Total posts in this thread: 9
Previous Thread This topic has been viewed 12967 times and has 8 replies Next Thread
KitchM
Export to OBJ
Do I understand correctly, that the best format for export to make it importable to other cad programs is to use obj? Will it save all the dimensions and other details as well?
[Aug 5, 2019, 5:28:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Export to OBJ
Not quite, Sweethome3D ONLY exports to .obj, paired with a .mtl file, there are a number of online file converters that could enable you to import into other software.
Sweethome3D does allow you to import other file types into SH3D, for a list of these see - Support > 3D Models > Create your 3D models
[Aug 5, 2019, 8:21:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KitchM
Re: Export to OBJ
Interesting; I thought it also did HTML.
So, when you are saying that a person needs to export to .obj and then use a file converter to create another program's format, does that mean that one also exports the .mtl? And does that mean that the converter must use both the file types in its translation process? How would it know to do so?
Also, I still need to know if the dimensions and other details are transferred to the new format.
[Aug 5, 2019, 10:06:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Export to OBJ
The html plug in allows you to export the 3d view, it can then be viewed via a browser remotely.
Never used the online converters.
[Aug 5, 2019, 10:29:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KitchM
Re: Export to OBJ
I think I get it. Thanks.
[Aug 12, 2019, 7:52:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Forestsun
Re: Export to OBJ
I think we don't need to reinvent the wheel. I know the simple and useful online file converter here I think more people will use this tool because it really helps. What else services do you know?
[Sep 4, 2020, 9:58:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JonnyD
Status: Online
Re: Export to OBJ
I'm getting an error when I attempt to save an .obj file from a furniture item. I'm running MACOS Sonoma and SH3D has full disk access
"Can't create .OBJ file"
Doesn't matter where I save it.
Anybody have an idea of how to fix this please?
[Jan 11, 2024, 10:45:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Export to OBJ
Did you try to export a simple item like a wall?
[Jan 12, 2024, 9:04:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JonnyD
Status: Online
Re: Export to OBJ
Hi Emanuel - sorry, didn't see your reply in my notifications. Yes, I've tried saving just a wall, or a cube. It doesn't matter where I save to, even one-drive or an external HD.
[Jan 23, 2024, 1:13:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
