uk
2D & 3D issues
hi im after some help when drawing walls on a level with a pattern down the walls drawn in 2D dosnt show on the plan but shows in the 3D view or how do I view anything on other levels through the plan view
Re: 2D & 3D issues
You can change the pattern used to fill a wall thickness in the plan with the drop down list Pattern in plan available in the wall modification dialog box. You can change the pattern of multiple walls at the same time, by selecting them and choose Plan > Modify walls menu item.
