Australia
Kitchen carcasses not scaling properly
I'm sure this is an operator error, but my furniture objects (Kitchen Carcasses do not seem to be scaling properly. In the attached snippet, I'm trying to fit 3 objects L5 U7 &U8 whose dimensions total 2060mm into a 2400mm space. The display shows the 3 objects exceeding 2400mm even though they are only 2060! Is this a screen display issue?
Romania
Re: Kitchen carcasses not scaling properly
NO.
Not quite but YES. You have rotate every cabinets by 90dg. In this way You don't change the original dimensions of furniture but only orientation. By the way in this positions You can't use it in real life; the handle are on the back of next cabinet. At least as I see from your picture.
