Re: YafaRay rendering plug-in
@Puybaret
I'm happy to present you the YafaRay Rendering plug-in (version 1.0 - 24 MB) able to render images with Yafaray engine, thanks to the new Tools > Create photo with YafaRay menu item. ... It's able to run under Windows 32 / 64 bit, macOS 64 bit and Linux 32 / 64 bit. Spherical lens is missing and will be hopefully implemented in a future version.
As this rendering engine is constantly evolving and a new version YafaRay v3.4.1 (2020-04-08) is available, will there be a new version of the plug-in each time?
EnkoNyito
@Ceciliabr
I ended up with a question in my head: “Is it Blender creating these wonderful renderings, or can the same quality be obtained from SH3D?” ... The question rises again: Is it Blender, or is it YafaRay that creates the high quality images shown at the YafaRay Gallery? ... Of course i realise that I’m not able to utilise the SH3D / YafaRay combo to the max after just a few days work, but I have a feeling that a lot is depending on the advanced settings and light options provided by Blender.
YafaRay is mainly designed to work with v2.7x versions of Blender at the moment and take full advantage of the features offered by it. Each scene (point of view) often has a specific setting because the anti-aliasing samples are also a multiplication factor (detailed information).
And if Enko is reading this: The PVR 1.9 combination renderer is a perfect tool! I use the faster Sunflow option for quick previews of sunlight and shadows directions during construction (Sunflow will normally render me a preview faster than YafaRay can finish the preloading ), and then I use YafaRay for artificial lighting and final rendering.
Thanks for the compliment! I just contributed to the immense work provided by Emmanuel to create the YafaRay plug-in. After further testing, I plan to increase the maximum value of the anti-aliasing samples to match level 5 of SunFlow (1024 samples per pixel).
EnkoNyito
The plug-in uses the YafaRay source code available in the end of 2019 (not sure it was exactly v3.3.0). I'll make the plug-in evolve with YafaRay new versions, but for the moment, I prefer to wait for the YafaRay developers answer for my request about equirectangular images support. We never know, we could have a nice surprise as they work on YafaRay again.
By the way, Cecilia, I love your renderings
Good news! David Bluecame added an equirectangular camera to YafaRay yesterday. I gave it a try this morning and it worked as expected, so I should be able to generate a new version of the plug-in with this missing feature soon.
The best news here is that David Bluecame is actually still updating YafaRay. The present version was released some three years ago, unless I'm mistaken, and the YafaRay forum has been relatively dead lately, so even an alfa-version bears good news.
Just wondering: Does YafaRay use GPU as well as CPU? My activity monitor indicates some GPU activity that is not present when rendering with Sunflow.
Thank you! Much appreciated! I really like YafaRay. I'm still experimenting, but I will find time to create and post some new snapshots soon, now that the youngest is back in kindergarten, at least most of the days.
DE
Those are really good news!
Can you estimate, when it will be available in SW3D?
A few days, a few weeks, or a few month?
I simply want to plan my project and optimize either for YR or SF rendering.
DE
When I look at the rendering process (Windows7 and 10), I see that the CPU is fully loaded and the GPU shows no significant load. Three questions: 1. Are there some adjustments or tricks, to force and use a faster GPU usage? or 2. Are there plans to integrate this feature in the near future?
3. Generelly asking (As I do not have any idea): Are some other 3D apps much faster, because the renderer is using the GPU, or is that a similar speed (for similar tasks)? Do those user also need to wait hours and hours for 1 large picture - if many light-sources are active in a larger room?
Here's the version 1.1 of the YafaRay rendering plug-in which allows to compute equirectangular images. It's based on the version 3.4.2 of YafaRay that David Bluecame very gently accepted to release with the missing camera used to compute this kind of images.
Equirectangular image of example 12 of the gallery (4000x2000 image)
@s_koch Finally, YafaRay doesn't really use the GPU. I think its team would like to use it in a future version but it's of course a complicated improvement. I don't know how much other rendering engines perform better or not. Even an in-depth study of their performances may lead to some too big expectations, because as soon as you integrate all the parameters in the rendering, you may loose a lot of CPU power. I expected that YafaRay would be able to run 10 times faster that SunFlow but finally this factor is more often 2 or 3 and some users even experienced some cases where YafaRay was slower than SunFlow!
Emmanuel, do you plan to implement caustic photons for direct lighting in a future version?
@enkonyito If it's not complicated, I'll add the missing methods in JNI if needed. Any information that will help me to program it faster will be appreciated. Note also that version 1.1 of the plug-in uses named cameras to let you generate videos more effectively in your plug-in, without the need to regenerate the scene at each frame.
DE
Kudos to David and YafaRay team!
And some extra Kudos to you, dear Emmanuel for this extreme fast response!!
But how to use "named cameras", or do you mean the named positions ("point of view") of the "visitor"?
And when I create a video, how to choose one of the 2 rendering engines?
