Previous Thread This topic has been viewed 16806 times and has 13 replies Next Thread
Re: Additional Sunflow options (tests)
@ enkonyito
Maybe this is not the right thread to discuss this, but I'm somewhat puzzled by the way Sunflow handles shininess.
It's like shininess is either on or off, with nothing in between.
I have done several tests on this, and I'm really wondering if the shininess slider has any function at all.
Is this just a result of the limitations imposed by SH3D, or is this a real Sunflow limitation?
[Aug 8, 2019, 12:02:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@Ceciliabr
In the Modify furniture panel, Matt=0 and Shiny=0.5.
In the Furniture materials panel, Matt=0 and Shiny=1. The Java 3D preview lets you see the difference in shininess.
When rendering, Sunflow applies a shader to the material that "changes" the shininess. (see pages 14 to 23 of Sunflow Wiki PDF)
As Puybaret had told me : "There's no limitation".
Sunflow's standard configuration in Sweet Home 3D is based on several tests performed in 2010 (Test 1, Test 2).
Enko
EnkoNyito
[Aug 9, 2019, 2:08:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
* Option:
-bucket X Y
Changes the default bucket size to n pixels and the default order (BucketRenderer, MultipassRenderer).
Sunflow default value: bucketSize = 32, bucketOrder = hilbert.
SH3D default value: bucketSize = 64, bucketOrder = spiral.
SH3D implementation:
int bucketSize = 16; // min = 16, max = 512
this.sunflow.parameter("bucket.size", bucketSize);
String bucketOrder = "spiral"; // hilbert, spiral, column, row, diagonal or random can be reversed
this.sunflow.parameter("bucket.order", bucketOrder);
this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS);
EnkoNyito
[Aug 23, 2019, 2:07:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
These options will no longer be managed in the next version of the photo-video rendering plug-in.
EnkoNyito
[May 27, 2021, 3:34:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
