dorin
Romania
Re: How can I edit a Collade File?
In this particular case I do this to solve the problem: 1. Import the zip file with import furniture; 2. Select and than Modify furniture...->Materials:Modify...(as hansmex specify) 3. Select material_3 and set invisible ->OK; 4. Select and export selection as obj; give them a name; 5. Import it as furniture and You will have desire furniture. All's well but this is not always the case. In other cases I import and modify the obj with AOI and then import as furniture with cautions at dimensions.
A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law
[Apr 22, 2019, 4:10:41 PM]
[Link]
