe you need some additional data to catch the problem. That's why I'm here :)
PS
I have SweetHome still running with this unsaved project :lol:
collinsmwenda
Country: Zambia
Post by collinsmwenda »
I need help. I downloaded furniture and inported it in sweet home. After that I couldn't save anymore. I uninstalled, redownloaded and installed still same problem. To make matters worse, I cannot even draw walls
