Total posts in this thread: 9
Previous Thread This topic has been viewed 5423 times and has 8 replies Next Thread
Max_Webler
I see red! What happened?
Hello Community,
i'm trying SweetHome3d for a couple of weeks now - what a cool tool!!! Thanx to all developers!!!
But yesterday it happened that i opened my file, and the 3d shows all chosen textures and furniture in red. Changes cannot be saved ("couldn't save file.....) except if you save under a new name. All chosen furniture is marked with a little red cross.....what's going on ???
Could it be that a piece of my imported furniture isn't programmed correctly in such a way, that it jams the rest too???
Any ideas?
Max
[Oct 18, 2008, 10:11:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Max_Webler
Re: I see red! What happened?
Hello,
meanwhile i updated my java to version 6 update 10 - no changes....:-(
By the way, i run Sh3d on a toshiba laptop (celeron M) under Win XP home SP 3.
[Oct 18, 2008, 10:44:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry for the problem.
First create a backup of your file, even if it doesn't work correctly.
Then, check if you use Sweet Home 3D 1.4, because there was a small bug about saving wrong SH3D files and I fixed it again in that version (see https://sourceforge.net/tracker/index.php?fun...id=152568&atid=784665 ).
This bug fix won't repair your file, but at least it shouldn't happen anymore.
I didn't find yet what could cause this problem. It's maybe a software that cleans temp files ?
I can try to restore a part of your file. Please send it to info@eteks.com
[Oct 18, 2008, 10:55:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Max_Webler
Hello Emmanuel,
nothing to be sorry about....it's freeware so we all give our share...
I just mailed the file to you, if it is easy to fix, of course that would be nice,
if not please let me know soon, so i have time to do it again.
Thanx, Max
[Oct 19, 2008, 7:20:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Max sent me his file, but miserably I couldn't repair his file.
Here's the solution I proposed him to avoid him to create again all his home:
1. Open the corrupted file
2. Click on plan to set focus in it, and choose "Edit > Select All" menu item (Ctrl + A)
3. Choose "Edit > Copy" menu item
4. Open a new home with "File > New" menu item
5. Click on plan to set focus in the new plan, and choose "Edit > Paste" menu item
6. Items will be still red in the new home, but all the walls and dimensions are nevertheless correct. Then, set again the texture of the floor, the texture of the walls, and replace each red object by one of the catalog. Once done, remove the red objects. To sum up make the "red" disappear.
7. Once there's no more red, you can save your new home.
[Oct 19, 2008, 7:55:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Chuck_Baker
Be very careful when using registry cleaners/optimizers, for in earlier versions of SH3D, the red x's will abound.
[Oct 27, 2008, 2:57:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
All new imported furniture are stored in temporary files, and then copied to application directory. If a system tool empties temporary directory, it's true that you may get some problems.
I'll try to fix that in a future version.
[Oct 27, 2008, 7:12:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Max_Webler
Yep, i guess that was it!!!
I think it was my Spybot 1.6 asking me if he were allowed to wipe my temp-files....... unhappyness sometimes is just one click away....;-(
Maybe the Spybot-Gang could add a note to this feature mentioning possible problems with wiped-out temp-files.
Well i guess indeed it would be a good idea to save the projects in a "safe" folder.... hope its not toooo much programming work.
Greetings & Thanx, Max
P.S. Emmanuel: I didn#t recieve any mail from you - probably didn't pass my spam-filter.
[Oct 27, 2008, 8:53:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Max_Webler
Done!
It actually works the way Emmanuel described!
Max
[Oct 27, 2008, 10:23:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
