Total posts in this thread: 6
Previous Thread This topic has been viewed 12857 times and has 5 replies Next Thread
timegroove
Sweden
Livingroom in new apartment
Hi!
After buying a new apartment that was not even built yet, I wanted a program that would let me visualise it and to try some different interior ideas. After some googling I found Sweet Home 3D and made a model of the apartment. Here is a design I did of the living room.
/Timegroove
[Oct 5, 2019, 1:30:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Livingroom in new apartment
Well done and very smart! However, the thin lights, especially on the doors at the right side, are a little bit odd. Are you sure that your room joins totally your walls?
[Oct 6, 2019, 1:28:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maureenowaters
Congrats on it's, it's really so beautiful, just love it.
[Oct 9, 2019, 7:59:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bartosz
Poland
Good job. I especially like the models, however VeroniQ made a good point, I also noticed sun leaks. I recommend to re-doble click all your floor corners to make them match wall corners or even overlap them, then your celiling will be sealed as well. I had the same bad experience - when your main plan is not locked then it's very easy to accidently move the floor when working on models. I appreciate your work on lighting. Can you make some other angles?
[Oct 11, 2019, 8:15:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
timegroove
Sweden
Thank you all for your comments. :) Yes, I noticed some sun leaks on the right side, but I ignored it so far, I should try to fix it. On the left side is a window and a door that is open, that is why there is sun coming in.
Maybe I can make some other angles. The light is setup so it looks good from this angle, I will try and see how it looks from other angles.
[Oct 17, 2019, 2:51:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great art ! wink
[Nov 1, 2019, 7:22:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
