Romania
Re: Rooms Surfaces plug-in
@bdfd From what I see You've right but... I don't know what to say. Only think that cross my mind is the 1-st suggestion I've propose. In this way You could test everything on a clean medium. At least for me is the best way I use when I test new furniture, texture or plug-ins. It's possible to interfere with other plug-in but I have almost the same as You installed (except Meta text) and I don't see any problem. Sorry man, I reach my skill's limits.
Romania
@bdfd Sorry if I boring You but I can't sleep. I've compare what You have with mine: 1. I see an very huge plug-in Koping (8.5M). I try to find it on google without success. 2. In second image I share my plug-ins folder and the way I use when I test something. I create an folder under plugins (mine are "Rezeva" which mean "backup" ) where I put the files I don't use everyday and I don't want to delete. Usually I drag-and-drop from an location to another. SH3D will see and load only those from plugins nothing else. If You can, please send me the link of Koping.sh3p and the source cod if it's free. Happy Easter! Dorin
TY Dorin.
Here are my installing plugins.
My last try : I moved all plugins in a backup directory except your. I launched sh3d. Result : no change ! .
Romania
New version 1.2 and also on Source Forge -add localization (only French); -add icon; -now work including on new file after room creation;
@bdfd You've right, on some localization don't work. I've try to fix it in this version.
@UbuntuBirdy I intend to add perimeter and walls surface surround rooms with and without hols (doors and windows) to have more useful information. But all under the same check box.
Australia
Feature Request - Re: Rooms Surfaces plug-in
I want more. Why? Because what you have almost does what I want and I don't want to write it myself.
What do I want?
A breakdown of area values,
The ability to create a list of key/value pairs,
The capacity to multiply any given area by one of those values, and
The resulting subtotals.
Why should you do it? Because it would be awesome useful.
Follow me here;
Key value list Ceiling paint 0.1 l/m^2 Ceiling paint (wet area) 0.13 l/m^2 Render 0.8 kg/m^2 Paint Primer 0.011 l/m^2 Red paint 0.019 l/m^2 Red paint + primer 0.03 l/m^2 Carpet 59 $/m^2
Area Material Result Room Name Ceiling 32m^2 Ceiling paint 3.2 litres Floor 32m^2 Lineolem $940 Wall 1 12m^2 Red paint + primer 0.36 litres Wall 2 12m^2 Red paint + primer 0.36 litres Wall 3 12m^2 Red paint + primer 0.36 litres Wall 3 12m^2 Wood Panel $390
Material Total Ceiling paint 3.2 litres Lineolem $940 Red paint + primer 1.1 litres Wood Panel $390
There are obviously a multitude of ways to summarise and present the results, but I'm hoping you can see the value to people who use SH3D to plan renovations and decorating.
Romania
Re: Feature Request - Re: Rooms Surfaces plug-in
Dear Jay,
Well, why not? You are bather than me! (I've study Your code for stairs). Other wise You will have to wait until I manage to learn how to do this.
At that moment I still working to add walls surfaces which surround each room without holes. The perimeter I've implemented but I'am not fully satisfied. According to this I what to change the plugin name in "Rooms Info".
Follow me here;
I've follow Your demands and I've see: The next step is to have some walls surfaces as accurate as possible.
I want more.
Me too but I don't know when. I weren't good enough to convince Santa to make me such gift
