applause High priority Roof with dormers and many corners and pitches // Dach mit Gauben und vielen Ecken und Neigungen
This topic has been viewed 9732 times and has 17 replies
shyne
Re: Roof with dormers and many corners and pitches // Dach mit Gauben und vielen Ecken und Neigungen
Post by shyne »
@Hansmex - I tried but I think I was really in geometry in school :D I get messed up in the 3D world. Anyway, I haven't taken time to test all those new possibilities. I think, I will get a good result.
@Keet As understood, there is no way in SH3D to make a whole into an object. I have to do this in another program
What you explained, will be a great help in some situations. But this time I meant, how can I find objects, which were made invisible. But now I am thinking, they still must be in the list in the bottom left corner. (and indeed they are)
So thank you for the great support.
Check the Furniture List in the bottom left window. There are check marks on the last column...
shyne
Post by shyne »
Hi Hans,
I found them, thank you :)
https://workupload.com/file/ELhVMSQbv38
Now I have experimented with the roof parts. It looks quite good. The angle in the "ridge" is now wrong because I inserted the dormers at the ends. But that would be OK. However, I can only change the size if I keep the proportions and then it doesn't fit on my surface anymore. Ideas?
Ideally, the ridge would also be pointed, but I would have the dormers at the ends...
shyne
Post by shyne »
https://workupload.com/file/duGWm2HAgxb
I did the following, resize the rood without the middle part (doesn't bother about proportions)... then add the middle part. I had to manipulate the height and so on and I am not sure, wether this is the best method, but hey, it 's a little bit more similar to what I needed...
Looks like a nice roof.
I hope my tips were useful?
If you need more help, just ask.
And share the design file....😃
shyne
Post by shyne »
Yes, you were great help! Absolutely! Here is the roof: https://workupload.com/file/DgM5yagGStX The parts don`t fir perfectly but for me it works :)
shyne
Post by shyne »
(This website won't keep the files for very long)
dorin
Post by dorin »
This is what I've done in few hours. Of course it is more to work.
And HERE is the file (my vision)
