Total posts in this thread: 40
Posts: 40   Pages: 4   [ Previous Page | 1 2 3 4 | Next Page ]
Previous Thread This topic has been viewed 19425 times and has 39 replies Next Thread
SARRAVAL
Re: Problème de lumière.
Love this room, looking forward to more.
Thank you very much, it's a pleasure, when someone appreciates your work.
Un dessin vaut mieux que mille explications.
[Apr 24, 2019, 8:09:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SARRAVAL
Quelques corrections
Je n'ai pas encore mis en rendering la console retourné , mais ca arrive , le calcul est très long !!!!!
[Apr 24, 2019, 4:12:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I have a suggestion for your ceiling/lighting, would you mind if i posted a small image as explanation?
[Apr 24, 2019, 7:26:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SARRAVAL
It does not bother me at all on the contrary I am eager to learn.
[Apr 24, 2019, 7:46:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
My sentiments exactly.
You have positioned light sources in the corners, the reason is understandable, but there does not appear to be anywhere for that light to come from.
I propose a modification to the molding arrangement, if it can be done with this molding, Here is my suggestion.
It is only a thought, easily discarded, but it may help.
[Apr 24, 2019, 7:55:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SARRAVAL
I'll try this option, and I'll keep you up to date.
[Apr 25, 2019, 8:07:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SARRAVAL
Voila:
[Apr 25, 2019, 4:25:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
An impressive room, but still room for improvements, hopefully.
There is a File here that might be able to help.
I did not want to flood your topic, so the file contains 4 images. Each is a replica, close, of your room, illuminated in 4 different ways. 0 and 1 show "normal" light sources, 3 and 4 are using Enkinyito's latest beta 1.7 rendering plug-in, which you will need should you decide to replicate it, The .rar file also contains the sh3d file i used to create the images.
None of them are intended as cut/paste solutions, but to give you an idea of what could be achieved. From the file i hope you will be able to illuminate your room to your satisfaction using some of the info, heights, elevations, power settings etc.
Ignore the sources near the french doors, that was a separate test.
Good luck. wink
[Apr 26, 2019, 6:20:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bettycc
Moi je ne trouve pas joli ces luminaires dans cette pièce
[Apr 26, 2019, 6:35:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tous les goûts sont dans la nature ! Moi, je trouve ces luminaires très sympas et ils rendent même étonnement bien.
[Apr 26, 2019, 10:50:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
