CH
How do I delete a section of a wall (create a room)
Hi all, I am a newbie and have a question for the pros:
I am creating a 2D plan for a flat remodel to give to my contractor:
I created 3 adjacent rooms (no external wall yet). A section of a wall that is common to two rooms will be removed in order to create a larger room (a kitchen). The room will no longer be a rectangular shape. Now, how do I 'delete' the section of the wall in order to open up the two rooms? Does the SH3D software allow to delete sections of a room or walls?
If not, how would you perform this operation in 2D? Thanks!!
Romania
Re: How do I delete a section of a wall (create a room)
For wall question: 1. Select the wall between two rooms; 2. Right click on selected wall; 3. Split wall; 4. Delete one section; 5. Resize the remaining section to Your desire length.
For room question You have two options: 1. Delete one room & resize manually the remain.(It's a little bit hard) 2. Delete both rooms & recreate automatically by double clicking inside the new walls area. (It's the easy one)
