Re: YafaRay rendering plug-in
Could you try with some files of the gallery (like the Alps hotel that you seem to like ;-), and report how rendering works with them?
For what it’s worth:
I have made some more tests with the YafaRay renderer, using an abused version of the Alps Hotel. The abuse was necessary because I wanted to test how YafaRay responded to lighting. Since YafaRay is not yet ( at least not in the current version) able to handle Enko’s “Other Light Sources”, I had to see what could be done without using them – only using a multitude of the original light sources – like I used to do in the “old days”.
Result: The YafaRay renderer v1.6 beta works surprisingly well.
Here are some YafaRay renderings of the abused Alps Hotelreception and front desk:
The CPU-issues from the last version are gone. YafaRay is now using all my 24 threads, as well as 92% of my CPU-capacity, and it’s performing quite fast – almost 50% faster than Sunflow. It’s also producing some nice results – as long as have the patience to work with my light-settings. And that’s where my ONLY complaint lies… for now:
Checking the lights are alfa and omega. Enko has showed that programming a resizable render window is possible. A resizable window will fit on any screen, no matter how stone-age the computer is. So I ask: Is there a good reason for keeping the “official” render windows of SH3D so tiny?
Why is resizable so important? As the YafaRay renderer is handling light sources somewhat different than the Sunflow renderer, it’s of no use to test my light-settings by using Enko’s resizable renderer. So testing the YafaRay renderer becomes a somewhat time-consuming process: First rendering the entire scene, then saving the test image. Then opening the test image in some graphics editor, and then trying to adjust the lights and do another test render… and then repeat the same process. I must admit that my motivation failed along the way, so my test renders are not what I would have liked them to be. I know that YafaRay can produce better results – even great results, but I don’t think that will happen until we get more options – plus a resizable rendering window, so we can monitor the effect of our light-settings a lot faster than with the current version.
The bucket size of the YafaRay renderer, is it dynamic? I'm wondering if that's the reason why it outperforms the Sunflow renderer.
[Edit 1 times,
last edit by Ceciliabr at Jan 25, 2020, 10:59:43 PM]
You absolutely nailed it! It's nothing more but all about that point!
Pascal
Here's the version 1.0 Beta 7, probably the last one before I release a final version.
This version brings support for Windows 32 bit and Linux 32 bit, the reason why it's almost twice larger (24 MB) than previous Beta. From my tests, it requires at least Windows 7 and Ubuntu 16 to run. I wonder though if it's worth supporting 32 bit systems, because when a rendering runs out of memory, the program will crash and this may happen even with some examples of the gallery.
I also added the Depth of field lens (still with focus at 2.5 m) as shown in the screenshot below, and managed the silk effect of colored materials at the best quality level. I wished I could get a nicer effect, but similarly to SunFlow Uber shader, it seems to be complicated to get a good solution.
Finally, I improved the copy of 3D models into YafaRay at rendering launch, added the ability to resize the rendering dialog box and saved its location / size in properties separated from the default photo creation panel ones.
It's mostly for aesthetic reasons, because I didn't like the space around the small group of controls at the bottom of a very large dialog box, and managing a minimum size isn't so easy. And not everybody has a large screen...
It looks like, and it's interesting at the end of a rendering because it helps to continue using all the power of the CPU.
I don't think so.
Thanks again for helping me testing this new plug-in
I just released the final version 1.0 of the YafaRay rendering plug-in. The final version should show some less blue images when the default sky is used in aerial view, thanks to a little more power set on the sunlight source.
Thank your all for your tests and feedback. Hope you'll enjoy this new plug-in
About the light panel color, maybe you could apply a light_mat material on the mesh (see the end of exportAppearance method)?
My first tests were inconclusive because all the objects in the scene had the 'light_mat' material. By applying it only to opaque light sources, I get this result. You will notice that unlike SunFlow, the YafaRay rendering engine does not take into account the light power for the "glow" effect.
For a first version, this plug-in keeps its promises! In order to finalize the integration of YafaRay with the PhotoVideoRendering plug-in, I still have to bind this rendering engine to the photo panel at points of views and the video panel.
EnkoNyito
Singapore
Thank you for the wonderful work! I love the speed of Yafaray.
First thing I noticed from my very first comparison test, is that the the reflection on the red cabinet surface is missing but I guess it's not a bad thing...
Absolutely a good version. Unfortunately I have hurt my hand, so I haven’t been able to do the tests I wanted. (I am writing this with the wrong hand)
I have made a very fast test and gotten some unexpected results.
I wrote earlier that YafaRay outperformed Sunflow on the speed. I no longer think that is right. I have tried the SPR(v1.9) on some older projects that are quite big and complicated, and I found that Sunflow is A LOT faster. Especially glass, mirrors and glowing surfaces seems to slow YafaRay down.
On SH3D-demo projects, YafaRay is absolutely faster, but as soon as things start to demand more of the renderer, Sunflow can be more than ten times faster. ( 6 hours compared to 29 minutes)
Have a look at this ( small) project file: Boxes.sh3d ( 49 kb).
This is basically a very simple project, containing four boxes, placed 50 cm above a mirror, everything resting upon a white backdrop ( illum 0 ). Boxes from left to right : 1 coloured white, 2 textured with a white texture , 3 same white texture applied to each side, 4 red texture applied to each side.
The renderings:
Default YafaRay = 1 min 30 seconds ( manually timed)
SPR(v1.9) YafaRay = 2 mins 48 seconds ( plus some strange texture effects)
Spr(vi.9) Sunflow = 5 seconds (!)
I will do some more tests when my hand is working again :)
Using Cecilia's test file, I get slightly different results.
Tests with a file I shared before, now repeated.
All tests done under Windows 10.
Based on the second test, I prefer the colours of Sunflow, but the reflections from Yafaray. Also, it's surprising that Enko's plug-in takes 30 secs longer for the renders.
[Edit 1 times,
last edit by hansmex at Feb 19, 2020, 11:55:15 PM]
