Total posts in this thread: 8
Fintan
Strange "shadows" in 3D view
Hi all Maybe this is covered somewhere else already, but I could not find it. Anyway when in 3D view and at certain side view angles, I get these strange trianggular "shadows" coming out of the floor and going to a wall. I would upload an image if I could.Instead here is the droppbox link:https://www.dropbox.com/s/9p8cmsmhhe8myr7/Shadows_1.png?dl=0 Can someone please point me in the right direction? I cannot finish this project without solving this issue first. Cheers Fintan
[May 15, 2019, 4:34:40 PM]
[Link]
Re: Strange "shadows" in 3D view
Hi Fintan, I suppose it's a question of ceiling. Try to remove it and see what's happen. If you need it at some places, create a new room and display only the ceiling.
[May 16, 2019, 9:26:38 AM]
[Link]
Fintan
Thank you Veroni That did the trick. But wny I wonder?? Cheers anyway!
[May 16, 2019, 9:36:55 AM]
[Link]
Ceilings cause this problem when not all the walls have the same height. Possible solutions: - Try to draw a room by hand using only walls with the same height. - Split a room in two or more smaller rooms if not all walls have the same height. H
Hans new website - under constuctionhansdirkse.info
[May 16, 2019, 9:37:27 AM]
[Link]
Fintan
Thanks Hans. so, in this case I would have to build the terrace as a separate "room" then add it on to the main Rooms?
[May 16, 2019, 10:49:51 AM]
[Link]
Imagine you have an L-shaped room. One leg has higher walls, and thus a higher ceiling, than the other leg. By hand draw a room in the first leg, than draw a second room in the other leg H
[May 16, 2019, 11:32:02 AM]
[Link]
Fintan
Right. Ok. Cheers
[May 16, 2019, 12:30:37 PM]
[Link]
bkdroid13
Cool. thanks for sharing. its helped to me
[Jun 1, 2019, 9:22:59 AM]
[Link]
