Re: YafaRay rendering plug-in
@Puybaret
Avoid to touch the native YafarayRenderer.cpp file used as a bridge to YafaRay if you don't know JNI (Java Native Interface), but it shouldn't be necessary.
After generating the YafarayRenderer.h file, modifying the YafarayRenderer.cpp file, adding the include and lib folders, rendering returns the error
Exception in thread "pool-7-thread-1" java.lang.UnsatisfiedLinkError: betaTestPlugin.YafarayRenderer.createEnvironment(Ljava/lang/String;Ljava/lang/String;)J at betaTestPlugin.YafarayRenderer.createEnvironment(Native Method)
The YafarayRenderer.class file is located in the bin/betaTestPlugin project folder.
What is the best way to use the YafaRay rendering engine in another plugin (derived version)?
EnkoNyito
enkonyito, did you export and load all the YafaRay DLLs required for the plug-in, like in the loadDLLs method I programmed in YafarayRenderer class?
jjocsak, the current version of the plug-in can work only in 64 bit. Maybe you installed Sweet Home 3D in 32 bit? If it's the case, just relaunch the installer and select the 64 bit architecture in the screen that allows to choose the installation folder. Of course, this will be possible only if your system is 64 bit.
MichaelN, did you try with some other files, or maybe the demos?
I tried it with my own file, not with the demo file. I now tried an aother position, which works fine. Than I go again back to my kitchen - other view than before - and SH3D crashes without any message. It just disappears from the desktop.
Enkonyito, if you moved native methods to another class or package, you'll have to generate new .h and .cpp files and compile source code to update libyafarayjni.dll. Did you succeed to generate such a DLL?
I had failed to generate the DLLs in a custom package (betaTestPlugin) when trying to follow this method:
// To generate JNI DLL for Windows, read "YafaRay Windows 10 MinGW 64bit building - Standalone.txt" in Core-3.3.0\building (no need to install Python and stop after installing LIBRARY DEPENDENCIES) // Run C:\mingw64\mingw64-shell.exe and use the following command (/C/Program Files/Java/jdk1.8.0_121 contains JDK) // plugin project folder> g++.exe -D_GLIBCXX_USE_CXX11_ABI=0 -I"/C:\Program Files\Java\jdk1.8.0_201\include" -I"/C/Program Files/Java/jdk1.8.0_201/include/win32" -Isrc/betaTestPlugin/include/yafaray -Isrc/betaTestPlugin/include/other -I/C/msys64/mingw64/include src/betaTestPlugin/YafarayRenderer.cpp -shared -o src/betaTestPlugin/lib/windows/x64/libyafarayjni.dll -Lsrc/betaTestPlugin/lib/windows/x64 -llibyafaray_v3_core
Some suggestions for the next version (1.0 Beta 4): - use a YafarayRenderer.properties file to modify rendering parameters such as for SunflowRender.properties - include an example xml scene using arealights or visible spherelights because their implementation is problematic - make tile borders visible to see the number of rendering threads
