Posts: 173   Pages: 18   [ Previous Page | 9 10 11 12 13 14 15 16 17 18 ]
Previous Thread This topic has been viewed 476707 times and has 172 replies Next Thread
mickut
Finland
Re: YafaRay rendering plug-in
Found the issue. A seemingly innocent looking model of a Denon LP player downloaded as Collada file:
https://3dwarehouse.sketchup.com/model/146e08...6a3/Denon-SL-7D-Turntable
Works almost OK with SunFlow, crashes YafaRay instantly. When I change "edge_color*" invisible in materials, it works.
The resulting non-crashing render does have some texture or surface clipping issues (and I've noticed it on many other models from 3dWareHouse as well).
[Jan 27, 2022, 8:10:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Probably you have already noticed that making 'material' (just above material 0 in Model materials list of Denon), material 12 and material 13 invisible will remove most of that surface clipping.
Reason for clipping seems to be that model has different color/material on inner surface and outer (visible) surface.
At some angle the phenomenon appears as the inner color leaks through.
[Feb 18, 2022, 5:33:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The version 1.4.5 fixes crashes that may happen with DAE models specifying only transparent color for some of its effect / material (generally edges like reported by mickut).
[Feb 25, 2022, 3:18:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
For your information, YafaRay renderer is now available in Sweet Home 3D 7.0 making this plug-in useful only if you use an older of Sweet Home 3D.
[Jul 18, 2022, 9:21:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
