Weird 3D Artifacts
This topic has been viewed 353870 times and has 108 replies
Johannes_Angello
- Country: Deutschland
Re: Weird 3D Artifacts
I have the same issue with:
GPU - AMD Radeon RX 6600 XT - Primär/Diskret
VRAM - 8176 MB - GDDR6 2000 MHz
Treiberversion - 22.20.19.11-220915a-383673E-AMD-Software-Adrenalin-Edition
AMD Windows-Treiberversion - 31.0.12019.11001
Direct3D-API-Version - 12.1
Vulkan™ API Version - 1.3.217
OpenCL™ API Version - 2.0
OpenGL® API Version - 4.6
Direct3D® Driver Version - 9.14.10.01523
Vulkan™ Driver Version - 2.0.233
OpenCL® Driver Version - 31.0.12019.11001
OpenGL® Driver Version - 22.09.1462311
2D-Treiberversion - 8.1.1.1634
2D-Treiberpfad - /REGISTRY/MACHINE/SYSTEM/CurrentControlSet/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0001
UI-Version - 2022.0915.1840.1936
AMD Audio-Treiberversion - 10.0.1.24
Treiberanbieter - Advanced Micro Devices, Inc.
Windows Edition - Windows 10 Core (64 bit)
Windows-Version - 21H2
Im trying to escalte this topic via AMD.
Does anyone have got a solution yet?
I reported this as a bug to AMD directly with their bug reporting tool. Instructions for doing so can be found here: https://www.amd.com/en/support/kb/faq/amdbrt. I have linked to this thread for further reference along with uploading some relevant screenshots. Hopefully that helps themJust confirming that this is still an issue with latest Adrenaline driver (22.9.1) released yesterday (2022-09-21)
https://www.amd.com/en/support/kb/relea ... win-22-9-1
Does anyone know the exact crux of the issue so that we can report it directly to AMD?
Just updated to 22.9.2 (released today, 2022-09-27) and the issue persists. I will be reporting this bug to AMD again.I reported this as a bug to AMD directly with their bug reporting tool. Instructions for doing so can be found here: https://www.amd.com/en/support/kb/faq/amdbrt. I have linked to this thread for further reference along with uploading some relevant screenshots. Hopefully that helps themJust confirming that this is still an issue with latest Adrenaline driver (22.9.1) released yesterday (2022-09-21)
quallemalle
I recently switched my GPU from Nvidia to AMD and also can confirm this bug with 22.10.1 driver :/ Will create a bug report
coldcomfort
Just happened to me too. I had no issues the other day and made no driver or windows update since (did install a new firewall). Only installed a few sweethome3d plugins the last time, but all worked just fine then.
The 3d view window is grey now when opening the program, with no model. Then loading a model gives those artifacts above, in both the 3d view and planview (objects are all black). And everything is a mess. Tried reinstalling and got the same issues.
AMD Radeon Vega 8 integrated graphics
Could some of you try Sweet Home 3D executable jar with a recent version of Java 17:
- download Java 17 and install it
- download Sweet Home 3D executable jar
- open a cmd window and run the command: (to get SweetHome3D-7.0.2.jar file path easily, drag-and-drop the file in the cmd window).
I wonder if it would run better, it could also worth to try the 32 bit version of Sweet Home 3D.
java --add-opens=java.desktop/sun.awt=ALL-UNNAMED --add-opens=java.desktop/com.apple.eio=ALL-UNNAMED --add-opens=java.desktop/com.apple.eawt=ALL-UNNAMED -jar path\to\SweetHome3D-7.0.2.jarI wonder if it would run better, it could also worth to try the 32 bit version of Sweet Home 3D.
coldcomfort
I fixed it by reinstalling my radeon software, with a factory reset. Downgrading to the 22.5.1 version.
quallemalle
Tried out running the jar with Java 17 as you mentioned but it did not fix the issue :/ (AMD Driver 22.10.3)
Just ran into this problem as well... so I guess we have to wait for AMD to fix it? Shame.
You’re not obliged to wait for AMD good will, just downgrade to version Adrenaline 22.5.1.
