Thank you for the explanations.
1. Memory
I was programming in NI LabVIEW and for the last 10 years in C# for the .Net Framework. Both running on Windows. In both environments the garbage collector will decrease memory when the new loaded file needs less objects than the old one.
I never programmed in Java so I don't have any experience with it. But I expected when starting SH3D the memory is b. Loading Home1 it is b + h1. Loading Home2 giving a second instance of SH3D it is b + h1 + h2. Removing the instance of Home 1 it will give b + h2 + r. I think r is management information for the objects which is also be used by Home 2.
2. 3D View
I was always asking myself how I can close the 3D View. I see the three dots on the three splitter bars (the vertical one and the two horizontal). But I don't see an arrow even not in GIMP with 400 % scaling.
Linux, slow actions in 2D area.
This topic has been viewed 10883 times and has 15 replies
Waldemar.Hersacher
- Country: Germany
Re: Linux, slow actions in 2D area.
MSI GP60, Linux Mint 22.2 Zara base: Ubuntu 24.04 noble SH3D 7.5 with Photo-video rendering 2.8
Same here, 30+ years C#, multiple other languages but not Java. The point was that collecting garbage takes time, even if it's so little you should hardly notice it. More collections = more time. How much memory really is freed or not is not that important nowadays as long as you have enough memory for the job. Working without enough memory will cause swapping and THAT is really slow.
The 2D and 3D panes are separated with a thin splitter bar. On the left of that bar you should see two tiny arrows. You can drag the splitter bar up and down or use the tiny arrows to fully open/close one of the panes. Same with the left and right panes. That splitter bar has the tiny arrows at the top of the bar.
Waldemar.Hersacher
- Country: Germany
They should be located at the left or right end of the bar or at the top or bottom. But I'm missing them.
And it doesn't matter which pane is active. I miss them even if the 3D view is active.
You're right, they should be visible but aren't. This remains even after restarting Sweet Home 3D?
You can try to detach/re-attach the 3D pane. Right-click in the 3Dview window and select "Display in separate window". Then right click in the 3DView window again and select "Display in main window". With a little luck the arrows will appear, otherwise the separate window is possibly an option for you.
I have Sweet Home 3D running on several versions of Debian with the Mate desktop and have never lost the arrows. Maybe it's a specific problem with your Linux desktop or desktop theme. Try the default theme and see if the arrows appear.
This is the fault of the GTK Look and Feel that is used by default in Ubuntu. You have two options:
1) Use Ctrl-Space. This will hide the 3D pane effectively. I can't find a shortcut to bring it back, so you would have to drag it up. There might be one, I just can't find it right now.
2) Disable the GTK theme so you see the arrows on the splitter. Warning: Ugly UI ahead! Just add the following comand line option in the SweetHome3D startup script:
-Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel Re: Linux, slow actions in 2D area.
A long list of Sweet Home 3D keyboard shortcuts: https://www.sweethome3d.com/blog/2019/0 ... tcuts.html
By-the-way, Ctrl Space is not in that list and neither is its reversal.
