Posts: 173   Pages: 18   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 476029 times and has 172 replies Next Thread
jjocsak
Re: YafaRay rendering plug-in
After I installed the plugin I noticed it's grayed out and cannot be selected.
What am I doing wrong?
Thanks
Jeff
[Nov 23, 2019, 5:46:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MichaelN
I just tried these plugin but it generates only complete grey pictures. Have I to do more than copying the file in the plugin folder?
[Nov 24, 2019, 9:43:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito, did you export and load all the YafaRay DLLs required for the plug-in, like in the loadDLLs method I programmed in YafarayRenderer class?
jjocsak, the current version of the plug-in can work only in 64 bit. Maybe you installed Sweet Home 3D in 32 bit? If it's the case, just relaunch the installer and select the 64 bit architecture in the screen that allows to choose the installation folder. Of course, this will be possible only if your system is 64 bit.
MichaelN, did you try with some other files, or maybe the demos?
[Nov 25, 2019, 11:30:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MichaelN
I tried it with my own file, not with the demo file.
I now tried an aother position, which works fine. Than I go again back to my kitchen - other view than before - and SH3D crashes without any message. It just disappears from the desktop.
[Nov 25, 2019, 4:45:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jjocsak
64 bit install solved the problem, thanks.
[Nov 25, 2019, 5:29:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Yes, otherwise it causes the error java.lang.ExceptionInInitializerError .
What would prevent access to native methods in this case (java.lang.UnsatisfiedLinkError ) ?
EnkoNyito
[Nov 26, 2019, 11:20:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Enkonyito, if you moved native methods to another class or package, you'll have to generate new .h and .cpp files and compile source code to update libyafarayjni.dll. Did you succeed to generate such a DLL?
[Dec 16, 2019, 3:25:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
As this solution (#2) works, I have not retested since.
I had failed to generate the DLLs in a custom package (betaTestPlugin) when trying to follow this method:
// To generate JNI DLL for Windows, read "YafaRay Windows 10 MinGW 64bit building - Standalone.txt" in Core-3.3.0\building (no need to install Python and stop after installing LIBRARY DEPENDENCIES)
// Run C:\mingw64\mingw64-shell.exe and use the following command (/C/Program Files/Java/jdk1.8.0_121 contains JDK)
// plugin project folder> g++.exe -D_GLIBCXX_USE_CXX11_ABI=0 -I"/C:\Program Files\Java\jdk1.8.0_201\include" -I"/C/Program Files/Java/jdk1.8.0_201/include/win32" -Isrc/betaTestPlugin/include/yafaray -Isrc/betaTestPlugin/include/other -I/C/msys64/mingw64/include src/betaTestPlugin/YafarayRenderer.cpp -shared -o src/betaTestPlugin/lib/windows/x64/libyafarayjni.dll -Lsrc/betaTestPlugin/lib/windows/x64 -llibyafaray_v3_core
EnkoNyito
[Dec 16, 2019, 11:14:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Some suggestions for the next version (1.0 Beta 4):
- use a YafarayRenderer.properties file to modify rendering parameters such as for SunflowRender.properties
- include an example xml scene using arealights or visible spherelights because their implementation is problematic
- make tile borders visible to see the number of rendering threads
Enko
Feedback on the light panels.
* When I choose,
params.put("type", "arealight");
// Uses the YafaRay coordinate system (X-right, Y-back, Z-up)
// vertex0 = (0% lightWidth, 0% lightDepth, 0% lightHeight)
// vertex1 = (100% lightWidth, 0% lightDepth, 0% lightHeight)
// vertex2 = (100% lightWidth, 0% lightDepth, 100% lightHeight)
// vertex3 = (0% lightWidth, 0% lightDepth, 100% lightHeight)
Point3f vertex0Location = new Point3f(0.0f - 0.5f, 0.0f - 0.5f, 0.5f - 0.0f);
Point3f vertex1Location = new Point3f(1.0f - 0.5f, 0.0f - 0.5f, 0.5f - 0.0f);
Point3f vertex3Location = new Point3f(0.0f - 0.5f, 0.0f - 0.5f, 0.5f - 1.0f);
lightTransform.transform(vertex0Location);
lightTransform.transform(vertex1Location);
lightTransform.transform(vertex3Location);
Point3f corner = new Point3f(vertex0Location.getX(), -vertex0Location.getZ(), vertex0Location.getY());
Point3f point1 = new Point3f(vertex1Location.getX(), -vertex1Location.getZ(), vertex1Location.getY());
Point3f point2 = new Point3f(vertex3Location.getX(), -vertex3Location.getZ(), vertex3Location.getY());
params.put("corner", corner);
params.put("point1", point1);
params.put("point2", point2);
params.put("color", new float [] {
((lightColor >> 16) & 0xFF) * ((this.homeLightColor >> 16) & 0xFF),
((lightColor >> 8) & 0xFF) * ((this.homeLightColor >> 8) & 0xFF),
(lightColor & 0xFF) * (this.homeLightColor & 0xFF), 1});
params.put("power", power * 100);
params.put("samples", 4);
createLight(UUID.randomUUID().toString(), params);
no light is emitted.
* When I choose,
params.put("type", "meshlight");
params.put("double_sided", false);
params.put("light_enabled", true);
Sweet Home 3D automatically closes every time without an error message in Eclipse.
EnkoNyito
[Jan 1, 2020, 8:51:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
For various reasons, I wanted to be able to recompile YafaRay DLLs. I succeeded to achieve this task without big problems under Windows and Linux thanks to the instructions given in YafaRay source code, but I had much more difficulties to make it work under macOS!
Finally, I was able to generate new DLLs based on a slightly modified version of the current source code (to fix an issue on normals management) and I'm happy to propose a version 1.0 Beta 4.
This new version is much smaller (13 MB instead of 46 MB) and should work under more systems.
enkonyito, before I investigate your problem, could you try again with this new version fist?
Happy New Year 2020 to everyone smile
[Jan 12, 2020, 1:56:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
